Kubota Compact Tractor B2410D-ACE Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B2410D-ACE Compact Tractor
Number of Pages: 237 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Radiador / Main Bearing Case
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaft
Ponto Neutro / Idle Apparatus
Bomba Gasoleo / Fuel Pump(Mechanical)
Acessorios / Water Pump
Válvula E Veio Do Balanceiro / Valve And Rocker Arm
Filtro Ar / Air Cleaner
Escpae / Muffler
Deposito Combustivel / Lower Gasket Kit
Deposito Combustivel / Fue L Tank
Tubo Combustivel / Fuel Pi Pe
Filtro Gasoleo[Peças Compo Nentes] / Fuel Filter [Component Parts]
Ventilad Or / Fan
Radiador / Water Pipe
Filtro Gasoleo / Stop Sol Enoid
Dínamo / Dynamo
Dinamo [Componenetes] / D Ynamo [Component Parts]
Motor Arranque / Starter
Motor Arranque [Component Es] / Starter [Component Parts]
Comutador / Switch
Painel / Panel Board
Painel[Peças Componentes] / Panel Board [Component Parts]
Farol Dianteiro / Head Li Ght
Lâmpada De Alerta De Peri Go / Hazard Light
Farol Traseiro / Tail Lig Ht
Cabalagem Eletrica(Cabine )[Ec] [G] / Electrical Wiring
Compensador / Clutch
Embraiagem / Clutch Rod
Bloqueio Diferencial / Clutch Pedal
Caixa Velocidades / Transmission Cas E
Carter Eixo / Rear Axle Case
Veio Primario / Front Shaft
Veio Tdf / Pto Shaft
Tdf Central / Mid Pto
Diferencial Carter / Rear Differenti Al
Veio Tracao Dianteira / Front Wheel Propeller Shaft
2 Velocidade / 2nd Shaft
3 Velocidade / 3rd Shaft
4 Velocidade / 4th Shaft
Forqueta Caixa / Creeper / Range Gear Shift Fork
Alvanca Tdf / Pto Gear Shi Ft Fork
Alavanca / Differential Lo Ck Shift Fork
Alavanca Velocidades / Mai N Gear Shift Lever
Alavanca Velocidades / Ran Ge Gear Shift Lever
Alavanca Dupla Traccao / F Ront Wheel Drive Lever
Alavanca Tdf / Pto Gear Sh Ift Lever
Eixo Traseiro / Rear Axle
Bloqueio Diferencial / Differential L Ock Pedal
Travão / Brake
Tirante Travao / Brake Rod
Pedal Travao / Brake Pedal
Alavamca De Controle / Hydraulic Control Lever
Bomba Hidraulico / Hy Draulic Pump
Bomba Hidraulico[Peça S Componentes] / Hydraulic Pump [Component Parts]
Linha Aspiração / Hyd Raulic Oil Line(Suction)
Tubo Oleo / Hydraulic Oil Line(Delivery)
Circuito Oleo (Direcç Ão) / Hydraulic Oil Line(Steering)
Circuito Oleo / Hydra Ulic Oil Line (F/M)
Piston Hidraulico / B Raços / Hydraulic Piston/Lift Arm
Alavanca / Feed Back Lever
Braco Hidraulico / Co Ntrol Valve
Valvula Control / Con Trol Valve [Component Parts]
Valvula Descarga / Re Lief Valve
Tirante / 3-Point Lin Kage 2(Lift Rod)
Suporte Eixo Frente / Front Axle Fr Ame
Carter Eixo / Front Axle Case
Diferencial Dianteiro / Front Diffe Rential
Grupo Conico / Differential Gear Sh Aft
Carter Grupo Conico / Bevel Gear Ca Se
Eixo Dianteiro / Front Axle
Veio / Front Drive Shaft
Braço Da Articulação / Knuckle Arm
Ligação / Drag Link
Direcção Assistida / Tie Rod
Direcção Assistida / Direção Punho / Steeri Ng Handle
Bomba Hidráulica(Ps) / Hydraulic Pump(Ps)
Bomba Hidraulico [Peças Componentes] / Hydr Aulic Pump(Ps) [Component Parts]
Ligacao Inferior / Lower Link
Ligacao Inferior / 3-Poin T Linkage 1(Lower Link)
Corrente Seguranca / Chec K Chain
Engate/Barra De Engate / Hitch/Drawbar
Proteccao Tdf / Pto Prote Ctor
Grelha Frontal / Front Grille
Acessorios / Bonnet
Painel Inferior / Panel Cover
Painel Lateral / Side Cover
Placa / Shutter Plate
Guarda Lamas / Fender
Extension Fender / Extension Fender
Haste Do Paralama / Fender Stay
Acessorios E Peças Serviço / Floor Seat
Degrau / Step
Roda Frente / Front Wheel (6-12b)
Roda Frente / Front Wheel (6-12)
Roda Frente / Front Wheel (6.00-12)
Roda Frente / Front Wheel (22*8.50-12)
Roda Frente / Front Wheel (24*8.50-12)
Roda Traseira / Rear Wheel (8-16)
Roda Traseira / Rear Wheel (9.5-16) # # Note:Order By Ref.No.220 New Part(6c190-1745-0) A Nd Ref.No.230 New Part. / Note:Order By Ref.No.220 New Part(6c190-1745-0) And Ref.No.230 New Part.
Roda Traseira / Rear Wheel (9.5-18) # # Note:Order By Ref.No.120 New Part(6c190-1745-0) A Nd Ref.No.130 New Part. / Note:Order By Ref.No.120 New Part(6c190-1745-0) And Ref.No.130 New Part.
Roda Traseira / Rear Wheel (31*13.5-1 5)
Roda Traseira / Rear Wheel (315/75d-1 5)
Etiqueta Frente / Label
Acessorios / Accesso Ries And Service Parts
Kit Alternador [Opçao] / Alternator Kit [Option]
Alternador [Peças Componentes] [Opcao] / Alterna Tor [Component Parts] [Option]
Kit Farios Trabalho (Opçao) / Working Light Kit [Option]
