Kubota Compact Tractor B2311HDB Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B2311HDB Compact Tractor
Number of Pages: 213 Pages
Itens Usados Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaft And G Overnor Shaft
Ponto Neutro / Idle Apparatus
Suporte Bico [Peças Componentes] / Nozzle Holder [ Component Parts]
Bomba Agua E Termostacto / Water Flange And Thermo Stat
Bomba Agua / Water Pump
Válvula E Veio Do Balanceiro / Valve And Rocker Ar M
Filtro Ar / Air Cleaner
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (Air Clean Er)
Escpae / Muffler
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel Filter
Filtro Gasoleo [Peças Compon Entes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel Pump
Ventoinha / Fan
Tubo Agua / Water Pipe
Deposito R Eserva / Reserve Tank
Sensor Térmico E Interrupto R Do Óleo / Oil Switch And Thermo Sensor
Valvula Solenoide / Stop So Lenoid
Alternador / Alternator
Motor Arranque / Starter
Motor Arranque [Peças Compo Nentes] / Starter [Component Parts]
Interruptor / Switch
Rele / Relay
Painel / Panel Board
Painel [Peças Componentes] / Panel Board [Component Parts]
Tampa Interruptor / Panel S Witch
Farol Frente [Exceto Uk] / Head Light [Except Uk]
Farol Frente [Uk] / Head Li Ght [Uk]
Luzes Frontais / Front Comb Ination Lamp
Braco Traseiro / Rear Combi Nation Lamp
Farol Matricula / License L Amp
Cablagem Electrica (Corpo) / Electrical Wiring (Body)
Tampa Da Caixa De Embraiagem / Clutch Housing Cover
Diferencial Dianteiro / Front Differe Ntial
Engrenagem Cónica Esquerda / Bevel Ge Ar Lh
Engrenagem Cónica Direita / Bevel Gea R Rh
Carter Grupo Conico / Bevel Gear Case
Carter Eixo Frente Esq / Front Axle C Ase Lh
Carter Eixo Frente Drt / Front Axle C Ase Rh
Eixo Dianteiro / Front Axle Lh
Veio Eixo / Front Wheel Drive Shaft
Caixa Da Transmissão / Transmission Ca Se
Diferencial Carreto / Differential Gea R Case
Carter Eixo Traseiro Esq / Rear Axle C Ase Lh
Carter Eixo Traseiro Drt / Rear Axle C Ase Rh
Hst / Hst
Hst (Caixa) [Peças Componentes] / Hst (Case) [Component Parts]
Hst (Bomba) [Peças Componentes] / Hst (Pump) [Component Parts]
Hst (Motor) [Peças Componentes] / Hst (Motor) [Component Parts]
Hst (Suporte Neutro) [Peças Componente S] / Hst (Port Block Cover) [Component Parts]
Hst (Fixador Do Neutro) [Peças Compone Ntes] / Hst (Neutral Holder) [Component Parts]
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Veio Gamas Velocidades / Range Gear Sh Aft
Inversor / Reverse Shaft
Veio Da Embraiagem Tdf / Pto Clutch Sh Aft
Tdf Central / Mid Pto
Grupo Conico / Bevel Gear Shaft
Diferencial Traseiro / Rear Differenti Al
Forqueta Velocidades / Range Gear Shift Fork
Braço De Mudança De Velocida De Tdf / Pto Gear Shift Arm
Bloqueio Diferencial De Forq Ueta / Differential Lock Shift Fork
Travão Esquerda / Brake Lh
Tirante Travao / Brake Rod
Caixa Velocidades / Speed Change Rod
Braço De Desengate Hst / Hst Release Arm
Alavanca Velocidades / Range Gear Shift Leve R
Alavanca Dupla Traccao / Front Wheel Drive L Ever
Control Velocidade / Cruise Control Lever
Cabo De Desengate Da Velocidade De Cruzeiro / Cruise Release Cable
Alavanca Control Posicao / Position Control Lever
Alavanca Da Válvula Do Carregador / Loader V Alve Lever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differential Lo Ck Pedal
Braço Bi-Speed / Bi-Speed Turn Arm
Biela Bi-Speed / Bi-Speed Shift Rod
Veio Bi-Speed Turn / Bi-Speed Turn Shaft
Pedal Inclinacao / Tilt Pedal
Cilindro Direcção [Peças Componentes] / Steer Ing Cylinder [Component Parts]
Bomba Hidraulico / Hydr Aulic Pump
Linha Aspiração (Sucção ) / Hydraulic Oil Line (Suction)
Tubo Oleo (Entrega) / H Ydraulic Pipe (Delivery)
Circuito Oleo (Direcção ) / Hydraulic Oil Line (Steering)
Tubo Oleo (Hst) / Hydra Ulic Oil Line (Hst)
Circuito Oleo (Radiador Oleo) / Hydraulic Oil Line (Oil Cooler)
Circuito Oleo (F/M) / H Ydraulic Oil Line (F/M)
Válvula Do Carregador / Loader Valve
Válvula Do Carregador [ Peças Componentes] / Loader Valve [Component Parts]
Elo Da Válvula Do Carre Gador / Loader Valve Link
Tubo Do Carregador Hidr Áulico / Hydraulic Loader Pipe
Cilindro Hidraulico / H Ydraulic Cylinder
Alavanca / Feed Back Le Ver
Valvula Control / Contr Ol Valve
Valvula Control [Peças Componentes] / Control Valve [Component Parts]
Veio De Ajuste Da Queda / Fall Adjustment Shaft
Válvula Tdf / Pto Valve
Válvula Tdf [Peças Comp Onentes] / Pto Valve [Component Parts]
3-Po Nt Acoplamento (Tirante) / Lift Rod
Liga Cao Inferior / Lower Link
Liga Cao Superior / Top Link
Corr Ente Seguranca / Check Chain
Puxo / Front Hitch
Puxo Traseiro / Rear Hitch
Prot Eccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Tampa Painel / Panel Cover
Placa / Shutter Plate
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Piso / Floor Sheet
Banco(Cobo Sc74/M91) / Seat(Cobo Sc74/M91)
Banco(Grammer Msg83/511) / Seat(Grammer Msg83 /511)
Banco(Grammer Msg93/511) / Seat(Grammer Msg93 /511)
Banco(Sears 807) / Seat(Sears 807)
Banco(Sears 830) / Seat(Sears 830)
Degrau / Step
Cobertura / Tail Cover
Caixa Ferramenta / Tool Box
Cobertura Traseira / Rear Cover
Arco / Rops
Roda Frente (7-12) / Front Wheel (7-12)
Roda Frente (24*8,50-12) / Front Wheel (24*8.50-12)
Roda Traseira (12,4-16) / Rear Wheel ( 12.4-16)
Roda Traseira (13,6-16) / Rear Wheel ( 13.6-16)
Acesso Rios E Peças Serviço / Accessories And Service Part S
Kit Luzes Trabalho [Opçao] / Working Light Kit [Op Tion]
Cilindro Elevação (Braços) [Opção] / Mower Lift Cy Linder Kit (Lift Arm) [Option]
Cilindro Elevação (Cilindro) [Opção] / Mower Lift Cylinder Kit (Cylinder) [Option]
Frente Hidráulico Tomada Kit [Opçao] / Front Hydra Ulic Outlet Kit [Option]
