Kubota Compact Tractor B2311HDB-F2 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B2311HDB-F2 Compact Tractor
Number of Pages: 252 Pages
Itens Usad Os Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Arvore Cames E Veio / Camshaft And Idle Gear Sh Aft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaft An D Governor Shaft
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Glow P Lug
Suporte Bico [Peças Componentes] / Nozzle Holde R [Component Parts]
Bomba Agua E Termostacto / Water Flange And The Rmostat
Bomba Agua / Water Pump
Válvula E Veio Do Balanceiro / Valve And Rocker Arm
Filtro Ar / Air Cleaner
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (Air Cl Eaner)
Escpae / Muffler
Deposito Combustivel / Fu El Tank
Tubo Combustivel / Fuel P Ipe
Filtro Gasoleo / Fuel Fil Ter
Filtro Gasoleo [Peças Com Ponentes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel Pump
Ventoin Ha / Fan
Tubo Ag Ua / Water Pipe
Radiado R / Radiator
Deposit O Reserva / Reserve Tank
Sensor Térmico E Interru Ptor Do Óleo / Oil Switch And Thermo Sensor
Alternador / Alternator
Alternador [Peças Compon Entes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Co Mponentes] / Starter [Component Parts]
Interruptor / Switch
Rele / Relay
Painel / Panel
Painel [Peças Componente S] / Panel Board [Component Parts]
Tampa Interruptor / Pane L Switch
Farol Frente [Ec] / Head Light [Ec]
Farol Frente [Uk] / Head Light [Uk]
Luzes Frontais / Front C Ombination Lamp
Braco Traseiro / Rear Co Mbination Lamp
Farol Matricula / Licens E Lamp
Cablagem Electrica (Corp O) / Electrical Wiring (Body)
Quadro Eixo Frente / Front Axle Fr Ame
Carter Eixo Frente / Front Axle Ca Se
Diferencial Dianteiro / Front Diff Erential
Engrenagem Cónica Esquerda / Bevel Gear Lh
Engrenagem Cónica Direita / Bevel Gear Rh
Carter Grupo Conico / Bevel Gear C Ase
Carter Eixo Frente Esq / Front Axl E Case Lh
Carter Eixo Frente Drt / Front Axl E Case Rh
Eixo Dianteiro / Front Axle Lh
Veio Eixo / Front Wheel Drive Shaf T
Caixa Da Transmissão / Transmission Case
Diferencial Carreto / Differential Gear Case
Carter Eixo Traseiro Esq / Rear Axl E Case Lh
Carter Eixo Traseiro Drt / Rear Axl E Case Rh
Hidroatático / Hst
Hst (Caixa) [Peças Componentes] / H St (Case) [Component Parts]
Hst (Bomba) [Peças Componentes] / H St (Pump) [Component Parts]
Hst (Motor) [Peças Componentes] / H St (Motor) [Component Parts]
Hst (Suporte Neutro) [Peças Compone Ntes] / Hst (Port Block Cover) [Component Parts]
Hst (Fixador Do Neutro) [Peças Comp Onentes] / Hst (Neutral Holder) [Component Parts]
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Veio Gamas Velocidades / Range Gear Shaft
Inversor / Reverse Shaft
Tdf / Veio Tdf / Pto Drive Shaft
Veio Da Embraiagem Tdf / Pto Clutch Shaft
Tdf Central / Mid Pto
Grupo Conico / Bevel Gear Shaft
Diferencial Traseiro / Rear Differe Ntial
Forqueta Velocidades / Ra Nge Gear Shift Fork
Braço De Mudança De Veloc Idade Tdf / Pto Gear Shift Arm
Bloqueio Diferencial De F Orqueta / Differential Lock Shift Fork
Eixo Traseiro Esquerda / Rear Axle L H
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao / Brake Rod
Caixa Velocidades / Speed Change Rod
Braço De Desengate Hst / Hst Release Arm
Gama Alavanca De Velocidades / Range Gear Shift Lever
Alavanca Dupla Traccao / Front Wheel Driv E Lever
Control Velocidade / Cruise Control Lever
Cabo De Desengate Da Velocidade De Cruzei Ro / Cruise Release Cable
Alavanca Control Posicao / Position Contr Ol Lever
Alavanca Da Válvula Do Carregador / Loade R Valve Lever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differential Lock Pedal
Braço Bi-Speed / Bi-Speed Turn Arm
Biela Bi-Speed / Bi-Speed Shift Rod
Veio Bi-Speed Turn / Bi-Speed Turn Shaft
Coluna Direcção / Steering Column
Pedal Inclinacao / Tilt Pedal
Cilindro Direcção [Peças Componentes] / St Eering Cylinder [Component Parts]
Bomba Hidraulico / H Ydraulic Pump
Bomba Hidraulico [Pe Ças Componentes] / Hydraulic Pump [Component Parts]
Linha Aspiração (Suc Ção) / Hydraulic Oil Line (Suction)
Tubo Oleo (Entrega) / Hydraulic Pipe (Delivery)
Circuito Oleo (Direc Ção) / Hydraulic Oil Line (Steering)
Tubo Oleo (Hst) / Hy Draulic Oil Line (Hst)
Circuito Oleo (Radia Dor Oleo) / Hydraulic Oil Line (Oil Cooler)
Circuito Oleo (F/M) / Hydraulic Oil Line (F/M)
Válvula Do Carregado R / Loader Valve
Válvula Do Carregado R [Peças Componentes] / Loader Valve [Component Par Ts]
Elo Da Válvula Do Ca Rregador / Loader Valve Link
Tubo Do Carregador H Idráulico / Hydraulic Loader Pipe
Piston Hidraulico / Braços / Hydraulic Piston/Lift Arm
Alavanca / Feed Back Lever
Valvula Control / Co Ntrol Valve
Valvula Control [Peç As Componentes] / Control Valve [Component Parts]
Veio De Ajuste Da Qu Eda / Fall Adjustment Shaft
Válvula Tdf / Pto Va Lve
Válvula Tdf [Peças C Omponentes] / Pto Valve [Component Parts]
3 -Pont Acoplamento (Tirante) / Lift Rod
L Igacao Inferior / Lower Link
L Igacao Superior / Top Link
C Orrente Seguranca / Check Chain
B Arra Reboque / Drawbar
P Uxo / Front Hitch
P Uxo Traseiro / Rear Hitch
P Roteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Painel Lateral / Side Cover
Placa / Shutter Plate
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Piso / Floor Sheet
Banco(Cobo Sc74/M91) / Seat(Cobo Sc74/M91)
Banco(Grammer Msg83/511) / Seat(Grammer Ms G83/511)
Banco(Grammer Msg93/511) / Seat(Grammer Ms G93/511)
Banco(Sears 807) / Seat(Sears 807)
Banco(Sears 830) / Seat(Sears 830)
Degrau / Step
Silenciador / Sound Absorber
Cobertura / Tail Cover
Caixa Ferramenta / Tool Box
Cobertura Traseira / Rear Cover
Arco / Rops
Roda Frente (7-12) / Front Wheel (7- 12)
Roda Traseira (12,4-16) / Rear Whee L (12.4-16)
Roda Traseira (13,6-16) / Rear Whee L (13.6-16)
Ace Ssorios E Peças Serviço / Accessories And Service P Arts
Kit Luzes Trabalho [Opçao] / Working Light Kit [Option]
Cilindro Elevação (Braços) [Opção] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cilindro Elevação (Cilindro) [Opção] / Mower Li Ft Cylinder Kit (Cylinder) [Option]
Kit Pesos Rodas [Opçao] / Front Weight Kit [Opt Ion]
Frente Hidráulico Tomada Kit [Opçao] / Front Hy Draulic Outlet Kit [Option]
Carreto / Gear Case
Escpae / Muffler
Ventoin Ha / Fan
Rele / Relay
Painel / Panel
Hidroatático / Hst
P Uxo / Front Hitch
Piso / Floor Sheet
Degrau / Step
Arco / Rops
