Kubota Compact Tractor B2261HDB-F2-S5 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B2261HDB-F2-S5 Compact Tractor
Number of Pages: 244 Pages
Itens U Sados Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel E Guia / Dipstick And Duide
Volante Motor / Flywheel
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Glo W Plug
Suporte Bico [Peças Componentes] / Nozzle Ho Lder [Component Parts]
Bomba Agua / Water Pump
Válvula E Veio Do Balanceiro / Valve And Roc Ker Arm
Filtro Ar / Air Cleaner
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (Air Cleaner)
Escpae / Muffler
Tubo Combustivel / Fue L Pipe
Filtro Gasoleo / Fuel Filter
Filtro Gasoleo [Peças Componentes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel P Ump
Vent Oinha / Fan
Tubo Agua / Water Pipe
Radi Ador / Radiator
Depo Sito Reserva / Reserve Tank
Sensor Térmico E Inte Rruptor Do Óleo / Oil Switch And Thermo Sensor
Valvula Solenoide / S Top Solenoid
Alternador / Alternat Or
Alternador [Peças Com Ponentes] / Alternator [Component Parts]
Motor Arranque / Star Ter
Motor Arranque [Peças Componentes] / Starter [Component Parts]
Interruptor / Switch
Rele / Relay
Painel / Panel
Painel [Peças Compone Ntes] / Panel Board [Component Parts]
Tampa Interruptor / P Anel Switch
Farol Frente [Ec] / H Ead Light [Ec]
Farol Frente [Uk] / H Ead Light [Uk]
Farol Frente [Saf] / Head Light [Saf]
Luzes Frontais / Fron T Combination Lamp
Braco Traseiro / Rear Combination Lamp
Farol Matricula / Lic Ense Lamp
Cablagem Electrica (C Orpo) / Electrical Wiring (Body)
Tampa Da Caixa De Embraiagem / Clutch H Ousing Cover
Suporte Principal / Center Fram E
Diferencial Dianteiro / Front D Ifferential
Engrenagem Cónica Esquerda / Be Vel Gear Lh
Engrenagem Cónica Direita / Bev El Gear Rh
Carter Grupo Conico / Bevel Gea R Case
Carter Eixo Frente Esq / Front Axle Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Eixo Dianteiro / Front Axle Lh
Caixa Da Transmissão / Transmiss Ion Case
Diferencial Carreto / Differenti Al Gear Case
Hidroatático / Hst
Hst (Caixa) [Peças Componentes] / Hst (Case) [Component Parts]
Hst (Suporte Neutro) [Peças Comp Onentes] / Hst (Port Block Cover) [Component Parts]
Hst (Fixador Do Neutro) [Peças C Omponentes] / Hst (Neutral Holder) [Component Parts ]
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Veio Gamas Velocidades / Range G Ear Shaft
Inversor / Reverse Shaft
Tdf / Veio Tdf / Pto Drive Shaft
Veio Da Embraiagem Tdf / Pto Clu Tch Shaft
Embraiagem Tdf / Pto Clutch
Tdf Central / Mid Pto
Grupo Conico / Bevel Gear Shaft
Diferencial Traseiro / Rear Diff Erential
Forqueta Velocidades / Range Gear Shift Fork
Braço De Mudança De Ve Locidade Tdf / Pto Gear Shift Arm
Bloqueio Diferencial D E Forqueta / Differential Lock Shift Fork
Eixo Traseiro Esquerda / Rear Axl E Lh
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao / Brake Rod
Caixa Velocidades / Speed Change Rod
Gama Alavanca De Velocidades / Range G Ear Shift Lever
Alavanca Dupla Traccao / Front Wheel D Rive Lever
Control Velocidade / Cruise Control Le Ver
Cabo De Desengate Da Velocidade De Cru Zeiro / Cruise Release Cable
Alavanca Control Posicao / Position Co Ntrol Lever
Alavanca Da Válvula Do Carregador / Lo Ader Valve Lever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Different Ial Lock Pedal
Braço Bi-Speed / Bi-Speed Turn Arm
Biela Bi-Speed / Bi-Speed Shift Rod
Veio Bi-Speed Turn / Bi-Speed Turn Sha Ft
Coluna Direcção / Steering Column
Pedal Inclinacao / Tilt Pedal
Cilindro Direcção [Peças Componentes] / Steering Cylinder [Component Parts]
Bomba Hidraulico [Peças Componentes] / Hydraulic Pump [Component Par Ts]
Linha Aspiração ( Sucção) / Hydraulic Oil Line (Suction)
Tubo Oleo (Entreg A) / Hydraulic Pipe (Delivery)
Circuito Oleo (Di Recção) / Hydraulic Oil Line (Steering)
Tubo Oleo (Hst) / Hydraulic Oil Line (Hst)
Circuito Oleo (Ra Diador Oleo) / Hydraulic Oil Line (Oil Cooler)
Circuito Oleo (F/ M) / Hydraulic Oil Line (F/M)
Válvula Do Carreg Ador / Loader Valve
Válvula Do Carreg Ador [Peças Componentes] / Loader Valve [Component Parts]
Elo Da Válvula Do Carregador / Loader Valve Link
Tubo Do Carregado R Hidráulico / Hydraulic Loader Pipe
Cilindro Hidrauli Co / Hydraulic Cylinder
Piston Hidraulico / Braços / Hydraulic Piston/Lift Arm
Alavanca / Feed B Ack Lever
Valvula Control [ Peças Componentes] / Control Valve [Component Parts ]
Veio De Ajuste Da Queda / Fall Adjustment Shaft
Válvula Tdf / Pto Valve
Válvula Tdf [Peça S Componentes] / Pto Valve [Component Parts]
3-Pont Acoplamento (Tirante) / Lift Rod
Ligacao Inferior / Lower Link
Corrente Seguranca / Check Chain
Barra Reboque / Drawbar
Puxo Traseiro / Rear Hitch
Proteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Tampa Painel / Panel Cover
Painel Lateral / Side Cover
Placa / Shutter Plate
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Piso / Floor Sheet
Banco(Cobo Sc74/M91) / Seat(Cobo Sc74/M 91)
Banco(Grammer Msg83/511) / Seat(Grammer Msg83/511)
Banco(Grammer Msg93/511) / Seat(Grammer Msg93/511)
Banco(Sears 807) / Seat(Sears 807)
Banco(Sears 830) / Seat(Sears 830)
Degrau / Step
Silenciador / Sound Absorber
Cobertura / Tail Cover
Caixa Ferramenta / Tool Box
Cobertura Traseira / Rear Cover
Arco / Rops
Roda Frente (5-12) / Front Wheel (5-12)
Roda Frente (6,00-12) / Front Whe El (6.00-12)
Roda Frente (22*8,50-12) / Front Wheel (22*8.50-12)
Roda Frente (24*8,50-12) / Front Wheel (24*8.50-12)
Roda Traseira (8-16) / Rear Whee L (8-16)
Roda Traseira (9,5-16) / Rear Wh Eel (9.5-16)
Roda Traseira (9,5-18) / Rear Wh Eel (9.5-18)
Roda Traseira (31*13,5-15) / Rea R Wheel (31*13.5-15)
Roda Traseira (315/75d-15) / Rea R Wheel (315/75d-15)
Acessorios E Peças Serviço / Accessories And Servic E Parts
Kit Luzes Trabalho [Opçao] / Working Light K It [Option]
Cilindro Elevação (Braços) [Opção] / Mower L Ift Cylinder Kit (Lift Arm) [Option]
Cilindro Elevação (Cilindro) [Opção] / Mower Lift Cylinder Kit (Cylinder) [Option]
Kit Pesos Rodas [Opçao] / Front Weight Kit [ Option]
Frente Hidráulico Tomada Kit [Opçao] / Front Hydraulic Outlet Kit [Option]
Carreto / Gear Case
Escpae / Muffler
Vent Oinha / Fan
Rele / Relay
Painel / Panel
Hidroatático / Hst
Piso / Floor Sheet
Degrau / Step
Arco / Rops
