Kubota Compact Tractor B2261DB-S5 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B2261DB-S5 Compact Tractor
Number of Pages: 273 Pages
Itens Usado S Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel E Guia / Dipstick And Duide
Volante Motor / Flywheel
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Glow Pl Ug
Bomba Agua / Water Pump
Válvula E Veio Do Balanceiro / Valve And Rocker Arm
Filtro Ar / Air Cleaner
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (Air Cle Aner)
Escpae / Muffler
Deposito Combustivel / Fue L Tank
Tubo Combustivel / Fuel Pi Pe
Filtro Gasoleo / Fuel Filt Er
Filtro Gasoleo [Peças Comp Onentes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel Pump
Ventoinh A / Fan
Tubo Agu A / Water Pipe
Sensor Térmico E Interrup Tor Do Óleo / Oil Switch And Thermo Sensor
Alternador [Tipo Trasero Rops] / Alternator [Rear Rops Type]
Alternador [Tipo Medio Ro Ps] / Alternator [Mid Rops Type]
Alternador [Peças Compone Ntes] [Tipo Trasero Rops] / Alternator [Component Parts] [Rear Rops Type]
Alternador [Peças Compone Ntes] [Tipo Medio Rops] / Alternator [Component Par Ts] [Mid Rops Type]
Motor Arranque / Starter
Interruptor [Tipo Medio R Ops] / Switch [Mid Rops Type]
Rele / Relay
Painel / Panel Board
Painel [Peças Componentes ] / Panel Board [Component Parts]
Tampa Interruptor / Panel Switch
Luzes Frente [Exceto Uk] / Head Light [Except Uk]
Luzes Frente [Uk] / Head Light [Uk]
Luzes Frontais [Tipo Tras Ero Rops] / Front Combination Lamp [Rear Rops Type]
Luzes Frontais [Tipo Medi O Rops] / Front Combination Lamp [Mid Rops Type]
Braco Traseiro / Rear Com Bination Lamp
Farol Matricula [Tipo Tra Sero Rops] / License Lamp [Rear Rops Type]
Farol Matricula [Tipo Med Io Rops] / License Lamp [Mid Rops Type]
Cablagem Electrica (Corpo ) [Tipo Trasero Rops] / Electrical Wiring (Body) [R Ear Rops Type]
Cablagem Electrica (Corpo ) [Tipo Medio Rops] / Electrical Wiring (Body) [Mid Rops Type]
Embraiagem / Clutch
Embraiagem / Clutch Rod
Quadro Eixo Frente / Front Axle Fra Me
Carter Eixo Frente / Front Axle Cas E
Diferencial Dianteiro / Front Diffe Rential
Engrenagem Cónica Esquerda / Bevel Gear Lh
Engrenagem Cónica Direita / Bevel G Ear Rh
Carter Grupo Conico / Bevel Gear Ca Se
Carter Eixo Frente Esq / Axle Case Lh
Carter Eixo Frente Drt / Axle Case Rh
Eixo Dianteiro Esq / Front Axle Lh
Veio Eixo / Front Wheel Drive Shaft
Caixa Da Transmissão [Tipo Trasero R Ops] / Transmission Case [Rear Rops Type]
Caixa Da Transmissão [Tipo Medio Rop S] / Transmission Case [Mid Rops Type]
Diferencial Carreto / Differential G Ear Case
Carter Eixo Traseiro Esq [Tipo Trase Ro Rops] / Rear Axle Case Lh [Rear Rops Type]
Carter Eixo Traseiro Esq [Tipo Medio Rops] / Rear Axle Case Lh [Mid Rops Type]
Carter Eixo Traseiro Drt [Tipo Trase Ro Rops] / Rear Axle Case Rh [Rear Rops Type]
Carter Eixo Traseiro Drt [Tipo Medio Rops] / Rear Axle Case Rh [Mid Rops Type]
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Engrenagem Principal / Main Gear Sha Ft
Veio Gamas Velocidades [Tipo Trasero Rops] / Range Gear Shaft [Rear Rops Type]
Veio Gamas Velocidades [Tipo Medio R Ops] / Range Gear Shaft [Mid Rops Type]
Inversor 1 / Reverse Shaft 1
Inversor 2 [Tipo Trasero Rops] / Rev Erse Shaft 2 [Rear Rops Type]
Inversor 2 [Tipo Medio Rops] / Rever Se Shaft 2 [Mid Rops Type]
Veio Inversor / Shuttle Shaft
Tdf / Veio Tdf [Tipo Trasero Rops] / Pto Drive Shaft [Rear Rops Type]
Tdf / Veio Tdf [Tipo Medio Rops] / P To Drive Shaft [Mid Rops Type]
Tdf / Veio Tdf [Tipo Trasero Rops] / Pto Gear Shift Shaft [Rear Rops Type]
Tdf / Veio Tdf [Tipo Medio Rops] / P To Gear Shift Shaft [Mid Rops Type]
Tdf Central [Tipo Trasero Rops] / Mi D Pto [Rear Rops Type]
Grupo Conico / Bevel Gear Shaft
Diferencial Traseiro / Rear Differen Tial
Forquilha Inversor / Shutt Le Shift Fork
Inversor / Shuttle Shift R Od
Forqueta Velocidades / Ran Ge Gear Shift Fork
Braço De Mudança De Veloci Dade Tdf [Tipo Trasero Rops] / Pto Gear Shift Fork [Rear Rops Type]
Braço De Mudança De Veloci Dade Tdf [Tipo Medio Rops] / Pto Gear Shift Fork [M Id Rops Type]
Braço De Mudança De Veloci Dade Tdf [Tipo Trasero Rops] / Pto Gear Shift Arm [ Rear Rops Type]
Bloqueio Diferencial De Fo Rqueta / Differential Lock Shift Fork
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao / Brake Rod
Tirante / Main Gear Shift Rod
Alavanca Velocidades / Range Gear Shift Le Ver
Alavanca Tdf [Tipo Trasero Rops] / Pto Gea R Shift Lever [Rear Rops Type]
Alavanca Tdf [Tipo Medio Rops] / Pto Gear Shift Lever [Mid Rops Type]
Alavanca Control Posicao / Position Contro L Lever
Valvula Control / Remote Control Lever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differential Lock Pedal
Braço Bi-Speed / Bi-Speed Turn Arm
Biela Bi-Speed / Bi-Speed Shift Rod
Veio Bi-Speed Turn / Bi-Speed Turn Shaft
Coluna Direcção / Steering Column
Pedal Inclinacao / Tilt Pedal
Cilindro Direcção [Peças Componentes] / Ste Ering Cylinder [Component Parts]
Bomba Hidraulico / Hy Draulic Pump
Bomba Hidraulico [Peç As Componentes] / Hydraulic Pump [Component Parts]
Linha Aspiração (Sucç Ão) / Hydraulic Oil Line (Suction)
Tubo Oleo (Entrega) / Hydraulic Pipe (Delivery)
Circuito Oleo (Direcç Ão) / Hydraulic Oil Line (Steering)
Circuito Oleo (F/M) / Hydraulic Oil Line (F/M)
Piston Hidraulico / B Raços / Hydraulic Piston/Lift Arm
Alavanca / Feed Back Lever
Valvula Control / Con Trol Valve
Valvula Control [Peça S Componentes] / Control Valve [Component Parts]
Válvula De Controlo A Uxiliar / Auxiliary Control Valve
Valvula Auxiliar [Peç As Componentes] / Remote Control Valve [Component Parts]
Veio De Ajuste Da Que Da / Fall Adjustment Shaft
Valvula Descarga / Re Lief Valve
Ti Rante / Lift Rod
Li Gacao Inferior [Tipo Medio Rops] / Lower Link [Mid Rops Type]
Li Gacao Superior / Top Link
Co Rrente Seguranca / Check Chain
Ba Rra Reboque / Drawbar
Pu Xo Dianteiro / Front Hitch
Pu Xo Traseiro [Tipo Trasero Rops] / Rear Hitch [Rear Rops Type]
Pr Oteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Tampa Painel / Panel Cover
Painel Lateral / Side Cover
Placa / Shutter Plate
Guia Esq [Tipo Trasero Rops] / Lever Guide Lh [Rear Rops Type]
Guia Esq [Tipo Medio Rops] / Lever Guide Lh [Mid Rops Type]
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Banco (Cobo Sc74/M91) / Seat (Cobo Sc74/M91 )
Banco (Grammer Msg83/511) / Seat (Grammer M Sg83/511)
Banco (Grammer Msg93/511) / Seat (Grammer M Sg93/511)
Banco (Sears 807) / Seat (Sears 807)
Banco (Sears 830) / Seat (Sears 830)
Cobertura / Tail Cover
Caixa Ferramenta / Tool Box
Cobertura Traseira [Tipo Trasero Rops] / Re Ar Cover [Rear Rops Type]
Cobertura Traseira [Tipo Medio Rops] / Rear Cover [Mid Rops Type]
Arco Seguranca 1 (Medio) / Rops 1 (Mid)
Arco Seguranca 2 (Traseiro) [Tipo Trasero R Ops] / Rops 2 (Rear) [Rear Rops Type]
Arco Seguranca 2 (Traseiro) [Tipo Medio Rop S] / Rops 2 (Rear) [Mid Rops Type]
Roda Frente (5-12) / Front Wheel (5-1 2)
Roda Frente (6-12) / Front Wheel (6-1 2)
Roda Frente (6,00-12) / Front Wheel ( 6.00-12)
Roda Frente (22*8,50-12) / Front Whee L (22*8.50-12)
Roda Frente (24*8,50-12) / Front Whee L (24*8.50-12)
Roda Traseira (8-16) / Rear Wheel (8 -16)
Roda Traseira (9,5-16) / Rear Wheel (9.5-16)
Roda Traseira (9,5-18) / Rear Wheel (9.5-18)
Roda Traseira (31*13,5-15) / Rear Wh Eel (31*13.5-15)
Roda Traseira (315/75d-15) / Rear Wh Eel (315/75d-15)
Etiqueta (Frente) [Tipo Trasero Rops] / Labe L (Front) [Rear Rops Type]
Etiqueta (Frente) [Tipo Medio Rops] / Label (Front) [Mid Rops Type]
Etiqueta (Traseira) [Tipo Trasero Rops] / La Bel (Rear) [Rear Rops Type]
Etiqueta (Traseira) [Tipo Medio Rops] / Labe L (Rear) [Mid Rops Type]
Aces Sorios E Peças Serviço / Accessories And Service Pa Rts
Kit De Carregador Dianteiro Válvula De Controlo (Válvula) [Opçao] / Front Loader Control Valve Kit (Valve) [Option]
Kit De Carregador Dianteiro Válvula De Controlo [Peças Componentes] [Opçao] / Front Loader Control Valve Kit [Component Parts] [Option]
Kit De Carregador Dianteiro Válvula De Controlo (Alavanca) [Opçao] / Front Loader Control Valve Kit (Lever) [Option]
Kit De Carregador Dianteiro Válvula De Controlo (Ligação) [Opçao] / Front Loader Control Valve Kit (Link) [Option]
Kit De Carregador Dianteiro Válvula De Controlo (Tubo 1) [Opçao] / Front Loader Control Valve Kit ( Pipe 1) [Option]
Kit De Carregador Dianteiro Válvula De Controlo (Tubo 2) [Opçao] / Front Loader Control Valve Kit ( Pipe 2) [Option]
Kit Luzes Trabalho [Tipo Trasero Rops] [Opçao] / Working Light Kit [Rear Rops Type] [Option]
Cilindro Elevação (Braços) [Opção] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cilindro Elevação (Cilindro) [Opção] / Mower Lif T Cylinder Kit (Cylinder) [Option]
Cilindro Elevação (Braco Hidraulico) [Opçao] / M Ower Lift Cylinder Kit (Cylinder) [Option]
Kit Pesos Rodas [Opção] / Front Weight Kit [Opti On]
Frente Hidráulico Tomada Kit [Opção] / Front Hyd Raulic Outlet Kit [Option]
