Kubota Compact Tractor B2231HDBC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B2231HDBC Compact Tractor
Number of Pages: 266 Pages
Itens Usados Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Arvore Cames E Veio / Camshaft And Idle Gear Shaf T
Volante Motor / Flywheel
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Glow Plu G
Bomba Agua E Termostacto / Water Flange And Therm Ostat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (Air Clea Ner)
Escpae / Muffler
Tubo Combustivel / Fuel Pip E
Filtro Gasoleo / Fuel Filte R
Filtro Gasoleo [Peças Compo Nentes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel Pump
Tubo Agua / Water Pipe
Sensor Térmico / Thermo Se Nsor
Valvula Solenoide / Stop S Olenoid
Alternador / Alternator
Alternador [Peças Componen Tes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Comp Onentes] / Starter [Component Parts]
Interruptor / Switch
Rele / Relay
Painel / Panel Board
Tampa Interruptor / Panel Switch
Luzes Frente [Exceto Uk] / Head Light [Except Uk]
Luzes Frente [Uk] / Head L Ight [Uk]
Luzes Frontais / Front Com Bination Lamp
Braco Traseiro / Rear Comb Ination Lamp
Luzes Trabalho / Working L Ight
Luz Interior / Room Light
Painel Controlo Air Condic Ionado/Relé / Air-Con.Control Panel/Relay
Antena/Coluna / Antenna/Sp Eaker
Depósito De Lavagem / Wash Er Tank
Limpa-Pára-Brisas (Diantei Ro) / Wiper (Front)
Cablagem Electrica (Corpo) / Electrical Wiring (Body)
Cablagem Electrica (Cabine ) / Electrical Wiring (Cab)
Tampa Da Caixa De Embraiagem / Clutch Housin G Cover
Quadro Eixo Frente / Front Axle Fram E
Diferencial Dianteiro / Front Differ Ential
Engrenagem Cónica Esquerda / Bevel G Ear Lh
Engrenagem Cónica Direita / Bevel Ge Ar Rh
Carter Grupo Conico / Bevel Gear Cas E
Carter Eixo Frente Esq / Front Axle Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Eixo Dianteiro Esq / Front Axle Lh
Caixa Da Transmissão / Transmission C Ase
Diferencial Carreto / Differential Ge Ar Case
Hst / Hst
Hst (Caixa) [Peças Componentes] / Hst (Case) [Component Parts]
Hst (Bomba) [Peças Componentes] / Hst (Pump) [Component Parts]
Hst (Motor) [Peças Componentes] / Hst (Motor) [Component Parts]
Hst (Tampa Do Bloco De Abertura) [Peç As Componentes] / Hst (Port Block Cover) [Component Parts]
Hst (Fixador Do Neutro) [Peças Compon Entes] / Hst (Neutral Holder) [Component Parts]
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Veio Gamas Velocidades / Range Gear S Haft
Inversor / Reverse Shaft
Tdf / Veio Tdf / Pto Drive Shaft
Veio Da Embraiagem Tdf / Pto Clutch S Haft
Tdf Central / Mid Pto
Grupo Conico / Bevel Gear Shaft
Diferencial Traseiro / Rear Different Ial
Forqueta Velocidades / Rang E Gear Shift Fork
Braço De Mudança De Velocid Ade Tdf / Pto Gear Shift Arm
Bloqueio Diferencial De For Queta / Differential Lock Shift Fork
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao (Dianteiro) / Brake Rod (Front)
Tirante Travao (Traseira) / Brake Rod (Rear)
Caixa Velocidades / Speed Change Rod
Alavanca Velocidades / Range Gear Shift Lev Er
Control Velocidade / Cruise Control Lever
Cabo De Desengate Da Velocidade De Cruzeiro / Cruise Release Cable
Alavanca Control Posicao / Position Control Lever
Alavanca Da Válvula Do Carregador / Loader Valve Lever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differential L Ock Pedal
Braço Bi-Speed / Bi-Speed Turn Arm
Biela Bi-Speed / Bi-Speed Shift Rod
Veio Bi-Speed Turn / Bi-Speed Turn Shaft
Coluna Direcção / Steering Column
Pedal Inclinacao / Tilt Pedal
Cilindro Direcção [Peças Componentes] / Stee Ring Cylinder [Component Parts]
Bomba Hidraulico / Hyd Raulic Pump
Bomba Hidraulico [Peça S Componentes] / Hydraulic Pump [Component Parts]
Circuito Oleo (Sucção) / Hydraulic Oil Line (Suction)
Circuito Oleo (Entrega ) / Hydraulic Pipe (Delivery)
Circuito Oleo (Direcçã O) / Hydraulic Oil Line (Steering)
Circuito Oleo (Hst) / Hydraulic Oil Line (Hst)
Circuito Oleo (Radiado R Oleo) / Hydraulic Oil Line (Oil Cooler)
Circuito Oleo (F/M) / Hydraulic Oil Line (F/M)
Válvula Do Carregador [Peças Componentes] / Loader Valve [Component Parts ]
Elo Da Válvula Do Carr Egador / Loader Valve Link
Tubo Do Carregador Hid Ráulico / Hydraulic Loader Pipe
Piston Hidraulico / Br Aços / Hydraulic Piston/Lift Arm
Alavanca / Feed Back L Ever
Valvula Control / Cont Rol Valve
Valvula Control [Peças Componentes] / Control Valve [Component Parts]
Veio De Ajuste Da Qued A / Fall Adjustment Shaft
Válvula Tdf / Pto Valv E
Válvula Tdf [Peças Com Ponentes] / Pto Valve [Component Parts]
Tir Ante / Lift Rod
Lig Acao Inferior / Lower Link
Lig Acao Superior / Top Link
Cor Rente Seguranca / Check Chain
Bar Ra Reboque / Drawbar
Pux O Dianteiro / Front Hitch
Pux O Traseiro / Rear Hitch
Pro Teccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Painel Lateral / Side Cover
Placa / Shutter Plate
Banco (Grammer Msg83/511) / Seat (Grammer Ms G83/511)
Banco (Grammer Msg93/511) / Seat (Grammer Ms G93/511)
Banco (Sears 807) / Seat (Sears 807)
Banco (Sears 830) / Seat (Sears 830)
Estrutura Cabine / Cab Frame
Painel Inferior / Panel Cover
Assento Por Baixo Da Cobertura / Seat Under Cover
Guarda Lamas / Over Fender
Cobertura / Tail Cover
Porta Esq / Door Lh
Porta Drt / Door Rh
Tejadilho Interior / Inner Roof
Tecto Abrir / Outer Roof
Dianteira Do Suporte Da Cabine / Cab Bracket Front
Traseira Do Suporte Da Cabine / Cab Bracket Rear
Tapete Do Piso / Floor Mat
Silenciador / Sound Absorber
Cobertura Interior / Interior Cover
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Vidro Frente / Front Glass
Vidro Traseiro Da Escotilha / Hatch Back Glass
Dobradiça Do Vidro Traseiro Da Escotilha / Hatch Ba Ck Glass Hinge
Ar Condicionado / Air Conditio Ner
Tubo (Ar Condicionado) / Drain Hose (Air Conditioner)
Condesador / Condenser
Tubo Do Ar Condicionado / Air Conditioner Pipe
Compressor / Air Compressor
Tubo Ar Condicionado / Air Con Ditioner Duct
Roda Frente (5-12) / Front Wheel (5-12 )
Roda Frente (6-12) / Front Wheel (6-12 )
Roda Frente (6,00-12) / Front Wheel (6 .00-12)
Roda Frente (22*8,50-12) / Front Wheel (22*8.50-12)
Roda Frente (24*8,50-12) / Front Wheel (24*8.50-12)
Roda Traseira (8-16) / Rear Wheel (8- 16)
Roda Traseira (9,5-16) / Rear Wheel ( 9.5-16)
Roda Traseira (31*13,5-15) / Rear Whe El (31*13.5-15)
Roda Traseira (315/75d-15) / Rear Whe El (315/75d-15)
Acess Orios E Peças Serviço / Accessories And Service Par Ts
Kit Luzes Trabalho (Traseira) [Opção] / Working L Ight Kit (Rear) [Option]
Kit Limpa Vidro Traseiros [Opção] / Rear Wiper Ki T [Option]
Cilindro Elevação (Braços) [Opção] / Mower Lift C Ylinder Kit (Lift Arm) [Option]
Cilindro Elevação (Cilindro) [Opção] / Mower Lift Cylinder Kit (Cylinder) [Option]
Kit Pesos Rodas [Opção] / Front Weight Kit [Optio N]
Distribuidor Auxiliar [Opção] / Auxiliary Control Valve [Option]
Kit Valvula Control Auxiliar [Peças Componentes] [Opção] / Auxiliary Control Valve [Component Parts] [Option]
Alavanca Da Válvula De Controlo Auxiliar (1º) [Op Ção] / Auxiliary Control Valve Lever Kit (1st) [Opt Ion]
Alavanca Da Válvula De Controlo Auxiliar (2º) [Op Ção] / Auxiliary Control Valve Lever Kit (2nd) [Opt Ion]
Acoplador Da Válvula De Controlo Auxiliar (2º) [O Pção] / Auxiliary Control Valve Coupler (2nd) [Opti On]
