Kubota Compact Tractor B2231HDBC-S5 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B2231HDBC-S5 Compact Tractor
Number of Pages: 288 Pages
Itens Usa Dos Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Arvore Cames E Veio / Camshaft And Idle Gear S Haft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaft A Nd Governor Shaft
Ponto Neutro / Idle Apparatus
Suporte Bico [Peças Componentes] / Nozzle Hold Er [Component Parts]
Bomba Agua E Termostacto / Water Flange And Th Ermostat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (Air C Leaner)
Escpae / Muffler
Deposito Combustivel / F Uel Tank
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel Fi Lter
Filtro Gasoleo [Peças Co Mponentes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel Pum P
Ventoi Nha / Fan
Tubo A Gua / Water Pipe
Radiad Or / Radiator
Deposi To Reserva / Reserve Tank
Sensor Térmico / Thermo Sensor
Valvula Solenoide / Sto P Solenoid
Alternador / Alternator
Alternador [Peças Compo Nentes] / Alternator [Component Parts]
Motor Arranque / Starte R
Motor Arranque [Peças C Omponentes] / Starter [Component Parts]
Interruptor / Switch
Rele / Relay
Painel / Panel Board
Tampa Interruptor / Pan El Switch
Luzes Frente [Exceto Uk ] / Head Light [Except Uk]
Luzes Frente [Uk] / Hea D Light [Uk]
Luzes Frontais / Front Combination Lamp
Braco Traseiro / Rear C Ombination Lamp
Farol Matricula / Licen Se Lamp
Luzes Trabalho / Workin G Light
Luz Interior / Room Lig Ht
Painel Controlo Air Con Dicionado/Relé / Air-Con.Control Panel/Relay
Antena/Coluna / Antenna /Speaker
Depósito De Lavagem / W Asher Tank
Limpa-Pára-Brisas (Dian Teiro) / Wiper (Front)
Cablagem Electrica (Cor Po) / Electrical Wiring (Body)
Cablagem Electrica (Cab Ine) / Electrical Wiring (Cab)
Tampa Da Caixa De Embraiagem / Clutch Hou Sing Cover
Quadro Eixo Frente / Front Axle F Rame
Carter Eixo Frente / Front Axle C Ase
Diferencial Dianteiro / Front Dif Ferential
Engrenagem Cónica Esquerda / Beve L Gear Lh
Engrenagem Cónica Direita / Bevel Gear Rh
Carter Grupo Conico / Bevel Gear Case
Carter Eixo Frente Esq / Front Ax Le Case Lh
Carter Eixo Frente Drt / Front Ax Le Case Rh
Eixo Dianteiro Esq / Front Axle L H
Veio Eixo / Front Wheel Drive Sha Ft
Caixa Da Transmissão / Transmissio N Case
Diferencial Carreto / Differential Gear Case
Carter Eixo Traseiro Esq / Rear Ax Le Case Lh
Carter Eixo Traseiro Drt / Rear Ax Le Case Rh
Hst / Hst
Hst (Caixa) [Peças Componentes] / Hst (Case) [Component Parts]
Hst (Bomba) [Peças Componentes] / Hst (Pump) [Component Parts]
Hst (Motor) [Peças Componentes] / Hst (Motor) [Component Parts]
Hst (Tampa Do Bloco De Abertura) [ Peças Componentes] / Hst (Port Block Cover) [Compon Ent Parts]
Hst (Fixador Do Neutro) [Peças Com Ponentes] / Hst (Neutral Holder) [Component Parts]
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Veio Gamas Velocidades / Range Gea R Shaft
Inversor / Reverse Shaft
Tdf / Veio Tdf / Pto Drive Shaft # # Note:Order By Ref.No.010,030,090 And Fig.No.D2220 0 Ref.No.100 New Parts. / Note:Order By Ref.No.010, 030,090 And Fig.No.D22200 Ref.No.100 New Parts.
Veio Da Embraiagem Tdf / Pto Clutc H Shaft
Embraiagem Tdf / Pto Clutch
Tdf Central / Mid Pto
Grupo Conico / Bevel Gear Shaft
Diferencial Traseiro / Rear Differ Ential
Forqueta Velocidades / R Ange Gear Shift Fork
Braço De Mudança De Velo Cidade Tdf / Pto Gear Shift Arm
Bloqueio Diferencial De Forqueta / Differential Lock Shift Fork
Eixo Traseiro Direita / Rear Axle R H
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao (Dianteiro) / Brake Rod (Front)
Tirante Travao (Traseira) / Brake Rod (Rear)
Caixa Velocidades / Speed Change Rod
Alavanca Velocidades / Range Gear Shift Lever
Alavanca Dupla Traccao / Front Wheel Dri Ve Lever
Control Velocidade / Cruise Control Leve R
Cabo De Desengate Da Velocidade De Cruze Iro / Cruise Release Cable
Alavanca Control Posicao / Position Cont Rol Lever
Alavanca Da Válvula Do Carregador / Load Er Valve Lever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differentia L Lock Pedal
Braço Bi-Speed / Bi-Speed Turn Arm
Biela Bi-Speed / Bi-Speed Shift Rod
Veio Bi-Speed Turn / Bi-Speed Turn Shaft
Coluna Direcção / Steering Column
Pedal Inclinacao / Tilt Pedal
Cilindro Direcção [Peças Componentes] / S Teering Cylinder [Component Parts]
Bomba Hidraulico [P Eças Componentes] / Hydraulic Pump [Component Parts ]
Circuito Oleo (Sucç Ão) / Hydraulic Oil Line (Suction)
Circuito Oleo (Entr Ega) / Hydraulic Pipe (Delivery)
Circuito Oleo (Dire Cção) / Hydraulic Oil Line (Steering)
Circuito Oleo (Hst) / Hydraulic Oil Line (Hst)
Circuito Oleo (Radi Ador Oleo) / Hydraulic Oil Line (Oil Cooler)
Circuito Oleo (F/M) / Hydraulic Oil Line (F/M)
Válvula Do Carregad Or / Loader Valve
Válvula Do Carregad Or [Peças Componentes] / Loader Valve [Component Pa Rts]
Tubo Do Carregador Hidráulico / Hydraulic Loader Pipe
Piston Hidraulico / Braços / Hydraulic Piston/Lift Arm
Alavanca / Feed Bac K Lever
Valvula Control [Pe Ças Componentes] / Control Valve [Component Parts]
Veio De Ajuste Da Q Ueda / Fall Adjustment Shaft
Válvula Tdf / Pto V Alve
Válvula Tdf [Peças Componentes] / Pto Valve [Component Parts]
Tirante / Lift Rod
Ligacao Inferior / Lower Link
Ligacao Superior / Top Link
Corrente Seguranca / Check Chain
Barra Reboque / Drawbar
Puxo Dianteiro / Front Hitch
Puxo Traseiro / Rear Hitch
Proteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Painel Lateral / Side Cover
Placa / Shutter Plate
Banco (Grammer Msg83/511) / Seat (Grammer Msg83/511)
Banco (Grammer Msg93/511) / Seat (Grammer Msg93/511)
Banco (Sears 807) / Seat (Sears 807)
Banco (Sears 830) / Seat (Sears 830)
Estrutura Cabine / Cab Frame
Painel Inferior / Panel Cover
Assento Por Baixo Da Cobertura / Seat Under Cove R
Guarda Lamas / Over Fender
Cobertura / Tail Cover
Porta Esq / Door Lh
Porta Drt / Door Rh
Tejadilho Interior / Inner Roof
Tecto Abrir / Outer Roof
Dianteira Do Suporte Da Cabine / Cab Bracket Fro Nt
Traseira Do Suporte Da Cabine / Cab Bracket Rear
Tapete Do Piso / Floor Mat
Silenciador / Sound Absorber
Cobertura Interior / Interior Cover
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Vidro Frente / Front Glass
Vidro Traseiro Da Escotilha / Hatch Back Glass
Dobradiça Do Vidro Traseiro Da Escotilha / Hatch Back Glass Hinge
Ar Condicionado / Air Condi Tioner
Tubo (Ar Condicionado) / Dr Ain Hose (Air Conditioner)
Condesador / Condenser
Tubo Do Ar Condicionado / A Ir Conditioner Pipe
Tubo Aquecimento / Heater H Ose
Compressor / Air Compressor
Tubo Ar Condicionado / Air Conditioner Duct
Roda Frente (6,00-12) / Front Wheel (6.00-12)
Roda Frente (22*8,50-12) / Front Wh Eel (22*8.50-12)
Roda Traseira (8-16) / Rear Wheel (8-16)
Roda Traseira (9,5-16) / Rear Whee L (9.5-16)
Roda Traseira (9,5-18) / Rear Whee L (9.5-18)
Roda Traseira (31*13,5-15) / Rear Wheel (31*13.5-15)
Roda Traseira (315/75d-15) / Rear Wheel (315/75d-15)
Mc Osstrits O /Oems Sorniet G Mccosstrios M0d Sornico /Mras
Kit Luzes Trabalho (Traseira) [Opção] / Workin G Light Kit (Rear) [Option]
Kit Limpa Vidro Traseiros [Opção] / Rear Wiper Kit [Option]
Cilindro Elevação (Braços) [Opção] / Mower Lif T Cylinder Kit (Lift Arm) [Option]
Cilindro Elevação (Cilindro) [Opção] / Mower L Ift Cylinder Kit (Cylinder) [Option]
Kit Pesos Rodas [Opção] / Front Weight Kit [Op Tion]
Distribuidor Auxiliar [Opção] / Auxiliary Cont Rol Valve [Option]
Kit Valvula Control Auxiliar [Peças Componente S] [Opção] / Auxiliary Control Valve [Component Par Ts] [Option]
Alavanca Da Válvula De Controlo Auxiliar (1º) [Opção] / Auxiliary Control Valve Lever Kit (1st) [ Option]
Alavanca Da Válvula De Controlo Auxiliar (2º) [Opção] / Auxiliary Control Valve Lever Kit (2nd) [ Option]
Acoplador Da Válvula De Controlo Auxiliar (1º) [Opção] / Auxiliary Control Valve Coupler (1st) [O Ption]
Acoplador Da Válvula De Controlo Auxiliar (2º) [Opção] / Auxiliary Control Valve Coupler (2nd) [O Ption]
Frente Hidráulico Tomada Kit [Opção] / Front H Ydraulic Outlet Kit [Option]
Carreto / Gear Case
Escpae / Muffler
Ventoi Nha / Fan
Rele / Relay
Hst / Hst
Tirante / Lift Rod
Porta Esq / Door Lh
Porta Drt / Door Rh
