Kubota Compact Tractor B2231DB Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B2231DB Compact Tractor
Number of Pages: 238 Pages
Itens Usados F Requentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaft And Go Vernor Shaft
Ponto Neutro / Idle Apparatus
Suporte Bico [Peças Componentes] / Nozzle Holder [C Omponent Parts]
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (Air Cleane R)
Escpae / Muffler
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel Filter
Filtro Gasoleo [Peças Compone Ntes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel Pump
Ventoinha / Fan
Tubo Agua / Water Pipe
Deposito Re Serva / Reserve Tank
Sensor Térmico E Interruptor Do Óleo / Oil Switch And Thermo Sensor
Valvula Solenoide / Stop Sol Enoid
Alternador [Tipo Trasero Rop S] / Alternator [Rear Rops Type]
Alternador [Peças Componente S] [Tipo Trasero Rops] / Alternator [Component Part S] [Rear Rops Type]
Motor Arranque / Starter
Motor Arranque [Peças Compon Entes] / Starter [Component Parts]
Interruptor [Tipo Trasero Ro Ps] / Switch [Rear Rops Type]
Rele / Relay
Painel / Panel Board
Painel [Peças Componentes] / Panel Board [Component Parts]
Tampa Interruptor / Panel Sw Itch
Luzes Frente [Exceto Uk] / H Ead Light [Except Uk]
Luzes Frente [Uk] / Head Lig Ht [Uk]
Luzes Frontais [Tipo Trasero Rops] / Front Combination Lamp [Rear Rops Type]
Braco Traseiro / Rear Combin Ation Lamp
Farol Matricula [Tipo Traser O Rops] / License Lamp [Rear Rops Type]
Cablagem Electrica (Corpo) [ Tipo Trasero Rops] / Electrical Wiring (Body) [Rear Rops Type]
Embraiagem / Clutch Rod
Diferencial Dianteiro / Front Differen Tial
Engrenagem Cónica Direita / Bevel Gear Rh
Carter Grupo Conico / Bevel Gear Case
Carter Eixo Frente Esq / Axle Case Lh
Carter Eixo Frente Drt / Axle Case Rh
Eixo Dianteiro Esq / Front Axle Lh
Veio Eixo / Front Wheel Drive Shaft
Caixa Da Transmissão [Tipo Trasero Rops ] / Transmission Case [Rear Rops Type]
Diferencial Carreto / Differential Gear Case
Carter Eixo Traseiro Esq [Tipo Trasero Rops] / Rear Axle Case Lh [Rear Rops Type]
Carter Eixo Traseiro Drt [Tipo Trasero Rops] / Rear Axle Case Rh [Rear Rops Type]
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Engrenagem Principal / Main Gear Shaft
Veio Gamas Velocidades [Tipo Trasero Ro Ps] / Range Gear Shaft [Rear Rops Type]
Inversor 1 / Reverse Shaft 1
Inversor 2 [Tipo Trasero Rops] / Revers E Shaft 2 [Rear Rops Type]
Veio Inversor / Shuttle Shaft
Tdf / Veio Tdf [Tipo Trasero Rops] / Pt O Drive Shaft [Rear Rops Type]
Tdf / Veio Tdf [Tipo Trasero Rops] / Pt O Gear Shift Shaft [Rear Rops Type]
Tdf Central [Tipo Trasero Rops] / Mid P To [Rear Rops Type]
Grupo Conico / Bevel Gear Shaft
Diferencial Traseiro / Rear Differentia L
Forqueta / Main Gear Shift Fo Rk
Forquilha Inversor / Shuttle Shift Fork
Inversor / Shuttle Shift Rod
Forqueta Velocidades / Range Gear Shift Fork
Braço De Mudança De Velocidad E Tdf / Pto Gear Shift Fork
Braço De Mudança De Velocidad E Tdf [Tipo Trasero Rops] / Pto Gear Shift Arm [Rea R Rops Type]
Bloqueio Diferencial De Forqu Eta / Differential Lock Shift Fork
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante / Main Gear Shift Rod
Alavanca Velocidades / Range Gear Shift Lever
Alavanca Dupla Traccao / Front Wheel Drive Le Ver
Alavanca Control Posicao / Position Control L Ever
Valvula Control / Remote Control Lever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differential Loc K Pedal
Braço Bi-Speed / Bi-Speed Turn Arm
Biela Bi-Speed / Bi-Speed Shift Rod
Veio Bi-Speed Turn / Bi-Speed Turn Shaft
Coluna Direcção / Steering Column
Pedal Inclinacao / Tilt Pedal
Cilindro Direcção [Peças Componentes] / Steeri Ng Cylinder [Component Parts]
Bomba Hidraulico / Hydra Ulic Pump
Linha Aspiração (Sucção) / Hydraulic Oil Line (Suction)
Tubo Oleo (Entrega) / Hy Draulic Pipe (Delivery)
Circuito Oleo (Direcção) / Hydraulic Oil Line (Steering)
Circuito Oleo (F/M) / Hy Draulic Oil Line (F/M)
Cilindro Hidraulico / Hy Draulic Cylinder
Piston Hidraulico / Braç Os / Hydraulic Piston/Lift Arm
Alavanca / Feed Back Lev Er
Valvula Control / Contro L Valve
Valvula Control [Peças C Omponentes] / Control Valve [Component Parts]
Válvula De Controlo Auxi Liar / Auxiliary Control Valve
Valvula Auxiliar [Peças Componentes] / Remote Control Valve [Component Part S]
Veio De Ajuste Da Queda / Fall Adjustment Shaft
Valvula Descarga / Relie F Valve
Tiran Te / Lift Rod
Ligac Ao Inferior [Tipo Trasero Rops] / Link,Lower [Rear Rops Type]
Ligac Ao Superior / Top Link
Corre Nte Seguranca / Check Chain
Barra Reboque / Drawbar
Puxo Dianteiro / Front Hitch
Puxo Traseiro [Tipo Trasero Rops] / Rear Hitch [Rear Rop S Type]
Prote Ccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Tampa Painel / Panel Cover
Painel Lateral / Side Cover
Placa / Shutter Plate
Guia Esq [Tipo Trasero Rops] / Lever Guide Lh [Rear Rops Type]
Guia Drt / Lever Guide Rh
Banco (Cobo Sc74/M91) / Seat (Cobo Sc74/M91)
Banco (Grammer Msg83/511) / Seat (Grammer Msg8 3/511)
Banco (Grammer Msg93/511) / Seat (Grammer Msg9 3/511)
Banco (Sears 807) / Seat (Sears 807)
Banco (Sears 830) / Seat (Sears 830)
Degrau / Step
Cobertura / Tail Cover
Caixa Ferramenta / Tool Box
Cobertura Traseira [Tipo Trasero Rops] / Rear Cover [Rear Rops Type]
Arco Seguranca 2 (Traseiro) [Tipo Trasero Rops ] / Rops 2 (Rear) [Rear Rops Type]
Roda Frente (5-12) / Front Wheel (5-12)
Roda Frente (6-12) / Front Wheel (6-12)
Roda Frente (22*8,50-12) / Front Wheel ( 22*8.50-12)
Roda Frente (24*8,50-12) / Front Wheel ( 24*8.50-12)
Roda Traseira (8-16) / Rear Wheel (8-16 )
Roda Traseira (9,5-16) / Rear Wheel (9. 5-16)
Roda Traseira (9,5-18) / Rear Wheel (9. 5-18)
Roda Traseira (31*13,5-15) / Rear Wheel (31*13.5-15)
Roda Traseira (315/75d-15) / Rear Wheel (315/75d-15)
Etiqueta (Frente) [Tipo Trasero Rops] / Label ( Front) [Rear Rops Type]
Etiqueta (Traseira) [Tipo Trasero Rops] / Label (Rear) [Rear Rops Type]
Acessor Ios E Peças Serviço / Accessories And Service Parts
Kit De Carregador Dianteiro Válvula De Controlo (Vá Lvula) [Opçao] / Front Loader Control Valve Kit (Va Lve) [Option]
Kit De Carregador Dianteiro Válvula De Controlo [Pe Ças Componentes] [Opçao] / Front Loader Control Val Ve Kit [Component Parts] [Option]
Kit De Carregador Dianteiro Válvula De Controlo (Al Avanca) [Opçao] / Front Loader Control Valve Kit (L Ever) [Option]
Kit De Carregador Dianteiro Válvula De Controlo (Li Gação) [Opçao] / Front Loader Control Valve Kit (Li Nk) [Option]
Kit De Carregador Dianteiro Válvula De Controlo (Tu Bo 1) [Opçao] / Front Loader Control Valve Kit (Pip E 1) [Option]
Kit De Carregador Dianteiro Válvula De Controlo (Tu Bo 2) [Opçao] / Front Loader Control Valve Kit (Pip E 2) [Option]
Kit Luzes Trabalho [Tipo Trasero Rops] [Opçao] / Wo Rking Light Kit [Rear Rops Type] [Option]
Cilindro Elevação (Braços) [Opção] / Mower Lift Cyl Inder Kit (Lift Arm) [Option]
Cilindro Elevação (Cilindro) [Opção] / Mower Lift C Ylinder Kit (Cylinder) [Option]
Cilindro Elevação (Braco Hidraulico) [Opçao] / Mowe R Lift Cylinder Kit (Cylinder) [Option]
Kit Pesos Rodas [Opção] / Front Weight Kit [Option]
Frente Hidráulico Tomada Kit [Opção] / Front Hydrau Lic Outlet Kit [Option]
