Kubota Compact Tractor B2201D Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B2201D Compact Tractor
Number of Pages: 232 Pages
Itens Usados Fr Equentemente / Frequently Used Items
B Loco Motor / Crankcase
C Arter Oleo / Oil Pan
C Abeça Motor / Cylinder Head
C Arreto / Gear Case
T Ampa Cabeça / Head Cover
V Areta Nivel E Guia / Dipstick And Guide
R Olamento Principal / Main Bearing Case
P Iston E Cambota / Piston And Crankshaft
V Olante Motor / Flywheel
V Eio Combustivel E Regulador / Fuel Camshaft And Gov Ernor Shaft
P Onto Neutro / Idle Apparatus
B Omba Injectora / Injection Pump
R Egulador / Governor
R Egulador Velocidade / Speed Control Plate
S Uporte Bico [Peças Componentes] / Nozzle Holder [Co Mponent Parts]
B Omba Agua / Water Pump
V Alvula E Veio Martelos / Valve And Rocker Arm
C Olector Escape / Exhaust Manifold
F Iltro Ar / Air Cleaner
T Ubo Aspiracao (Filtro Ar) / Inlet Pipe (Air Cleaner )
E Scpae / Muffler
K It Juntas Superior / Upper Gasket Kit
K It Juntas Inferior / Lower Gasket Kit
A Celarador Mao / Accelerator Lever
P Edal Acelarador / Accelerator Pedal
Deposito Combustivel / Fuel Ta Nk
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel Filter
Filtro Gasoleo [Peças Componen Tes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel Pump
Ventoinha / Fan
Tubo Agua / Water Pipe
Radiador / R Adiator
Valvula Solenoide / Stop Sole Noid
Alternador [Tipo Trasero Rops ] / Alternator [Rear Rops Type]
Alternador [Tipo Medio Rops] / Alternator [Mid Rops Type]
Alternador [Peças Componentes ] [Tipo Trasero Rops] / Alternator [Component Parts ] [Rear Rops Type]
Alternador [Peças Componentes ] [Tipo Medio Rops] / Alternator [Component Parts] [Mid Rops Type]
Motor Arranque / Starter
Interruptor [Tipo Trasero Rop S] / Switch [Rear Rops Type]
Interruptor [Tipo Medio Rops] / Switch [Mid Rops Type]
Rele / Relay
Painel / Panel Board
Painel [Peças Componentes] / Panel Board [Component Parts]
Tampa Interruptor / Panel Swi Tch
Luzes Frente [Exceto Uk] / He Ad Light [Except Uk]
Luzes Frente [Uk] / Head Ligh T [Uk]
Luzes Frontais [Tipo Trasero Rops] / Front Combination Lamp [Rear Rops Type]
Luzes Frontais [Tipo Medio Ro Ps] / Front Combination Lamp [Mid Rops Type]
Braco Traseiro / Rear Combina Tion Lamp
Farol Matricula [Tipo Trasero Rops] / License Lamp [Rear Rops Type]
Farol Matricula [Tipo Medio R Ops] / License Lamp [Mid Rops Type]
Cablagem Electrica (Corpo) [T Ipo Trasero Rops] / Electrical Wiring (Body) [Rear Rops Type]
Cablagem Electrica (Corpo) [T Ipo Medio Rops] / Electrical Wiring (Body) [Mid Rop S Type]
Embraiagem / Clutch
Embraiagem / Clutch Rod
Diferencial Dianteiro / Front Different Ial
Engrenagem Cónica Esquerda / Bevel Gear Lh
Engrenagem Cónica Direita / Bevel Gear Rh
Carter Eixo Frente Esq / Axle Case Lh
Carter Eixo Frente Drt / Axle Case Rh
Eixo Dianteiro Esq / Front Axle Lh
Veio Eixo / Front Wheel Drive Shaft
Caixa Da Transmissão [Tipo Trasero Rops] / Transmission Case [Rear Rops Type]
Caixa Da Transmissão [Tipo Medio Rops] / Transmission Case [Mid Rops Type]
Diferencial Carreto / Differential Gear Case
Carter Eixo Traseiro Esq [Tipo Trasero R Ops] / Rear Axle Case Lh [Rear Rops Type]
Carter Eixo Traseiro Esq [Tipo Medio Rop S] / Rear Axle Case Lh [Mid Rops Type]
Carter Eixo Traseiro Drt [Tipo Trasero R Ops] / Rear Axle Case Rh [Rear Rops Type]
Carter Eixo Traseiro Drt [Tipo Medio Rop S] / Rear Axle Case Rh [Mid Rops Type]
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Engrenagem Principal / Main Gear Shaft
Veio Gamas Velocidades [Tipo Trasero Rop S] / Range Gear Shaft [Rear Rops Type]
Veio Gamas Velocidades [Tipo Medio Rops] / Range Gear Shaft [Mid Rops Type]
Inversor 1 / Reverse Shaft 1
Inversor 2 [Tipo Trasero Rops] / Reverse Shaft 2 [Rear Rops Type]
Inversor 2 [Tipo Medio Rops] / Reverse S Haft 2 [Mid Rops Type]
Veio Inversor / Shuttle Shaft
Tdf / Veio Tdf [Tipo Trasero Rops] / Pto Drive Shaft [Rear Rops Type]
Tdf / Veio Tdf [Tipo Medio Rops] / Pto D Rive Shaft [Mid Rops Type]
Tdf / Veio Tdf [Tipo Trasero Rops] / Pto Gear Shift Shaft [Rear Rops Type]
Tdf / Veio Tdf [Tipo Medio Rops] / Pto G Ear Shift Shaft [Mid Rops Type]
Tdf Central [Tipo Trasero Rops] / Mid Pt O [Rear Rops Type]
Grupo Conico / Bevel Gear Shaft
Forqueta / Main Gear Shift For K
Forquilha Inversor / Shuttle S Hift Fork
Forqueta Velocidades / Range G Ear Shift Fork
Braço De Mudança De Velocidade Tdf / Pto Gear Shift Fork
Braço De Mudança De Velocidade Tdf [Tipo Trasero Rops] / Pto Gear Shift Arm [Rear Rops Type]
Bloqueio Diferencial De Forque Ta / Differential Lock Shift Fork
T Ravão Esquerda / Brake Lh
T Ravão Direita / Brake Rh
T Irante Travao / Brake Rod
T Ravao Parque / Parking Brake Lever
Tirante / Main Gear Shift Rod
Alavanca Velocidades / Range Gear Shift Lever
Alavanca Dupla Traccao / Front Wheel Drive Lev Er
Alavanca Tdf [Tipo Trasero Rops] / Pto Gear Sh Ift Lever [Rear Rops Type]
Alavanca Tdf [Tipo Medio Rops] / Pto Gear Shif T Lever [Mid Rops Type]
Alavanca Control Posicao / Position Control Le Ver
Valvula Control / Remote Control Lever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differential Lock Pedal
Coluna Direcção / Steering Column
Pedal Inclinacao / Tilt Pedal
Cilindro Direcção [Peças Componentes] / Steerin G Cylinder [Component Parts]
Bomba Hidraulico / Hydrau Lic Pump
Bomba Hidraulico [Peças C Omponentes] / Hydraulic Pump [Component Parts]
Linha Aspiração (Sucção) / Hydraulic Oil Line (Suction)
Tubo Oleo (Entrega) / Hyd Raulic Pipe (Delivery)
Circuito Oleo (Direcção) / Hydraulic Oil Line (Steering)
Circuito Oleo (F/M) / Hyd Raulic Oil Line (F/M)
Cilindro Hidraulico / Hyd Raulic Cylinder
Piston Hidraulico / Braço S / Hydraulic Piston/Lift Arm
Alavanca / Feed Back Leve R
Valvula Control [Peças Co Mponentes] / Control Valve [Component Parts]
Válvula De Controlo Auxil Iar / Auxiliary Control Valve
Valvula Auxiliar [Peças C Omponentes] / Remote Control Valve [Component Parts ]
Veio De Ajuste Da Queda / Fall Adjustment Shaft
Valvula Descarga / Relief Valve
Tirant E / Lift Rod
Ligaca O Inferior [Tipo Trasero Rops] / Link,Lower [Rear R Ops Type]
Ligaca O Inferior [Tipo Medio Rops] / Lower Link [Mid Rops Type]
Ligaca O Superior / Top Link
Corren Te Seguranca / Check Chain
Barra Reboque / Drawbar
Puxo D Ianteiro / Front Hitch
Puxo T Raseiro [Tipo Trasero Rops] / Rear Hitch [Rear Rops Type]
Puxo T Raseiro [Tipo Medio Rops] / Rear Hitch [Mid Rops Ty Pe]
Protec Cao Tdf / Pto Protector
Grelha Frontal / Front Grille
Tampa Painel / Panel Cover
Painel Lateral / Side Cover
Placa / Shutter Plate
Guia Esq [Tipo Trasero Rops] / Lever Guide Lh [ Rear Rops Type]
Guia Esq [Tipo Medio Rops] / Lever Guide Lh [Mi D Rops Type]
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Banco (Cobo Sc74/M91) / Seat (Cobo Sc74/M91)
Banco (Grammer Msg83/511) / Seat (Grammer Msg83 /511)
Banco (Grammer Msg93/511) / Seat (Grammer Msg93 /511)
Banco (Sears 807) / Seat (Sears 807)
Banco (Sears 830) / Seat (Sears 830)
Degrau / Step
Cobertura / Tail Cover
Caixa Ferramenta / Tool Box
Cobertura Traseira [Tipo Trasero Rops] / Rear C Over [Rear Rops Type]
Cobertura Traseira [Tipo Medio Rops] / Rear Cov Er [Mid Rops Type]
Arco Seguranca 1 (Medio) / Rops 1 (Mid)
Arco Seguranca 2 (Traseiro) [Tipo Trasero Rops] / Rops 2 (Rear) [Rear Rops Type]
Arco Seguranca 2 (Traseiro) [Tipo Medio Rops] / Rops 2 (Rear) [Mid Rops Type]
Roda Frente (5-12) / Front Wheel (5-12)
Roda Frente (6-12) / Front Wheel (6-12)
Roda Frente (6,00-12) / Front Wheel (6.00 -12)
Roda Frente (22*8,50-12) / Front Wheel (2 2*8.50-12)
Roda Frente (24*8,50-12) / Front Wheel (2 4*8.50-12)
Roda Traseira (8-16) / Rear Wheel (8-16)
Roda Traseira (9,5-16) / Rear Wheel (9.5 -16)
Roda Traseira (9,5-18) / Rear Wheel (9.5 -18)
Roda Traseira (31*13,5-15) / Rear Wheel (31*13.5-15)
Roda Traseira (315/75d-15) / Rear Wheel (315/75d-15)
Etiqueta (Frente) [Tipo Trasero Rops] / Label (F Ront) [Rear Rops Type]
Etiqueta (Frente) [Tipo Medio Rops] / Label (Fro Nt) [Mid Rops Type]
Etiqueta (Traseira) [Tipo Trasero Rops] / Label (Rear) [Rear Rops Type]
Etiqueta (Traseira) [Tipo Medio Rops] / Label (R Ear) [Mid Rops Type]
K It De Carregador Dianteiro Válvula De Controlo (Vál Vula) [Opçao] / Front Loader Control Valve Kit (Val Ve) [Option]
K It De Carregador Dianteiro Válvula De Controlo [Peç As Componentes] [Opçao] / Front Loader Control Valv E Kit [Component Parts] [Option]
K It De Carregador Dianteiro Válvula De Controlo (Ala Vanca) [Opçao] / Front Loader Control Valve Kit (Le Ver) [Option]
K It De Carregador Dianteiro Válvula De Controlo (Lig Ação) [Opçao] / Front Loader Control Valve Kit (Lin K) [Option]
K It De Carregador Dianteiro Válvula De Controlo (Tub O 1) [Opçao] / Front Loader Control Valve Kit (Pipe 1) [Option]
K It De Carregador Dianteiro Válvula De Controlo (Tub O 2) [Opçao] / Front Loader Control Valve Kit (Pipe 2) [Option]
K It Luzes Trabalho [Tipo Trasero Rops] [Opçao] / Wor King Light Kit [Rear Rops Type] [Option]
C Ilindro Elevação (Braços) [Opção] / Mower Lift Cyli Nder Kit (Lift Arm) [Option]
C Ilindro Elevação (Cilindro) [Opção] / Mower Lift Cy Linder Kit (Cylinder) [Option]
K It Pesos Rodas [Opção] / Front Weight Kit [Option]
F Rente Hidráulico Tomada Kit [Opção] / Front Hydraul Ic Outlet Kit [Option]
