Kubota Compact Tractor B2201D-S5 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B2201D-S5 Compact Tractor
Number of Pages: 261 Pages
Itens Usados Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Arvore Cames E Veio / Camshaft And Idle Gear Shaf T
Volante Motor / Flywheel
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Glow Plu G
Bomba Agua E Termostacto / Water Flange And Therm Ostat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (Air Clea Ner)
Escpae / Muffler
Tubo Combustivel / Fuel Pip E
Filtro Gasoleo / Fuel Filte R
Filtro Gasoleo [Peças Compo Nentes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel Pump
Ventoinha / Fan
Tubo Agua / Water Pipe
Valvula Solenoide / Stop S Olenoid
Alternador [Tipo Trasero R Ops] / Alternator [Rear Rops Type]
Alternador [Peças Componen Tes] [Tipo Trasero Rops] / Alternator [Component Pa Rts] [Rear Rops Type]
Alternador [Peças Componen Tes] [Tipo Medio Rops] / Alternator [Component Part S] [Mid Rops Type]
Motor Arranque / Starter
Motor Arranque [Peças Comp Onentes] / Starter [Component Parts]
Interruptor [Tipo Trasero Rops] / Switch [Rear Rops Type]
Interruptor [Tipo Medio Ro Ps] / Switch [Mid Rops Type]
Rele / Relay
Painel / Panel Board
Painel [Peças Componentes] / Panel Board [Component Parts]
Luzes Frente [Exceto Uk] / Head Light [Except Uk]
Luzes Frente [Uk] / Head L Ight [Uk]
Luzes Frontais [Tipo Trase Ro Rops] / Front Combination Lamp [Rear Rops Type]
Luzes Frontais [Tipo Medio Rops] / Front Combination Lamp [Mid Rops Type]
Braco Traseiro / Rear Comb Ination Lamp
Farol Matricula [Tipo Tras Ero Rops] / License Lamp [Rear Rops Type]
Farol Matricula [Tipo Medi O Rops] / License Lamp [Mid Rops Type]
Cablagem Electrica (Corpo) [Tipo Trasero Rops] / Electrical Wiring (Body) [Re Ar Rops Type]
Cablagem Electrica (Corpo) [Tipo Medio Rops] / Electrical Wiring (Body) [Mid Rops Type]
Embraiagem / Clutch
Embraiagem / Clutch Rod
Quadro Eixo Frente / Front Axle Fram E
Diferencial Dianteiro / Front Differ Ential
Engrenagem Cónica Esquerda / Bevel G Ear Lh
Engrenagem Cónica Direita / Bevel Ge Ar Rh
Carter Grupo Conico / Bevel Gear Cas E
Carter Eixo Frente Esq / Axle Case L H
Carter Eixo Frente Drt / Axle Case R H
Eixo Dianteiro Esq / Front Axle Lh
Veio Eixo / Front Wheel Drive Shaft
Caixa Da Transmissão [Tipo Trasero Ro Ps] / Transmission Case [Rear Rops Type]
Caixa Da Transmissão [Tipo Medio Rops ] / Transmission Case [Mid Rops Type]
Diferencial Carreto / Differential Ge Ar Case
Carter Eixo Traseiro Esq [Tipo Traser O Rops] / Rear Axle Case Lh [Rear Rops Type]
Carter Eixo Traseiro Esq [Tipo Medio Rops] / Rear Axle Case Lh [Mid Rops Type]
Carter Eixo Traseiro Drt [Tipo Traser O Rops] / Rear Axle Case Rh [Rear Rops Type]
Carter Eixo Traseiro Drt [Tipo Medio Rops] / Rear Axle Case Rh [Mid Rops Type]
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Engrenagem Principal / Main Gear Shaf T
Veio Gamas Velocidades [Tipo Trasero Rops] / Range Gear Shaft [Rear Rops Type]
Veio Gamas Velocidades [Tipo Medio Ro Ps] / Range Gear Shaft [Mid Rops Type]
Inversor 1 / Reverse Shaft 1
Inversor 2 [Tipo Trasero Rops] / Reve Rse Shaft 2 [Rear Rops Type]
Inversor 2 [Tipo Medio Rops] / Revers E Shaft 2 [Mid Rops Type]
Veio Inversor / Shuttle Shaft
Tdf / Veio Tdf [Tipo Trasero Rops] / Pto Drive Shaft [Rear Rops Type]
Tdf / Veio Tdf [Tipo Medio Rops] / Pt O Drive Shaft [Mid Rops Type]
Tdf / Veio Tdf [Tipo Trasero Rops] / Pto Gear Shift Shaft [Rear Rops Type]
Tdf / Veio Tdf [Tipo Medio Rops] / Pt O Gear Shift Shaft [Mid Rops Type]
Tdf Central [Tipo Trasero Rops] / Mid Pto [Rear Rops Type]
Grupo Conico / Bevel Gear Shaft
Diferencial Traseiro / Rear Different Ial
Forquilha Inversor / Shuttl E Shift Fork
Inversor / Shuttle Shift Ro D
Forqueta Velocidades / Rang E Gear Shift Fork
Braço De Mudança De Velocid Ade Tdf [Tipo Trasero Rops] / Pto Gear Shift Fork [ Rear Rops Type]
Braço De Mudança De Velocid Ade Tdf [Tipo Medio Rops] / Pto Gear Shift Fork [Mi D Rops Type]
Braço De Mudança De Velocid Ade Tdf [Tipo Trasero Rops] / Pto Gear Shift Arm [R Ear Rops Type]
Bloqueio Diferencial De For Queta / Differential Lock Shift Fork
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao / Brake Rod
Tirante / Main Gear Shift Rod
Alavanca Velocidades / Range Gear Shift Lev Er
Alavanca Tdf [Tipo Trasero Rops] / Pto Gear Shift Lever [Rear Rops Type]
Alavanca Tdf [Tipo Medio Rops] / Pto Gear S Hift Lever [Mid Rops Type]
Alavanca Control Posicao / Position Control Lever
Valvula Control / Remote Control Lever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differential L Ock Pedal
Coluna Direcção / Steering Column
Pedal Inclinacao / Tilt Pedal
Cilindro Direcção [Peças Componentes] / Stee Ring Cylinder [Component Parts]
Bomba Hidraulico / Hyd Raulic Pump
Bomba Hidraulico [Peça S Componentes] / Hydraulic Pump [Component Parts]
Linha Aspiração (Sucçã O) / Hydraulic Oil Line (Suction)
Tubo Oleo (Entrega) / Hydraulic Pipe (Delivery)
Circuito Oleo (Direcçã O) / Hydraulic Oil Line (Steering)
Circuito Oleo (F/M) / Hydraulic Oil Line (F/M)
Piston Hidraulico / Br Aços / Hydraulic Piston/Lift Arm
Alavanca / Feed Back L Ever
Valvula Control / Cont Rol Valve
Valvula Control [Peças Componentes] / Control Valve [Component Parts]
Válvula De Controlo Au Xiliar / Auxiliary Control Valve
Valvula Auxiliar [Peça S Componentes] / Remote Control Valve [Component Pa Rts]
Veio De Ajuste Da Qued A / Fall Adjustment Shaft
Valvula Descarga / Rel Ief Valve
Lig Acao Inferior [Tipo Trasero Rops] / Link,Lower [Rea R Rops Type]
Lig Acao Inferior [Tipo Medio Rops] / Lower Link [Mid R Ops Type]
Lig Acao Superior / Top Link
Cor Rente Seguranca / Check Chain
Bar Ra Reboque / Drawbar
Pux O Dianteiro / Front Hitch
Pux O Traseiro [Tipo Trasero Rops] / Rear Hitch [Rear R Ops Type]
Pux O Traseiro [Tipo Medio Rops] / Rear Hitch [Mid Rops Type]
Pro Teccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Tampa Painel / Panel Cover
Painel Lateral / Side Cover
Placa / Shutter Plate
Guia Esq [Tipo Trasero Rops] / Lever Guide L H [Rear Rops Type]
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Banco (Cobo Sc74/M91) / Seat (Cobo Sc74/M91)
Banco (Grammer Msg83/511) / Seat (Grammer Ms G83/511)
Banco (Grammer Msg93/511) / Seat (Grammer Ms G93/511)
Banco (Sears 830) / Seat (Sears 830)
Degrau / Step
Cobertura / Tail Cover
Caixa Ferramenta / Tool Box
Cobertura Traseira [Tipo Trasero Rops] / Rea R Cover [Rear Rops Type]
Cobertura Traseira [Tipo Medio Rops] / Rear Cover [Mid Rops Type]
Arco Seguranca 1 (Medio) / Rops 1 (Mid)
Roda Frente (5-12) / Front Wheel (5-12 )
Roda Frente (6-12) / Front Wheel (6-12 )
Roda Frente (6,00-12) / Front Wheel (6 .00-12)
Roda Frente (22*8,50-12) / Front Wheel (22*8.50-12)
Roda Frente (24*8,50-12) / Front Wheel (24*8.50-12)
Roda Traseira (9,5-16) / Rear Wheel ( 9.5-16)
Roda Traseira (9,5-18) / Rear Wheel ( 9.5-18)
Roda Traseira (31*13,5-15) / Rear Whe El (31*13.5-15)
Roda Traseira (315/75d-15) / Rear Whe El (315/75d-15)
Etiqueta (Frente) [Tipo Trasero Rops] / Label (Front) [Rear Rops Type]
Etiqueta (Traseira) [Tipo Trasero Rops] / Lab El (Rear) [Rear Rops Type]
Etiqueta (Traseira) [Tipo Medio Rops] / Label (Rear) [Mid Rops Type]
Acess Orios E Peças Serviço / Accessories And Service Par Ts
Etqss Uaius Q /Qles Sqa(Ilu R Ettqssuaiqs E)D Sqa(Itq /Ea [S
Kit De Carregador Dianteiro Válvula De Controlo ( Válvula) [Opçao] / Front Loader Control Valve Kit ( Valve) [Option]
Kit De Carregador Dianteiro Válvula De Controlo [ Peças Componentes] [Opçao] / Front Loader Control V Alve Kit [Component Parts] [Option]
Kit De Carregador Dianteiro Válvula De Controlo ( Alavanca) [Opçao] / Front Loader Control Valve Kit (Lever) [Option]
Kit De Carregador Dianteiro Válvula De Controlo ( Ligação) [Opçao] / Front Loader Control Valve Kit ( Link) [Option]
Kit De Carregador Dianteiro Válvula De Controlo ( Tubo 1) [Opçao] / Front Loader Control Valve Kit (P Ipe 1) [Option]
Kit De Carregador Dianteiro Válvula De Controlo ( Tubo 2) [Opçao] / Front Loader Control Valve Kit (P Ipe 2) [Option]
Kit Luzes Trabalho [Tipo Trasero Rops] [Opçao] / Working Light Kit [Rear Rops Type] [Option]
Cilindro Elevação (Braços) [Opção] / Mower Lift C Ylinder Kit (Lift Arm) [Option]
Cilindro Elevação (Cilindro) [Opção] / Mower Lift Cylinder Kit (Cylinder) [Option]
Kit Pesos Rodas [Opção] / Front Weight Kit [Optio N]
Frente Hidráulico Tomada Kit [Opção] / Front Hydr Aulic Outlet Kit [Option]
