Kubota Compact Tractor B1830DB Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B1830DB Compact Tractor
Number of Pages: 355 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Volante Motor / Flywheel
Ponto Neutro / Idle Apparatus
Suporte Bico [Peças Componentes] / Nozzle Hol Der [Component Parts]
Bomba Agua E Termostacto / Water Flange And T Hermostat
Bomba Agua / Water Pump
Valvula E Veio Martelos / Valve And Rocker Ar M
Filtro Ar / Air Cleaner
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (Air Cleaner)
Escpae / Muffler
Acelarador Pedal / Accelerator Pedal
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel Filter
Bomba Gasoleo / Fuel Pump
Ventoinha / Fan
Tubo Agua / Water Pipe
Deposito Re Serva / Reserve Tank
Sensor Térmico E Interruptor Do Óleo / Oil Switch And Thermo Sensor
Valvula Solenoide / Stop Sol Enoid
Alternador / Alternator
Alternador [Peças Componente S] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Compon Entes] / Starter [Component Parts]
Comutador / Switch
Rele / Relay
Painel / Panel Board
Painel [Peças Componentes] / Panel Board [Component Parts]
Farol Frente / Head Light
Luzes Frontais [Tipo Traseir A Arco] / Front Combination Lamp [Rear Rops Type] # # N.º De Série<=30882 S.No.;<=30882 / S.No.<=30882 S.No.;<=30882
Luzes Frontais [Tipo Traseir A Arco] / Front Combination Lamp [Rear Rops Type] # # N.º De Série>=30883 S.No.;>=30883 / S.No.>=30883 S.No.;>=30883
Luzes Frontais [Tipo Medio A Rco] / Front Combination Lamp [Mid Rops Type]
Braco Traseiro / Rear Combin Ation Lamp
Farol Matricula / License La Mp
Ficha Reboque / Trailer Sock Et
Cablagem Electrica / Electri Cal Wiring
Embraiagem / Clutch
Embraiagem / Clutch Rod
Tampa Da Caixa De Embraiagem / Clutch Housing Cover
Carter Eixo Frente / Front Axle Case # # N.º De Série<=30075 S.No.;<=30075 [Note:Order By Fig.No.G10502 #1 Ref.No.010,020,070 #2 Ref.No.080,1 60 New Parts.] / S.No.<=30075 [Note:Order By Fig.No .G10502 #1 Ref.No.010,020,070 #2 Ref.No.080,160 New Parts.]
Carter Eixo Frente / Front Axle Case # # N.º De Série>=30076 [Nota: Encomenda Por N.º De R Eferência 080,160 Peças Novas.] / S.No.>=30076 [Not E:Order By Ref.No.080,160 New Parts.]
Diferencial Dianteiro / Front Differen Tial
Engrenagem Cónica Esquerda / Bevel Gea R Lh
Engrenagem Cónica Direita / Bevel Gear Rh
Carter Grupo Conico / Bevel Gear Case
Carter Eixo Frente Esq / Front Axle Ca Se Lh
Carter Eixo Frente Drt / Front Axle Ca Se Rh
Eixo Dianteiro Esq / Front Axle Lh
Veio Eixo / Front Drive Shaft
Tampa Transmissao / Transmission Case C Over
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Engrenagem Principal / Main Gear Shaft
Veio Gamas Velocidades / Range Gear Sha Ft
Inversor 1 / Reverse Shaft 1
Inversor 2 / Reverse Shaft 2
Veio Inversor / Shuttle Shaft
Veio Tdf / Pto Drive Shaft
Veio Engrenagem Tdf / Pto Gear Shift Sh Aft
Velocidades Engrenagem / Range Gear
Diferencial Traseiro / Rear Differentia L
Carter Eixo Traseiro Esq [Tipo Traseira Arco] / Rear Axle Case Lh [Rear Rops Type]
Carter Eixo Traseiro Esq [Tipo Medio Arc O] / Rear Axle Case Lh [Mid Rops Type]
Carter Eixo Traseiro Drt [Tipo Traseira Arco] / Rear Axle Case Rh [Rear Rops Type]
Carter Eixo Traseiro Drt [Tipo Medio Arc O] / Rear Axle Case Rh [Mid Rops Type]
Forqueta / Main Gear Shift Fo Rk
Forquilha Inversor / Shuttle Shift Fork
Inversor / Shuttle Shift Rod
Forqueta Velocidades / Range Gear Shift Fork
Alvanca Tdf / Pto Gear Shift Fork
Alavanca / Differential Lock Shift Fork
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao / Brake Rod
Alavanca Velocidades / Main Gear Shift Lever
Alavanca Velocidades / Range Gear Shift Lever
Alavanca Dupla Traccao / Front Wheel Drive Le Ver
Alavanca Control Posicao / Position Control L Ever
Avalanca Control Valvula / Remote Control Lev Er
Pedal Travao / Brake Pedal
Bloqueio Diferencial / Differential Lock Peda L
Braço Bi-Speed / Bi-Speed Turn Arm
Biela Bi-Speed / Bi-Speed Shift Rod
Veio Bi-Speed Turn / Bi-Speed Turn Shaft
Alavanca / Tilt Lever
Cilindro Direcção [Peças Componentes] / Steeri Ng Cylinder [Component Parts]
Bomba Hidraulico / Hydra Ulic Pump
Tubo Oleo Hidraulico (As Piração) / Hydraulic Oil Line (Suction)
Tubo Oleo Hidraulico (Fo Rnecimento) / Hydraulic Oil Line (Delivery)
Tubo Oleo Hidraulico (Di Recção) / Hydraulic Oil Line (Steering)
Tubo Oleo Hidraulico (F/ M) / Hydraulic Oil Line (F/M)
Cilindro Hidraulico / Hy Draulic Cylinder
Piston Hidraulico/Braços / Hydraulic Piston/Lift Arm
Alavanca / Feed Back Lev Er
Valvula Control / Contro L Valve
Valvula Control [Peças C Omponentes] / Control Valve [Component Parts]
Distribuidor Auxiliar / Remote Control Valve
Distribuidor Auxiliar [P Eças Componentes] / Remote Control Valve [Component Parts]
Veio De Ajuste Da Queda / Fall Adjustment Shaft
Valvula Descarga / Relie F Valve
Tirante / Lift Rod
Ligacao Inferior / Lower Li Nk
Ligacao Superior / Top Link
Corrente Seguranca / Check Chain
Barra Reboque / Drawbar
Puxo Dianteiro / Front Hitc H
Puxo Traseiro / Rear Hitch
Proteccao Tdf / Pto Protect Or
Grelha Frontal / Front Grille
Capot Superior / Bonnet (Hood)
Tampa Painel / Panel Cover
Painel Lateral / Side Cover
Placa / Shutter Plate
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Piso / Floor Sheet
Banco (Cobo Sc74/M91) / Seat (Cobo Sc74/M91)
Banco (Grammer Msg83/8) / Seat (Grammer Msg83/ 8)
Banco (Kab Seating Xh2/P1) / Seat (Kab Seating Xh2/P1)
Banco (Kab Seating 11/P1) / Seat (Kab Seating 11/P1)
Banco (Sears Mcs3000) / Seat (Sears Mcs3000)
Degrau / Step
Cobertura / Tail Cover
Arco [Tipo Traseira Arco] / Rops [Rear Rops Ty Pe]
Arco Seguranca 1 (Central) [Tipo Medio Arco] / Rops 1 (Center) [Mid Rops Type]
Arco Seguranca 2 (Traseiro) [Tipo Medio Arco] / Rops 2 (Rear) [Mid Rops Type]
Roda Frente (6-12b) / Front Wheel (6-12b)
Roda Frente (6.00-12) / Front Wheel (6.00 -12)
Roda Frente (22*8.50-12) / Front Wheel (2 2*8.50-12)
Roda Frente (24*8.50-12) / Front Wheel (2 4*8.50-12)
Roda Frente (6-12) / Front Wheel (6-12)
Roda Traseira (8-16) / Rear Wheel (8-16)
Roda Traseira (31*13.5-15) / Rear Wheel (31*13.5-15)
Roda Traseira (315/75d-15) / Rear Wheel (315/75d-15)
Roda Traseira (9,5-16) / Rear Wheel (9.5 -16)
Etiqueta (Frente) [Tipo Traseira Arco] [Ingles] [Espanhol] / Label (Front) [Rear Rops Type] [Engli Sh] [Spanish]
Etiqueta (Frente) [Tipo Traseira Arco] [Italian O] / Label (Front) [Rear Rops Type] [Italian]
Etiqueta (Frente) [Tipo Traseira Arco] / Label (Front) [Rear Rops Type]
Etiqueta (Frente) [Tipo Medio Arco] [Ingles] [E Spanhol] / Label (Front) [Mid Rops Type] [English] [Spanish]
Etiqueta (Frente) [Tipo Medio Arco] [Italiano] / Label (Front) [Mid Rops Type] [Italian]
Etiqueta (Frente) [Tipo Medio Arco] / Label (Fr Ont) [Mid Rops Type]
Etiqueta (Traseira) [Tipo Traseira Arco] [Ingle S] / Label (Rear) [Rear Rops Type] [English]
Etiqueta (Traseira) [Tipo Traseira Arco] [Espan Hol] / Label (Rear) [Rear Rops Type] [Spanish]
Etiqueta (Traseira) [Tipo Traseira Arco] [Itali Ano] / Label (Rear) [Rear Rops Type] [Italian]
Etiqueta (Traseira) [Tipo Traseira Arco] / Labe L (Rear) [Rear Rops Type]
Etiqueta (Traseira) [Tipo Medio Arco] [Ingles] / Label (Rear) [Mid Rops Type] [English]
Etiqueta (Traseira) [Tipo Medio Arco] [Espanhol ] / Label (Rear) [Mid Rops Type] [Spanish]
Etiqueta (Traseira) [Tipo Medio Arco] [Italiano ] / Label (Rear) [Mid Rops Type] [Italian]
Etiqueta (Traseira) [Tipo Medio Arco] / Label ( Rear) [Mid Rops Type]
Acessor Ios E Peças Serviço / Accessories And Service Parts
Frente Suspensão [Opção] / Front Winker Stay Kit [O Ption]
Kit Luzes Trabalho [Opção] / Working Light Kit [Opt Ion]
Cilindro Elevação (Braco Hidraulico) [Opção] / Mowe R Lift Cylinder Kit (Lift Arm) [Option]
Cilindro Elevação (Cilindro) [Opção] / Mower Lift C Ylinder Kit (Cylinder) [Option]
Kit Pesos Rodas [Opção] / Front Weight Kit [Option]
Carreto / Gear Case
Escpae / Muffler
Ventoinha / Fan
Comutador / Switch
Rele / Relay
Embraiagem / Clutch
Tirante / Lift Rod
Piso / Floor Sheet
Degrau / Step
