Kubota Compact Tractor B1820DT Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B1820DT Compact Tractor
Number of Pages: 203 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Radiador / Main Bearing Case
Piston E Cambota / Piston And Crank Shaft
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaft
Ponto Neutro / Idle Apparatus
Suporte Bico [Peças Componentes] / Nozzle Holder [C Omponent Parts]
Bomba Gasoleo / Fuel Pump (Mechanical)
Fan Drive Pulley / Fan Drive Pulley
Bomba Agua E Termostacto / Water Flange And Thermos Tat
Acessorios / Water Pump
Válvula E Veio Do Balanceiro / Valve And Rocker Arm
Filtro Ar / Air Cleaner
Escpae / Muffler
Kit De Junta Superior [Opção] / Upper Gasket Kit [O Ption]
Kit De Junta Inferior [Opção / Lower Gasket Kit [Op Tion]
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo[Peças Componen Tes] / Fuel Filter (Component Parts)
Ventilador / Fan
Radiador / Water Pipe
Deposito Re Serva / Reserve Tank
Filtro Gasoleo / Stop Soleno Id
Alternador / Alternator
Alternador [Peças Componente S] / Alternator (Component Parts)
Motor Arranque [Componentes] / Starter [Component Parts]
Comutador / Switch
Interruptor / Rele / Switch/ Relay
Painel[Peças Componentes] / Panel Board [Component Parts]
Farol Dianteiro / Head Light
Farol Traseiro / Tail Light
Lampada (Arco) / Winker Lamp
Farol Matricula / License La Mp
Cablagem Electrica / Electri Cal Wiring(Body)
Compensador / Clutch
Embraiagem / Clutch Rod
Bloqueio Diferencial / Clutch Pedal
Estrututa Frontal / Front Frame
Carter Eixo / Rear Axle Case
Veio Frontal / Front Propeller Shaft
Veio Tdf / Pto Shaft
Tdf Central / Mid Pto
Grupo Conico / Range Gear
Diferencial Traseiro / Differential Rea R
1 Velocidade / 1st Shaft
2 Velocidade / 2nd Shaft
3 Velocidade / 3rd Shaft/4th Shaft
Forqueta / Main Gear Shift Fo Rk
Forqueta Caixa / Creeper / Ra Nge Gear Shift Fork
Alvanca Tdf / Pto Shift Fork
Alavanca / Rear Differential Lock Shift Fork
Alavanca Velocidades / Main G Ear Shift Lever
Alavanca Velocidades / Range Gear Shift Lever
Alavanca Dupla Traccao / Fron T Wheel Drive Lever
Eixo Traseiro / Rear Axle
Roda Traseira / Rear Wheel(7-16)
Roda Traseira / Rear Wheel(8-16)
Roda Traseira / Rear Wheel(9.5-16)
Roda Traseira / Rear Wheel(212/80d-15)
Roda Traseira / Rear Wheel(29*12.00-15)
Travão / Brake
Tirante Travao / Brake Rod
Pedal Do Travão De Estacionamento / Parking Brake P Edal
Pedal Travao / Brake Pedal
Alavamca De Controle / Hydra Ulic Control Lever
Bomba Hidraulico[Peças Compo Nentes] / Hydraulic Pump [Component Parts]
Linha Aspiração / Hydraulic Pipe (Suction)
Linha De Óleo Hidráulico (Fo Rnecimento) / Hydraulic Oil Line (Delivery)
Cilindro Hidraulico / Hydrau Lic Cylinder
Hydraulic Valve [Component Parts] / Hydraulic Valve [Component Parts]
Braço De Elevação Hidráulico / Hydraulic Lift Arm
Braco Hidraulico / Control V Alve
Valvula Control / Control Va Lve [Component Parts]
Roda Frente / Front Wheel(4.5-10)
Roda Frente / Front Wheel(5-12)
Roda Frente / Front Wheel(6-12b)
Roda Frente / Front Wheel(20*8.00*10)
Roda Frente / Front Wheel(20.5*8.00*10)
Carter Eixo / Front Axle Case
Diferencial Dianteiro / Front Differen Tial
Grupo Conico / Bevel Gear
Carter Grupo Conico / Bevel Gear Case
Eixo Dianteiro / Front Axle
Veio / Front Drive Shaft
Braço Da Articulação / Knuckle Arm
Ligação / Drag Link
Direcção Assistida / Tie Rod
Direcção Assistida / Direção Punho / Steering Handle
Direcção / Steering
Tiran Te / Lift Rod
Ligac Ao Inferior / Lower Link
Ligac Ao Superior / Top Link
Corre Nte Seguranca / Check Chain
Puxo / Hitch (Rear)
Grelha Frontal / Front Grille
Capot / Hood (Bonnet)
Painel Inferior / Panel Cover
Painel Lateral / Side Cover
Placa / Shutter Plate
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Banco / Seat (Cobo Sc74/M91)
Banco / Seat (Grammer Msg83/8)
Banco / Seat (Kab Seating Xh2/P1)
Banco / Seat (Sears 607)
Degrau / Step
Cobertura / Tail Cover
Etiqueta Frente / Label
Acessorios / Accessorie S And Service Parts
Kit Luzes Trabalho (Opçao) / Work Light Kit [Option ]
Front Hitch Kit [Option] / Front Hitch Kit [Option]
Kit Barra Reboque[Opcao] / Drawbar Kit (Front) [Opt Ion]
Rops Kit [Option] / Rops Kit [Option]
Carreto / Gear Case
Escpae / Muffler
Ventilador / Fan
Comutador / Switch
Travão / Brake
Ligação / Drag Link
Direcção / Steering
Tiran Te / Lift Rod
Puxo / Hitch (Rear)
Degrau / Step
