Kubota Compact Tractor B1610 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B1610 Compact Tractor
Number of Pages: 216 Pages
Itens Uso Frequente / Fr Equently Used Items
Bl Oco Motor / Crank Case
Ca Rter Oleo / Oil Pan
Ca Beca Motor / Cylinder Head
Ca Rreto / Gear Case
Ta Mpa Cabeça / Head Cover
Fi Ltro Oleo / Oil Filter
Va Reta Nivel E Guia / Dipstick And Guide
Ra Diador / Main Bearing Case
Ar Vore Cames E Veio / Camshaft And Idle Gear Shaft
Pi Ston E Cambota / Piston And Crankshaft
Vo Lante Motor / Flywheel
Ve Io / Fuel Camshaft And Governor Shaft
Po Nto Neutro / Idle Apparatus
Bo Mba Injectora / Injection Pump
Re Gulador / Governor
Re Gulador Velocidade / Speed Control Plate
Va Lvula Solenoide / Nozzle Holder And Glow Plug
Su Porte Bico [Peças Componentes] / Nozzle Holder [Com Ponent Parts]
Bo Mba Gasoleo / Fuel Pump (Mechanical)
Bo Mba Agua E Termostacto / Water Flange And Thermosta T
Ac Essorios / Water Pump
Vá Lvula E Veio Do Balanceiro / Valve And Rocker Arm
Co Lector Admissao / Inlet Manifold
Co Lector Escape / Exhaust Manifold
Fi Ltro Ar / Air Cleaner [Fr,Uk,G]
Fi Ltro Ar / Air Cleaner [South Europe,Sp]
Es Cpae / Muffler
Ac Elarador Mao / Accelerator Lever
Ac Elarador / Accelerator Pedal
Ti Rante Do Acelerador / Accelerator Rod
Deposito Combustivel / Fuel Tan K
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo[Peças Componente S] / Fuel Filter [Component Parts]
Ventilador / Fan
Radiador / Wa Ter Pipe
Radiador / Ra Diator
Deposito Rese Rva / Reserve Tank
Alternador / Alternator
Alternador [Peças Componentes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componentes] / Starter [Component Parts]
Comutador / Switch
Painel[Peças Componentes] / Pa Nel Board [Component Parts]
Farol Frente / Head Light/Tail Lamp [Except Uk]
Farol Frente / Head Light/Tail Lamp [Uk]
Cabalagem Eletrica(Cabine)[Ec] [G] / Electrical Wiring
Compensador / Clutch
Embraiagem / Clutch Rod
Bloqueio Diferencial / Clutch Pedal
Caixa Velocidades / Transmission Case [Fr ,Uk,G]
Caixa Velocidades / Transmission Case [So Uth Europe,Sp]
Carter Eixo / Rear Axle Case
Veio Embraiagem / Clutch Shaft/Output Sha Ft
Tdf / Veio Tdf / Pto Counter Shaft/Pto Dr Ive Shaft
Tdf Intermédia / Mid Pto [Fr,Uk,G]
Diferencial Carter / Rear Differential
Veio Tracao Dianteira / Front Wheel Prope Ller Shaft
1 Velocidade / Fwd 1st Shaft
2 Velocidade / Fwd 2nd Shaft
3 Velocidade / Fwd 3rd Shaft
Forqueta Caixa / Creeper / Rang E Gear Shift Fork
Alvanca Tdf / Pto Gear Shift Fo Rk
Alavanca / Differential Lock Sh Ift Fork
Alavanca Velocidades / Main Gea R Shift Lever
Alavanca Velocidades / Range Ge Ar Shift Lever
Alavanca Tdf / Pto Gear Shift L Ever
Alavamca De Controle / Hydrauli C Control Lever
Eixo Traseiro / Rear Axle
Roda Traseira / Rear Wheel (7-16)
Roda Traseira / Rear Wheel (8-16)
Roda Traseira / Rear Wheel (212/80d-15)
Bloqueio Diferencial / Differential Lock P Edal
Tr Avão / Brake
Ti Rante Travao / Brake Rod
Al Avanca Travao Mao / Parking Brake Lever
Pe Dal Travao / Brake Pedal
Se Condary Brake Pedal [G,Sp] / Secondary Brake Pedal [G,Sp]
Roda Frente / Front Wheel (4.50-10)
Roda Frente / Front Wheel (5-12)
Roda Frente / Front Wheel (20*8.00*10)
Carter Eixo / Front Axle Case
Diferencial Dianteiro / Front Differenti Al
Carter Grupo Conico / Bevel Gear Case
Eixo Dianteiro / Front Axle
Veio / Front Drive Shaft
Braço Da Articulação / Knuckle Arm
Direcção / Steering Controller [South Europe]
Direcção / Steering Controller [Fr,Uk,G,Sp]
Direcção [Peças Componentes] / Steering Controll Er [Component Parts] [South Europe]
Direcção [Peças Componentes] / Steering Controll Er [Component Parts] [Fr,Uk,G,Sp]
Bomba Hidraulico / Hydraul Ic Pump
Bomba Hidraulico[Peças Com Ponentes] / Hydraulic Pump [Component Parts]
Linha Aspiração / Hydrauli C Oil Line (Suction)
Linha De Óleo Hidráulico ( Fornecimento) / Hydraulic Oil Line (Delivery)
Cilindro Hidraulico / Hydr Aulic Cylinder
Válvula De Hidraulico[Peça S Componentes] / Hydraulic Valve [Component Parts] [Except G]
Piston Hidraulico / Braços / Hydraulic Piston/Lift Arm
Braco Hidraulico / Control Valve
Valvula Control / Control Valve [Component Parts]
Tirante / Lift Rod
Ligacao Inferior / Lower Link
Ligacao Superior / Top Link
Corrente Seguranca / Check Cha In
Barra Reboque / Drawbar [G]
Puxo / Hitch
Puxo / Front Hitch
Grelha Frontal / Front Grille
Acessorios / Bonnet
Painel Inferior / Panel Cover
Lubrificacao (Engrenagem De Passeio De Bomba Hid Raulica) [Opção] / Side Cover Lower
Guarda Lamas / Fender
Banco / Seat [Uk,South Europe]
Banco / Seat [Fr,Sp]
Banco / Seat [G]
Degrau / Step
Etiqueta Frente / Label
Acessorios / Accessories And Service Parts
