Kubota Compact Tractor B1241D-EC-M-S5 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B1241D-EC-M-S5 Compact Tractor
Number of Pages: 193 Pages
Itens U Sados Frequentemente / Frequently Used Items
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Volante Motor / Flywheel
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Glo W Plug
Suporte Bico [Peças Componentes] / Nozzle Ho Lder [Component Parts]
Bomba Agua / Water Pump
Valvula E Veio Martelos / Valve And Rocker A Rm
Filtro Ar / Air Cleaner
Tubo Aspiracao / Inlet Pipe (Air Cleaner)
Escpae / Muffler
Tubo Combustivel / Fue L Pipe
Filtro Gasoleo / Fuel Filter
Filtro Gasoleo [Peças Componentes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel P Ump
Vent Oinha / Fan
Tubo Agua / Water Pipe
Radi Ador / Radiator
Depo Sito Reserva / Reserve Tank
Sensor Térmico E Inte Rruptor Do Óleo / Oil Switch And Thermo Sensor
Valvula Solenoide / S Top Solenoid
Alternador / Alternat Or
Motor Arranque / Star Ter
Motor Arranque [Peças Componentes] / Starter [Component Parts]
Interruptor / Switch
Interruptor/Rele / Re Lay
Painel / Panel Board
Painel [Peças Compone Ntes] / Panel Board [Component Parts]
Tampa Interruptor / P Anel Switch
Farol Frente / Head L Ight
Braco Traseiro / Rear Combination Lamp
Lampada / Winker Lamp
Farol Matricula / Lic Ense Lamp
Cablagem Electrica (C Orpo) / Electrical Wiring (Body)
Embraiagem / Clutch
Embraiagem / Clutch Rod
Tampa Da Caixa De Embraiagem / Clutch H Ousing Cover
Suporte Principal / Center Fram E
Roda Frente (6-12) / Front Whee L (6-12)
Roda Frente (7-12) / Front Whee L (7-12)
Roda Frente (5-12) / Front Whee L (5-12)
Suporte Eixo Frente / Front Axl E Frame
Diferencial Dianteiro / Front D Ifferential
Engrenagem Cónica Esquerda / Be Vel Gear Lh
Engrenagem Cónica Direita / Bev El Gear Rh
Carter Grupo Conico / Bevel Gea R Case
Carter Eixo Frente Esq / Front Axle Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Eixo Dianteiro / Front Axle Lh
Veio Eixo / Front Drive Shaft
Caixa Da Transmissão / Transmiss Ion Case
Veio Primario / Front Propeller Shaft
Veio Primario / Front Shaft
Veio Tdf / Pto Shaft
Grupo Conico / Range Gear
Diferencial Traseiro / Different Ial Rear
Veio Tracao Dianteira / Front Wh Eel Propeller Shaft
2 Velocidade / 2nd Shaft
3 Velocidade / 3rd Shaft
4 Velocidade / 4th Shaft
Forqueta / Main Gear S Hift Fork
Forqueta Velocidades / Range Gear Shift Fork
Alvanca Tdf / Pto Gear Shift Fork
Bloqueio Diferencial D E Forqueta / Differential Lock Shift Fork
Eixo Traseiro Esquerda / Rear Axl E Lh
Roda Traseira (9.5-16) / Rear Whe El (9.5-16)
Roda Traseira (9.5-18) / Rear Whe El (9.5-18)
Roda Traseira (8-16) / Rear Wheel (8-16)
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao / Brake Rod
Tirante / Main Gear Shift Lever
Alavanca Dupla Traccao / Front Wheel D Rive Lever
Alavamca De Controle / Hydraulic Contr Ol Lever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Different Ial Lock Pedal
Braço Da Articulação / Knuckle Arm
Ligação / Drag Link
Direcção Assistida / Tie Rod
Bomba Hidráulica (Ps) / Hydraulic Pump (Ps)
Bomba Hidraulico (Ps) [Peças Componentes] / Hydraulic Pump (Ps) [Com Ponent Parts]
Bomba Hidraulico [Peças Componentes] / Hydraulic Pump [Component Par Ts]
Linha Aspiração ( Sucção) / Hydraulic Oil Line (Suction)
Tubo Oleo (Entreg A) / Hydraulic Oil Line (Delivery)
Circuito Oleo (Di Recção) / Hydraulic Oil Line (Steering)
Circuito Oleo (F/ M) / Hydraulic Oil Line (F/M)
Piston Hidraulico / Braços / Hydraulic Piston/Lift Arm
Valvula Control [ Peças Componentes] / Control Valve [Component Parts ]
Veio De Ajuste Da Queda / Fall Adjustment Shaft
3-Pont Acoplamento (Tirante) / Lift Rod
Ligacao Inferior / Lower Link
Ligacao Superior / Top Link
Barra Reboque / Drawbar
Puxo / Front Hitch
Puxo Traseiro / Rear Hitch
Proteccao Tdf / Pto Protector
Capot Superior / Bonnet
Painel Lateral / Side Cover
Pilar Central / Center Pillar
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Piso / Floor Sheet
Degrau / Step
Degrau Suspensão / Step Stay
Cobertura / Tail Cover
Cobertura Traseira / Rear Cover
Arco Seguranca 1 (Medio) / Rops 1 (Rear )
Arco Seguranca 2 (Traseiro) / Rops 2 (M Id)
Banco / Seat
Acessorios E Peças Serviço / Accessories And Servic E Parts
Kit Luzes Trabalho [Opçao] / Working Light K It [Option]
Puxo Dianteiro,Kit[Opção] / Front Hitch Kit [Option]
Engate Traseiro (Opcao) / Rear Hitch Kit [Op Tion]
Kit Barra [Opcao] / Drawbar Kit [Option]
Kit Pesos Rodas [Opçao] / Front Weight Kit [ Option]
Kit Espelho Rectrovisor / Rearview Mirror Ki T [Option]
