Kubota Compact Tractor B1241D-EC-F2-S5 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B1241D-EC-F2-S5 Compact Tractor
Number of Pages: 192 Pages
Itens Usados Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Arvore Cames E Veio / Camshaft And Idle Gea R Shaft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaf T And Governor Shaft
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Gl Ow Plug
Suporte Bico [Peças Componentes] / Nozzle H Older [Component Parts]
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Tubo Aspiracao / Inlet Pipe (Air Cleaner)
Escpae / Muffler
Tubo Combustivel / Fu El Pipe
Filtro Gasoleo / Fuel Filter
Filtro Gasoleo [Peças Componentes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel Pump
Ven Toinha / Fan
Tub O Agua / Water Pipe
Rad Iador / Radiator
Dep Osito Reserva / Reserve Tank
Sensor Térmico E Int Erruptor Do Óleo / Oil Switch And Thermo Sensor
Alternador / Alterna Tor
Alternador [Peças Co Mponentes] / Alternator [Component Parts]
Motor Arranque / Sta Rter
Motor Arranque [Peça S Componentes] / Starter [Component Parts]
Interruptor / Switch
Interruptor/Rele / R Elay
Painel / Panel Board
Painel [Peças Compon Entes] / Panel Board [Component Parts]
Tampa Interruptor / Panel Switch
Farol Frente / Head Light
Braco Traseiro / Rea R Combination Lamp
Lampada / Winker Lam P
Farol Matricula / Li Cense Lamp
Cablagem Electrica ( Corpo) / Electrical Wiring (Body)
Embraiagem / Clutch
Embraiagem / Clutch Rod
Tampa Da Caixa De Embraiagem / Clutch Housing Cover
Suporte Principal / Center Fra Me
Roda Frente (6-12) / Front Whe El (6-12)
Roda Frente (7-12) / Front Whe El (7-12)
Roda Frente (5-12) / Front Whe El (5-12)
Suporte Eixo Frente / Front Ax Le Frame
Carter Eixo Frente / Front Axl E Case
Diferencial Dianteiro / Front Differential
Engrenagem Cónica Esquerda / B Evel Gear Lh
Engrenagem Cónica Direita / Be Vel Gear Rh
Carter Grupo Conico / Bevel Ge Ar Case
Carter Eixo Frente Esq / Front Axle Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Eixo Dianteiro / Front Axle Lh
Eixo Frente Drt / Front Axle R H
Veio Eixo / Front Drive Shaft
Caixa Da Transmissão / Transmis Sion Case
Veio Primario / Front Propeller Shaft
Veio Primario / Front Shaft
Veio Tdf / Pto Shaft
Grupo Conico / Range Gear
Diferencial Traseiro / Differen Tial Rear
Veio Tracao Dianteira / Front W Heel Propeller Shaft
3 Velocidade / 3rd Shaft
4 Velocidade / 4th Shaft
Forqueta Velocidades / Range Gear Shift Fork
Alvanca Tdf / Pto Gea R Shift Fork
Bloqueio Diferencial De Forqueta / Differential Lock Shift Fork
Eixo Traseiro Esquerda / Rear Ax Le Lh
Eixo Traseiro Direita / Rear Axl E Rh
Roda Traseira (9.5-16) / Rear Wh Eel (9.5-16)
Roda Traseira (9.5-18) / Rear Wh Eel (9.5-18)
Roda Traseira (8-16) / Rear Whee L (8-16)
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao / Brake Rod
Tirante / Main Gear Shift Lever
Alavanca Velocidades / Range Gear Shi Ft Lever
Alavamca De Controle / Hydraulic Cont Rol Lever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differen Tial Lock Pedal
Braço Da Articulação / Knuckle Arm
Ligação / Drag Link
Direcção Assistida / Tie Rod
Bomba Hidráulica (Ps) / Hydraulic Pump (Ps)
Bomba Hidraulico (Ps) [Peças Componentes] / Hydraulic Pump (Ps) [Co Mponent Parts]
Bomba Hidraulico [Peças Componentes] / Hydraulic Pump [Component Pa Rts]
Linha Aspiração (Sucção) / Hydraulic Oil Line (Suction)
Tubo Oleo (Entre Ga) / Hydraulic Oil Line (Delivery)
Circuito Oleo (D Irecção) / Hydraulic Oil Line (Steering)
Circuito Oleo (F /M) / Hydraulic Oil Line (F/M)
Cilindro Hidraul Ico (Elevador) / Hydraulic Cylinder
Piston Hidraulic O / Braços / Hydraulic Piston/Lift Arm
Alavanca / Feed Back Lever
Valvula Control [Peças Componentes] / Control Valve [Component Part S]
Veio De Ajuste D A Queda / Fall Adjustment Shaft
3-Pont Acoplamento (Tirante) / Lift Rod
Ligacao Inferior / Lower Link
Ligacao Superior / Top Link
Corrente Seguranca / Check Chain
Barra Reboque / Drawbar
Puxo / Front Hitch
Puxo Traseiro / Rear Hitch
Proteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior / Bonnet
Tampa Painel / Panel Cover
Painel Lateral / Side Cover
Pilar Central / Center Pillar
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Piso / Floor Sheet
Degrau / Step
Degrau Suspensão / Step Stay
Cobertura / Tail Cover
Cobertura Traseira / Rear Cover
Arco / Rops
Banco / Seat
Acessorios E Peças Serviço / Accessories And Servi Ce Parts
Kit Luzes Trabalho [Opçao] / Working Light Kit [Option]
Puxo Dianteiro,Kit[Opção] / Front Hitch Kit [Option]
Engate Traseiro (Opcao) / Rear Hitch Kit [O Ption]
Kit Pesos Rodas [Opçao] / Front Weight Kit [Option]
Kit Espelho Rectrovisor / Rearview Mirror K It [Option]
