Kubota Compact Tractor B1241D-EC-F Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B1241D-EC-F Compact Tractor
Number of Pages: 197 Pages
Itens Usad Os Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Arvore Cames E Veio / Camshaft And Idle Gear Sh Aft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaft An D Governor Shaft
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Glow P Lug
Suporte Bico [Peças Componentes] / Nozzle Holde R [Component Parts]
Bomba Agua E Termostacto / Water Flange And The Rmostat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Tubo Aspiracao / Inlet Pipe (Air Cleaner)
Escpae / Muffler
Deposito Combustivel / Fu El Tank
Tubo Combustivel / Fuel P Ipe
Filtro Gasoleo / Fuel Fil Ter
Filtro Gasoleo [Peças Com Ponentes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel Pump (Mechanical)
Ventoin Ha / Fan
Tubo Ag Ua / Water Pipe
Radiado R / Radiator
Sensor Térmico E Interru Ptor Do Óleo / Oil Switch And Thermo Sensor
Alternador / Alternator
Alternador [Peças Compon Entes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Co Mponentes] / Starter [Component Parts]
Interruptor / Switch
Interruptor/Rele / Relay
Painel / Panel Board
Painel [Peças Componente S] / Panel Board [Component Parts]
Tampa Interruptor / Pane L Switch
Farol Frente / Head Ligh T
Braco Traseiro / Rear Co Mbination Lamp
Lampada / Winker Lamp
Farol Matricula / Licens E Lamp
Cablagem Electrica (Corp O) / Electrical Wiring (Body)
Embraiagem / Clutch
Embraiagem / Clutch Rod
Tampa Da Caixa De Embraiagem / Clutch Hous Ing Cover
Roda Frente (6-12) / Front Wheel ( 6-12)
Roda Frente (7-12) / Front Wheel ( 7-12)
Roda Frente (5-12) / Front Wheel ( 5-12)
Suporte Eixo Frente / Front Axle F Rame
Carter Eixo Frente / Front Axle Ca Se
Diferencial Dianteiro / Front Diff Erential
Engrenagem Cónica Esquerda / Bevel Gear Lh
Engrenagem Cónica Direita / Bevel Gear Rh
Carter Grupo Conico / Bevel Gear C Ase
Carter Eixo Frente Esq / Front Axl E Case Lh
Carter Eixo Frente Drt / Front Axl E Case Rh
Eixo Dianteiro / Front Axle Lh
Veio Eixo / Front Drive Shaft
Caixa Da Transmissão / Transmission Case
Diferencial / Differential Gear Cas E
Carter Eixo Traseiro Esq / Rear Axl E Case Lh
Carter Eixo Traseiro Drt / Rear Axl E Case Rh
Veio Primario / Front Propeller Sha Ft
Veio Tdf / Pto Shaft
Grupo Conico / Range Gear
Diferencial Traseiro / Differential Rear
Veio Tracao Dianteira / Front Wheel Propeller Shaft
2 Velocidade / 2nd Shaft
3 Velocidade / 3rd Shaft
4 Velocidade / 4th Shaft
Forqueta / Main Gear Shif T Fork
Forqueta Velocidades / Ra Nge Gear Shift Fork
Alvanca Tdf / Pto Gear Sh Ift Fork
Bloqueio Diferencial De F Orqueta / Differential Lock Shift Fork
Eixo Traseiro Esquerda / Rear Axle L H
Roda Traseira (9.5-16) / Rear Wheel (9.5-16)
Roda Traseira (9.5-18) / Rear Wheel (9.5-18)
Roda Traseira (8-16) / Rear Wheel (8 -16)
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao / Brake Rod
Tirante / Main Gear Shift Lever
Alavanca Velocidades / Range Gear Shift L Ever
Alavanca Dupla Traccao / Front Wheel Driv E Lever
Alavamca De Controle / Hydraulic Control Lever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differential Lock Pedal
Braço Da Articulação / Knuckle Arm
Ligação / Drag Link
Bomba Hidráulica (Ps ) / Hydraulic Pump (Ps)
Bomba Hidraulico (Ps ) [Peças Componentes] / Hydraulic Pump (Ps) [Compon Ent Parts]
Bomba Hidraulico [Pe Ças Componentes] / Hydraulic Pump [Component Parts]
Linha Aspiração (Suc Ção) / Hydraulic Oil Line (Suction)
Tubo Oleo (Entrega) / Hydraulic Oil Line (Delivery)
Circuito Oleo (Direc Ção) / Hydraulic Oil Line (Steering)
Circuito Oleo (F/M) / Hydraulic Oil Line (F/M)
Cilindro Hidraulico (Elevador) / Hydraulic Cylinder
Piston Hidraulico / Braços / Hydraulic Piston/Lift Arm
Alavanca / Feed Back Lever
Valvula Control / Co Ntrol Valve
Valvula Control [Peç As Componentes] / Control Valve [Component Parts]
Veio De Ajuste Da Qu Eda / Fall Adjustment Shaft
3 -Pont Acoplamento (Tirante) / Lift Rod
L Igacao Inferior / Lower Link
L Igacao Superior / Top Link
C Orrente Seguranca / Check Chain
B Arra Reboque / Drawbar
P Uxo / Front Hitch
P Uxo Traseiro / Rear Hitch
P Roteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior / Bonnet
Tampa Painel / Panel Cover
Painel Lateral / Side Cover
Pilar Central / Center Pillar
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Degrau / Step
Degrau Suspensão / Step Stay
Cobertura / Tail Cover
Cobertura Traseira / Rear Cover
Arco / Rops
Banco / Seat
Ace Ssorios E Peças Serviço / Accessories And Service P Arts
Kit Luzes Trabalho [Opçao] / Working Light Kit [Option]
Puxo Dianteiro,Kit[Opção] / Front Hitch Kit [Op Tion]
Kit Barra [Opcao] / Drawbar Kit [Option]
Kit Pesos Rodas [Opçao] / Front Weight Kit [Opt Ion]
Kit Espelho Rectrovisor / Rearview Mirror Kit [ Option]
