Kubota Compact Tractor B1220D Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B1220D Compact Tractor
Number of Pages: 191 Pages
Itens Uso Frequente / F Requently Used Items
B Loco Motor / Crankcase
C Arter Oleo / Oil Pan
C Abeca Motor / Cylinder Head
C Arreto / Gear Case
T Ampa Cabeça / Head Cover
F Iltro Oleo / Oil Filter
V Areta Nivel E Guia / Dipstick And Guide
B Omba Oleo / Oil Pump
R Adiador / Main Bearing Case
P Iston E Cambota / Piston And Crank Shaft
V Olante Motor / Flywheel
V Eio / Fuel Camshaft And Governor Shaft
P Onto Neutro / Idle Apparatus
B Omba Injectora / Injection Pump
R Egulador / Governor
R Egulador Velocidade / Speed Control Plate
V Alvula Solenoide / Nozzle Holder And Glow Plug
S Uporte Bico [Peças Componentes] / Nozzle Holder [Co Mponent Parts]
B Omba Gasoleo / Fuel Pump (Mechanical)
A Cessorios / Water Pump
V Álvula E Veio Do Balanceiro / Valve And Rocker Arm
C Olector Escape / Exhaust Manifold
F Iltro Ar / Air Cleaner
E Scpae / Muffler
K It De Junta Superior / Upper Gasket Kit
D Eposito Combustivel / Lower Gasket Kit
A Celarador Mao / Hand Accelerator Lever
A Celarador / Accelerator Pedal
Deposito Combustivel / Fuel Ta Nk
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo[Peças Component Es] / Fuel Filter [Component Parts]
Ventilador / Fan
Radiador / W Ater Pipe
Radiador / R Adiator
Filtro Gasoleo / Stop Solenoi D
Dínamo / Dynamo
Dinamo [Componenetes] / Dynam O [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componentes] / Starter [Component Parts]
Comutador / Switch
Panel Board And Switch / Pane L Board And Switch
Painel[Peças Componentes] / P Anel Board [Component Parts]
Cablagem Electrica / Electric Al Wiring(Body)
Compensador / Clutch
Embraiagem / Clutch Rod
Bloqueio Diferencial / Clutch Pedal
Estrututa Frontal / Front Frame
Carter Eixo / Rear Axle Case
Veio Frontal / Front Propeller Shaft
Veio Tdf / Pto Shaft
Grupo Conico / Bevel Gear Shaft/Range Ge Ar
Diferencial Traseiro / Differential Rear
Veio Tracao Dianteira / Front Wheel Prop Eller Shaft
2 Velocidade / 2nd Shaft
3 Velocidade / 3rd Shaft/4th Shaft
Forqueta / Main Gear Shift For K
Forqueta Caixa / Creeper / Ran Ge Gear Shift Fork
Alvanca Tdf / Pto Shift Fork
Alavanca / Rear Differential L Ock Shift Fork
Alavanca Velocidades / Main Ge Ar Shift Lever
Alavanca Velocidades / Range G Ear Shift Lever
Eixo Traseiro / Rear Axle
Roda Traseira / Rear Wheel(7-16)
Roda Traseira / Rear Wheel(8-16)
Roda Traseira / Rear Wheel(9.5-16)
Roda Traseira / Rear Wheel(212/80d-15)
Roda Traseira / Rear Wheel(29*12.00-15)
T Ravão / Brake
T Irante Travao / Brake Rod
A Lavanca Travao Mao / Parking Brake Lever
P Edal Travao / Brake Pedal
Alavamca De Controle / Hydrau Lic Control Lever
Bomba Hidraulico[Peças Compon Entes] / Hydraulic Pump [Component Parts]
Linha Aspiração / Hydraulic P Ipe (Suction)
Linha De Óleo Hidráulico (For Necimento) / Hydraulic Oil Line (Delivery)
Cilindro Hidraulico / Hydraul Ic Cylinder
Change Valve [Component Parts ] [Option] / Change Valve [Component Parts] [Option ]
Braço De Elevação Hidráulico / Hydraulic Lift Arm
Braco Hidraulico / Control Va Lve
Valvula Control / Control Val Ve [Component Parts]
Roda Frente / Front Wheel(4.5-10)
Roda Frente / Front Wheel(5-12)
Roda Frente / Front Wheel(6-12b)
Roda Frente / Front Wheel(20*8.00*10)
Roda Frente / Front Wheel(20.5*8.00*10)
Carter Eixo / Front Axle Case
Diferencial Dianteiro / Front Different Ial
Carter Grupo Conico / Bevel Gear Case
Eixo Dianteiro / Front Axle
Veio / Front Drive Shaft
Braço Da Articulação / Knuckle Arm
Ligação / Drag Link
Direcção Assistida / Tie Rod
Direcção Assistida / Direção Punho / Steering H Andle
Direcção / Steering
Tirant E / Lift Rod
Ligaca O Inferior / Lower Link
Ligaca O Superior / Top Link
Corren Te Seguranca / Check Chain
Grelha Frontal / Front Grille
Capot / Hood (Bonnet)
Painel Inferior / Panel Cover
Painel Lateral / Side Cover
Placa / Shutter Plate
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Acessorios / Seat
Degrau / Step
Cobertura / Tail Cover
Etiqueta Frente / Label(Front)
Etiqueta Traseira / Label(Rear)
Acessorios / Accessories And Service Parts
K It Luzes Trabalho (Opçao) / Warking Light Kit [Opti On]
F Ront Hitch Kit [Option] / Front Hitch Kit [Option]
H Ydraulic Port Kit [Option] / Hydraulic Port Kit [Op Tion]
E Scpae / Muffler
Ventilador / Fan
Dínamo / Dynamo
Comutador / Switch
T Ravão / Brake
Ligação / Drag Link
Direcção / Steering
Tirant E / Lift Rod
Acessorios / Seat
Degrau / Step
