Kubota Compact Tractor B1181DT-F2-EC-S5 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B1181DT-F2-EC-S5 Compact Tractor
Number of Pages: 183 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Arvore Cames E Veio / Camshaft And Idle Ge Ar Shaft
Piston E Cambota / Piston/Crankshaft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camsha Ft And Governor Shaft
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And G Low Plug
Bomba Gasoleo (Mecânica) / Fuel Pump (Mech Anical)
Polia De Accionamento Da Ventoinha / Fan D Rive Pulley
Bomba Agua E Termostacto / Water Flange An D Thermostat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Escpae / Muffler
Tubo Combustivel / F Uel Pipe
Filtro Gasoleo [Peça S Componentes] / Fuel Filter [Component Parts]
Ve Ntoinha / Fan
Tu Bo Agua / Water Pipe
Ra Diador / Radiator
De Posito Reserva / Reserve Tank
Alternador / Altern Ator
Alternador [Peças C Omponentes] / Alternator [Component Parts]
Motor Arranque / St Arter
Motor Arranque [Peç As Componentes] / Starter [Component Parts]
Interruptor / Cab I Nner Switch
Interruptor/Rele / Switch/Relay
Painel ・Interruptor / Panel Board And Switch
Farol Frente / Head Light
Farol Traseiro / Re Ar Lamp
Lampada / Winker La Mp
Farol Matricula / L Icense Lamp
Cablagem Electrica (Corpo) / Electrical Wiring (Body)
Embraiagem / Clutch
Embraiagem / Clutch Rod
Estrututa Frontal / Front Fra Me
Suporte Principal / Center Fr Ame
Roda Frente (4.50-10) / Front Wheel (4.50-10)
Roda Frente (5-12) / Front Wh Eel (5-12)
Roda Frente (20*8.00-10) / Fr Ont Wheel (20*8.00-10)
Roda Frente (20.5*8.00-10) / Front Wheel (20.5*8.00-10)
Roda Frente (6-12) / Front Wh Eel (6-12)
Carter Eixo Frente / Front Ax Le Case
Diferencial Dianteiro / Front Differential
Carter Grupo Conico / Bevel G Ear Case
Carter Eixo / Front Axle Case
Eixo Dianteiro / Front Axle
Veio Eixo / Front Wheel Drive Shaft
Caixa Da Transmissão / Transmi Ssion Case
Diferencial / Differential Gea R Case
Carter Eixo Traseiro Esq / Rea R Axle Case Lh
Carter Eixo Traseiro Drt / Rea R Axle Case Rh
Veio Primario / Propeller Shaf T
Veio Tdf / Pto Shaft
Tdf Central / Mid Pto
Grupo Conico / Range Gear
Diferencial Traseiro / Rear Di Fferential
Veio Tracao Dianteira / Front Propeller Shaft
1 Velocidade / 1st Shaft
2 Velocidade / 2nd Shaft
3 Velocidade / 3rd Shaft
Forqueta Velocidades / Range Gear Shift Fork
Alvanca Tdf / Pto Ge Ar Shift Fork
Bloqueio Diferencial De Forqueta / Rear Differential Lock Shift Fork
Eixo Traseiro Esquerda / Rear A Xle Lh
Eixo Traseiro Direita / Rear Ax Le Rh
Roda Traseira (7-16) / Rear Whe El (7-16)
Roda Traseira (8-16) / Rear Whe El (8-16)
Roda Traseira (215/80d-15) / Re Ar Wheel (215/80d-15)
Roda Traseira (29*12.00-15) / R Ear Wheel (29*12.00-15)
Roda Traseira (9.5-18) / Rear W Heel (9.5-18)
Travão / Brake
Tirante Travao / Brake Rod
Tirante / Main Gear Shift Rod
Alavanca Velocidades / Range Gear Sh Ift Lever
Alavamca De Controle / Hydraulic Con Trol Lever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differe Ntial Lock Pedal
Braço Da Articulação / Knuckle Arm
Ligação / Link,Drag
Direcção Assistida / Tie Rod
Direcção / Steering
Bomba Hidráulic A (Ps) / Hydraulic Pump (Ps)
Bomba Hidraulic O (Ps) [Peças Componentes] / Hydraulic Pump (Ps) [C Omponent Parts]
Bomba Hidraulic O / Hydraulic Pump
Bomba Hidraulic O [Peças Componentes] / Hydraulic Pump [Component Parts]
Linha Aspiração (Sucção) / Hydraulic Pipe (Suction)
Tubo Oleo (Entr Ega) / Hydraulic Pipe (Delivery)
Circuito Oleo ( Direcção) / Hydraulic Oil Line (Steering)
Cilindro Hidrau Lico (Elevador) / Hydraulic Cylinder
Válvula De Hidr Aulico [Peças Componentes] / Change Valve [Componen T Parts]
Piston Hidrauli Co / Braços / Hydraulic Lift Arm
Valvula Control [Peças Componentes] / Control Valve [Component Par Ts]
3-Pont Acoplamento (Tirante) / Lift Rod
Ligacao Inferior / Lower Link
Ligacao Superior / Top Link
Corrente Seguranca / Check Chain
Proteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Tampa Painel / Panel Cover
Painel Lateral / Side Cover
Placa / Shutter Plate
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Degrau / Step
Cobertura / Tail Cover
Cobertura Traseira / Rear Cover
Arco / Rops
Etiquetas / Labels
Acessorios E Peças Serviço / Accessories And Serv Ice Parts
Banco [Opçao] / Seat [Option]
Kit Luzes Trabalho [Opçao] / Working Light Kit [Option]
Puxo Dianteiro,Kit[Opção] / Front Hitch Ki T [Option]
Engate Traseiro (Opcao) / Rear Hitch Kit [ Option]
Kit Barra Reboque[Opcao] / Drawbar Kit [Op Tion]
Kit Pesos Rodas [Opçao] / Front Weight Kit [Option]
