Kubota Compact Tractor B1181DT-EC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B1181DT-EC Compact Tractor
Number of Pages: 191 Pages
Itens Usado S Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Piston E Cambota / Piston/Crankshaft
Volante Motor / Flywheel
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Glow Pl Ug
Bomba Gasoleo (Mecânica) / Fuel Pump (Mechanical )
Polia De Accionamento Da Ventoinha / Fan Drive P Ulley
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Escpae / Muffler
Deposito Combustivel / Fue L Tank
Tubo Combustivel / Fuel Pi Pe
Filtro Gasoleo [Peças Comp Onentes] / Fuel Filter [Component Parts]
Ventoinh A / Fan
Tubo Agu A / Water Pipe
Alternador / Alternator
Alternador [Peças Compone Ntes] / Alternator [Component Parts]
Motor Arranque / Starter
Interruptor / Cab Inner S Witch
Interruptor/Rele / Switch /Relay
Painel ・Interruptor / Panel Board And Switch
Painel [Peças Componentes ] / Panel [Component Parts]
Farol Frente / Head Light
Farol Traseiro / Rear Lam P
Lampada / Winker Lamp
Cablagem Electrica (Corpo ) / Electrical Wiring (Body)
Embraiagem / Clutch
Embraiagem / Clutch Rod
Estrututa Frontal / Front Frame
Roda Frente (4.50-10) / Front Wheel (4.50-10)
Roda Frente (5-12) / Front Wheel (5 -12)
Roda Frente (20*8.00-10) / Front Wh Eel (20*8.00-10)
Roda Frente (20.5*8.00-10) / Front Wheel (20.5*8.00-10)
Roda Frente (6-12) / Front Wheel (6 -12)
Carter Eixo Frente / Front Axle Cas E
Diferencial Dianteiro / Front Diffe Rential
Grupo Conico / Bevel Gear
Carter Grupo Conico / Bevel Gear Ca Se
Carter Eixo / Front Axle Case
Eixo Dianteiro / Front Axle
Veio Eixo / Front Wheel Drive Shaft
Caixa Da Transmissão / Transmission Case
Veio Tdf / Pto Shaft
Tdf Central / Mid Pto
Grupo Conico / Range Gear
Diferencial Traseiro / Rear Differen Tial
Veio Tracao Dianteira / Front Propel Ler Shaft
1 Velocidade / 1st Shaft
2 Velocidade / 2nd Shaft
3 Velocidade / 3rd Shaft
Forqueta Velocidades / Ran Ge Gear Shift Fork
Bloqueio Diferencial De Fo Rqueta / Rear Differential Lock Shift Fork
Roda Traseira (7-16) / Rear Wheel (7- 16)
Roda Traseira (8-16) / Rear Wheel (8- 16)
Roda Traseira (215/80d-15) / Rear Whe El (215/80d-15)
Roda Traseira (29*12.00-15) / Rear Wh Eel (29*12.00-15)
Roda Traseira (9.5-18) / Rear Wheel ( 9.5-18)
Travão / Brake
Tirante Travao / Brake Rod
Tirante / Main Gear Shift Rod
Alavanca Velocidades / Range Gear Shift Le Ver
Alavamca De Controle / Hydraulic Control L Ever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differential Lock Pedal
Braço Da Articulação / Knuckle Arm
Ligação / Link,Drag
Direcção Assistida / Tie Rod
Direcção / Steering
Bomba Hidráulica (Ps) / Hydraulic Pump (Ps)
Bomba Hidraulico (Ps) [Peças Componentes] / Hydraulic Pump (Ps) [Compone Nt Parts]
Bomba Hidraulico / Hy Draulic Pump
Bomba Hidraulico [Peç As Componentes] / Hydraulic Pump [Component Parts]
Linha Aspiração (Sucç Ão) / Hydraulic Pipe (Suction)
Tubo Oleo (Entrega) / Hydraulic Pipe (Delivery)
Circuito Oleo (Direcç Ão) / Hydraulic Oil Line (Steering)
Cilindro Hidraulico ( Elevador) / Hydraulic Cylinder
Válvula De Hidraulico [Peças Componentes] / Change Valve [Component Part S]
Piston Hidraulico / B Raços / Hydraulic Lift Arm
Valvula Control / Con Trol Valve
Valvula Control [Peça S Componentes] / Control Valve [Component Parts]
3- Pont Acoplamento (Tirante) / Lift Rod
Li Gacao Inferior / Lower Link
Li Gacao Superior / Top Link
Co Rrente Seguranca / Check Chain
Pu Xo Traseiro / Rear Hitch
Grelha Frontal / Front Grille
Tampa Painel / Panel Cover
Painel Lateral / Side Cover
Placa / Shutter Plate
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Degrau / Step
Cobertura / Tail Cover
Cobertura Traseira / Rear Cover
Arco / Rops
Etiquetas / Labels
Aces Sorios E Peças Serviço / Accessories And Service Pa Rts
Banco [Opçao] / Seat [Option]
Kit Luzes Trabalho [Opçao] / Working Light Kit [ Option]
Puxo Dianteiro,Kit[Opção] / Front Hitch Kit [Opt Ion]
Engate Traseiro (Opcao) / Rear Hitch Kit [Option ]
Kit Barra Reboque[Opcao] / Drawbar Kit [Option]
Kit Pesos Rodas [Opçao] / Front Weight Kit [Opti On]
Kit Espelho Rectrovisor / Rearview Mirror Kit [O Ption]
Carreto / Gear Case
Escpae / Muffler
Ventoinh A / Fan
Embraiagem / Clutch
Travão / Brake
Ligação / Link,Drag
Direcção / Steering
Degrau / Step
Arco / Rops
Etiquetas / Labels
