Kubota Compact Tractor B1121D Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B1121D Compact Tractor
Number of Pages: 145 Pages
Itens Usados Fr Equentemente / Frequently Used Items
B Loco Motor / Crankcase
C Arter Oleo / Oil Pan
C Abeça Motor / Cylinder Head
C Arreto / Gear Case
T Ampa Cabeça / Head Cover
F Iltro Oleo / Oil Filter
V Areta Nivel E Guia / Dipstick And Guide
B Omba Oleo / Oil Pump
R Olamento Principal / Main Bearing Case
P Iston E Cambota / Piston/Crankshaft
V Olante Motor / Flywheel
V Eio Combustivel E Regulador / Fuel Camshaft And Gov Ernor Shaft
P Onto Neutro / Idle Apparatus
B Omba Injectora / Injection Pump
R Egulador / Governor
R Egulador Velocidade / Speed Control Plate
V Ela Pre Aquecimento / Nozzle Holder And Glow Plug
S Uporte Bico [Peças Componentes] / Nozzle Holder [Co Mponent Parts]
B Omba Gasoleo (Mecânica) / Fuel Pump (Mechanical)
B Omba Agua / Water Pump
V Alvula E Veio Martelos / Valve And Rocker Arm
C Olector Escape / Exhaust Manifold
F Iltro Ar / Air Cleaner
E Scpae / Muffler
K It Juntas Inferior / Lower Gasket Kit
A Celarador Mao / Hand Accelerator Lever
P Edal Acelarador / Accelerator Pedal
Deposito Combustivel / Fuel Ta Nk
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo [Peças Componen Tes] / Fuel Filter [Component Parts]
Ventoinha / Fan
Tubo Agua / Water Pipe
Radiador / R Adiator
Valvula Solenoide / Stop Sole Noid
Dínamo / Dynamo
Motor Arranque / Starter
Interruptor / Cab Inner Switc H
Interruptor/Rele / Relay
Painel [Peças Componentes] / Panel [Component Parts]
Farol Frente / Head Light
Cablagem Electrica (Corpo) / Electrical Wiring (Body)
Embraiagem / Clutch
Embraiagem / Clutch Rod
Estrututa Frontal / Front Frame
Caixa Da Transmissão / Transmission Case
Carter Eixo / Rear Axle Case
Grupo Conico / Range Gear
Diferencial Traseiro / Rear Differential
Veio Tracao Dianteira / Front Propeller Shaft
1 Velocidade / 1st Shaft
2 Velocidade / 2nd Shaft
3 Velocidade / 3rd Shaft
Forqueta / Main Gear Shift For K
Forqueta Velocidades / Range G Ear Shift Fork
Alvanca Tdf / Pto Gear Shift F Ork
Bloqueio Diferencial De Forque Ta / Rear Differential Lock Shift Fork
Tirante / Main Gear Shift Rod
Alavanca Velocidades / Range G Ear Shift Lever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / D Ifferential Lock Pedal
Eixo Traseiro / Rear Axle
Roda Traseira (7-16) / Rear Wheel (7-16)
Roda Traseira (8-16) / Rear Wheel (8-16)
T Ravão / Brake
T Irante Travao / Brake Rod
T Ravao Parque / Parking Brake Lever
Roda Frente (4,50-10) / Front Wheel (4 .50-10)
Roda Frente (5-12) / Front Wheel (5-12 )
Diferencial Dianteiro / Front Different Ial
Grupo Conico / Bevel Gear
Carter Eixo / Front Axle Case
Eixo Dianteiro / Front Axle
Veio Eixo / Front Wheel Drive Shaft
Braço Da Articulação / Knuckle Arm
Ligação / Link,Drag
Direcção Assistida / Tie Rod
Direcção / Steering
Bomba Hidraulico [Peças Compo Nentes] / Hydraulic Pump [Component Parts]
Linha Aspiração (Sucção) / Hy Draulic Pipe (Suction)
Tubo Oleo (Entrega) / Hydraul Ic Pipe (Delivery)
Cilindro Hidraulico (Elevador ) / Hydraulic Cylinder
Válvula De Hidraulico[Peças C Omponentes] / Hydraulic Valve [Component Parts]
Piston Hidraulico / Braços / Hydraulic Lift Arm
Valvula Control / Control Val Ve
Valvula Control [Peças Compon Entes] / Control Valve [Component Parts]
3-Pont Acoplamento (Tirante) / Lift Rod
Ligaca O Inferior / Lower Link
Ligaca O Superior / Top Link
Corren Te Seguranca / Check Chain
Grelha Frontal / Front Grille
Tampa Painel / Panel Cover
Painel Lateral / Side Cover
Placa / Shutter Plate
Guarda Lamas / Fender
Degrau / Step
Cobertura / Tail Cover
Etiquetas / Labels
Acessori Os E Peças Serviço / Accessories And Service Parts
K It Luzes Trabalho [Opçao] / Working Light Kit [Opti On]
P Uxo Dianteiro,Kit[Opção] / Front Hitch Kit [Option]
E Scpae / Muffler
Ventoinha / Fan
Dínamo / Dynamo
Embraiagem / Clutch
T Ravão / Brake
Ligação / Link,Drag
Direcção / Steering
Degrau / Step
Etiquetas / Labels
