Kubota Compact Tractor B1121D-S5 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B1121D-S5 Compact Tractor
Number of Pages: 156 Pages
Itens Usados Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Arvore Cames E Veio / Camshaft And Idle Gear Shaf T
Piston E Cambota / Piston/Crankshaft
Volante Motor / Flywheel
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Glow Plu G
Bomba Gasoleo (Mecânica) / Fuel Pump (Mechanical)
Bomba Agua E Termostacto / Water Flange And Therm Ostat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Escpae / Muffler
Tubo Combustivel / Fuel Pip E
Filtro Gasoleo [Peças Compo Nentes] / Fuel Filter [Component Parts]
Ventoinha / Fan
Tubo Agua / Water Pipe
Valvula Solenoide / Stop S Olenoid
Dínamo / Dynamo
Dinamo [Peças Componentes] / Dynamo [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Comp Onentes] / Starter [Component Parts]
Interruptor / Cab Inner Sw Itch
Interruptor/Rele / Relay
Painel ・Interruptor / Panel Board/Switch
Painel [Peças Componentes] / Panel [Component Parts]
Farol Frente / Head Light
Cablagem Electrica (Corpo) / Electrical Wiring (Body)
Embraiagem / Clutch
Embraiagem / Clutch Rod
Estrututa Frontal / Front Frame
Caixa Da Transmissão / Transmission C Ase
Carter Eixo / Rear Axle Case
Veio Tdf / Pto Shaft
Grupo Conico / Range Gear
Diferencial Traseiro / Rear Different Ial
Veio Tracao Dianteira / Front Propell Er Shaft
1 Velocidade / 1st Shaft
2 Velocidade / 2nd Shaft
3 Velocidade / 3rd Shaft
Forqueta Velocidades / Rang E Gear Shift Fork
Alvanca Tdf / Pto Gear Shif T Fork
Bloqueio Diferencial De For Queta / Rear Differential Lock Shift Fork
Tirante / Main Gear Shift R Od
Alavanca Velocidades / Rang E Gear Shift Lever
Alavanca Tdf / Pto Gear Shi Ft Lever
Alavamca De Controle / Hydr Aulic Control Lever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differential Lock Pedal
Eixo Traseiro / Rear Axle
Roda Traseira (7-16) / Rear Wheel (7- 16)
Roda Traseira (8-16) / Rear Wheel (8- 16)
Travão / Brake
Tirante Travao / Brake Rod
Roda Frente (4,50-10) / Front Wheel (4.50-10)
Roda Frente (5-12) / Front Wheel (5 -12)
Diferencial Dianteiro / Front Differ Ential
Grupo Conico / Bevel Gear
Carter Grupo Conico / Bevel Gear Cas E
Carter Eixo / Front Axle Case
Eixo Dianteiro / Front Axle
Veio Eixo / Front Wheel Drive Shaft
Braço Da Articulação / Knuckle Arm
Ligação / Link,Drag
Direcção Assistida / Tie Rod
Direcção / Steering
Bomba Hidraulico / Hydraul Ic Pump
Bomba Hidraulico [Peças Co Mponentes] / Hydraulic Pump [Component Parts]
Linha Aspiração (Sucção) / Hydraulic Pipe (Suction)
Tubo Oleo (Entrega) / Hydr Aulic Pipe (Delivery)
Cilindro Hidraulico (Eleva Dor) / Hydraulic Cylinder
Válvula De Hidraulico[Peça S Componentes] / Hydraulic Valve [Component Parts]
Piston Hidraulico / Braços / Hydraulic Lift Arm
Valvula Control [Peças Com Ponentes] / Control Valve [Component Parts]
3-P Ont Acoplamento (Tirante) / Lift Rod
Lig Acao Inferior / Lower Link
Lig Acao Superior / Top Link
Cor Rente Seguranca / Check Chain
Pux O Traseiro / Rear Hitch
Grelha Frontal / Front Grille
Tampa Painel / Panel Cover
Placa / Shutter Plate
Guarda Lamas / Fender
Degrau / Step
Cobertura / Tail Cover
Etiquetas / Labels
Acess Orios E Peças Serviço / Accessories And Service Par Ts
Kit Luzes Trabalho [Opçao] / Working Light Kit [O Ption]
Puxo Dianteiro,Kit[Opção] / Front Hitch Kit [Opti On]
Carreto / Gear Case
Escpae / Muffler
Ventoinha / Fan
Dínamo / Dynamo
Embraiagem / Clutch
Travão / Brake
Ligação / Link,Drag
Direcção / Steering
Degrau / Step
Etiquetas / Labels
