Kubota Compact Tractor B1121D-F2-EC-S5 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B1121D-F2-EC-S5 Compact Tractor
Number of Pages: 187 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Arvore Cames E Veio / Camshaft And Idle Gea R Shaft
Piston E Cambota / Piston/Crankshaft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaf T And Governor Shaft
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Gl Ow Plug
Suporte Bico [Peças Componentes] / Nozzle H Older [Component Parts]
Bomba Gasoleo (Mecânica) / Fuel Pump (Mecha Nical)
Polia De Accionamento Da Ventoinha / Fan Dr Ive Pulley
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Escpae / Muffler
Tubo Combustivel / Fu El Pipe
Filtro Gasoleo [Peças Componentes] / Fuel Filter [Component Parts]
Ven Toinha / Fan
Tub O Agua / Water Pipe
Rad Iador / Radiator
Dep Osito Reserva / Reserve Tank
Alternador / Alterna Tor
Alternador [Peças Co Mponentes] / Alternator [Component Parts]
Motor Arranque / Sta Rter
Motor Arranque [Peça S Componentes] / Starter [Component Parts]
Interruptor / Cab In Ner Switch
Interruptor/Rele / S Witch/Relay
Painel ・Interruptor / Panel Board And Switch
Painel [Peças Compon Entes] / Panel [Component Parts]
Farol Frente / Head Light
Farol Traseiro / Rea R Lamp
Lampada / Winker Lam P
Farol Matricula / Li Cense Lamp
Cablagem Electrica ( Corpo) / Electrical Wiring (Body)
Embraiagem / Clutch
Suporte Principal / Center Fra Me
Roda Frente (4.50-10) / Front Wheel (4.50-10)
Roda Frente (5-12) / Front Whe El (5-12)
Roda Frente (20*8.00-10) / Fro Nt Wheel (20*8.00-10)
Roda Frente (20.5*8.00-10) / F Ront Wheel (20.5*8.00-10)
Roda Frente (6-12) / Front Whe El (6-12)
Carter Eixo Frente / Front Axl E Case
Diferencial Dianteiro / Front Differential
Grupo Conico / Bevel Gear
Carter Grupo Conico / Bevel Ge Ar Case
Carter Eixo / Front Axle Case
Eixo Dianteiro / Front Axle
Veio Eixo / Front Wheel Drive Shaft
Caixa Da Transmissão / Transmis Sion Case
Veio Tdf / Pto Shaft
Grupo Conico / Range Gear
Diferencial Traseiro / Rear Dif Ferential
Veio Tracao Dianteira / Front P Ropeller Shaft
1 Velocidade / 1st Shaft
2 Velocidade / 2nd Shaft
Forqueta Velocidades / Range Gear Shift Fork
Alvanca Tdf / Pto Gea R Shift Fork
Bloqueio Diferencial De Forqueta / Rear Differential Lock Shift Fork
Eixo Traseiro Esquerda / Rear Ax Le Lh
Eixo Traseiro Direita / Rear Axl E Rh
Roda Traseira (7-16) / Rear Whee L (7-16)
Roda Traseira (8-16) / Rear Whee L (8-16)
Roda Traseira (215/80d-15) / Rea R Wheel (215/80d-15)
Roda Traseira (29*12.00-15) / Re Ar Wheel (29*12.00-15)
Roda Traseira (9.5-18) / Rear Wh Eel (9.5-18)
Travão / Brake
Tirante Travao / Brake Rod
Tirante / Main Gear Shift Rod
Alavanca Velocidades / Range Gear Shi Ft Lever
Alavamca De Controle / Hydraulic Cont Rol Lever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differen Tial Lock Pedal
Braço Da Articulação / Knuckle Arm
Ligação / Link,Drag
Direcção Assistida / Tie Rod
Direcção / Steering
Bomba Hidraulico [Peças Componentes] / Hydraulic Pump [Component Pa Rts]
Linha Aspiração (Sucção) / Hydraulic Pipe (Suction)
Tubo Oleo (Entre Ga) / Hydraulic Pipe (Delivery)
Cilindro Hidraul Ico (Elevador) / Hydraulic Cylinder
Válvula De Hidra Ulico [Peças Componentes] [Opção] / Change Valve [C Omponent Parts]
Piston Hidraulic O / Braços / Hydraulic Lift Arm
Valvula Control [Peças Componentes] / Control Valve [Component Part S]
3-Pont Acoplamento (Tirante) / Lift Rod
Ligacao Inferior / Lower Link
Ligacao Superior / Top Link
Puxo Traseiro / Rear Hitch
Proteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Tampa Painel / Panel Cover
Painel Lateral / Side Cover
Placa / Shutter Plate
Guarda Lamas / Fender
Degrau / Step
Cobertura / Tail Cover
Cobertura Traseira / Rear Cover
Arco / Rops
Etiquetas / Labels
Acessorios E Peças Serviço / Accessories And Servi Ce Parts
Banco [Opçao] / Seat [Option]
Kit Luzes Trabalho [Opçao] / Working Light Kit [Option]
Puxo Dianteiro,Kit[Opção] / Front Hitch Kit [Option]
Engate Traseiro (Opcao) / Rear Hitch Kit [O Ption]
Kit Barra Reboque[Opcao] / Drawbar Kit [Opt Ion]
Kit Pesos Rodas [Opçao] / Front Weight Kit [Option]
Carreto / Gear Case
Escpae / Muffler
Ven Toinha / Fan
Embraiagem / Clutch
Travão / Brake
Ligação / Link,Drag
Direcção / Steering
Degrau / Step
Arco / Rops
Etiquetas / Labels
