Kubota Compact Tractor B1121D-EC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B1121D-EC Compact Tractor
Number of Pages: 176 Pages
Itens Usados Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Piston E Cambota / Piston/Crankshaft
Volante Motor / Flywheel
Ponto Neutro / Idle Apparatus
Bomba Gasoleo (Mecânica) / Fuel Pump (Mechanical)
Polia De Accionamento Da Ventoinha / Fan Drive Pu Lley
Bomba Agua E Termostacto / Water Flange And Therm Ostat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Escpae / Muffler
Tubo Combustivel / Fuel Pip E
Filtro Gasoleo [Peças Compo Nentes] / Fuel Filter [Component Parts]
Ventoinha / Fan
Tubo Agua / Water Pipe
Valvula Solenoide / Stop S Olenoid
Alternador / Alternator
Alternador [Peças Componen Tes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Comp Onentes] / Starter [Component Parts]
Interruptor / Cab Inner Sw Itch
Interruptor/Rele / Switch/ Relay
Painel ・Interruptor / Panel Board And Switch
Painel [Peças Componentes] / Panel [Component Parts]
Farol Frente / Head Light
Farol Traseiro / Rear Lamp
Lampada / Winker Lamp
Cablagem Electrica (Corpo) / Electrical Wiring (Body)
Embraiagem / Clutch
Embraiagem / Clutch Rod
Estrututa Frontal / Front Frame
Roda Frente (4.50-10) / Front Wheel (4.50-10)
Roda Frente (5-12) / Front Wheel (5- 12)
Roda Frente (20*8.00-10) / Front Whe El (20*8.00-10)
Roda Frente (20.5*8.00-10) / Front W Heel (20.5*8.00-10)
Roda Frente (6-12) / Front Wheel (6- 12)
Diferencial Dianteiro / Front Differ Ential
Grupo Conico / Bevel Gear
Carter Grupo Conico / Bevel Gear Cas E
Carter Eixo / Front Axle Case
Eixo Dianteiro / Front Axle
Veio Eixo / Front Wheel Drive Shaft
Caixa Da Transmissão / Transmission C Ase
Veio Tdf / Pto Shaft
Grupo Conico / Range Gear
Diferencial Traseiro / Rear Different Ial
Veio Tracao Dianteira / Front Propell Er Shaft
1 Velocidade / 1st Shaft
2 Velocidade / 2nd Shaft
3 Velocidade / 3rd Shaft
Forqueta Velocidades / Rang E Gear Shift Fork
Alvanca Tdf / Pto Gear Shif T Fork
Bloqueio Diferencial De For Queta / Rear Differential Lock Shift Fork
Roda Traseira (7-16) / Rear Wheel (7-1 6)
Roda Traseira (8-16) / Rear Wheel (8-1 6)
Roda Traseira (215/80d-15) / Rear Whee L (215/80d-15)
Roda Traseira (29*12.00-15) / Rear Whe El (29*12.00-15)
Roda Traseira (9.5-18) / Rear Wheel (9 .5-18)
Travão / Brake
Tirante Travao / Brake Rod
Tirante / Main Gear Shift Rod
Alavanca Velocidades / Range Gear Shift Lev Er
Alavamca De Controle / Hydraulic Control Le Ver
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differential L Ock Pedal
Braço Da Articulação / Knuckle Arm
Ligação / Link,Drag
Direcção Assistida / Tie Rod
Direcção / Steering
Bomba Hidraulico / Hyd Raulic Pump
Bomba Hidraulico [Peça S Componentes] / Hydraulic Pump [Component Parts]
Tubo Oleo (Entrega) / Hydraulic Pipe (Delivery)
Cilindro Hidraulico (E Levador) / Hydraulic Cylinder
Válvula De Hidraulico [Peças Componentes] [Opção] / Change Valve [Compone Nt Parts]
Piston Hidraulico / Br Aços / Hydraulic Lift Arm
Valvula Control / Cont Rol Valve
Valvula Control [Peças Componentes] / Control Valve [Component Parts]
Lig Acao Inferior / Lower Link
Lig Acao Superior / Top Link
Pux O Traseiro / Rear Hitch
Pro Teccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Tampa Painel / Panel Cover
Painel Lateral / Side Cover
Placa / Shutter Plate
Guarda Lamas / Fender
Degrau / Step
Cobertura / Tail Cover
Cobertura Traseira / Rear Cover
Arco / Rops
Etiquetas / Labels
Acess Orios E Peças Serviço / Accessories And Service Par Ts
Banco [Opçao] / Seat [Option]
Kit Luzes Trabalho [Opçao] / Working Light Kit [O Ption]
Puxo Dianteiro,Kit[Opção] / Front Hitch Kit [Opti On]
Engate Traseiro (Opcao) / Rear Hitch Kit [Option]
Kit Barra Reboque[Opcao] / Drawbar Kit [Option]
Kit Barra Reboque[Opcao] / Drawbar Kit [Option] # # [Ec,B1] / [Ec,B1]
Kit Pesos Rodas [Opçao] / Front Weight Kit [Optio N]
Kit Espelho Rectrovisor / Rearview Mirror Kit [Op Tion]
