Kubota Carrier KC70 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Carrier
Model: Kubota KC70 Carrier
Number of Pages: 54 Pages
Cu Lasse / Cylinder Head
Fi Lter A Air / Air Cleaner
Si Lencieux / Muffler
Cu Lbuteur, Couvercle De Culasse / Rocker Arm,Cylinder Head Cover
Ar Bre A Cames / Camshaft
Pi Stons, Vilebrequin / Piston, Crankshaft
Po Mpe Ahuile / Oil Pump
Re Froidisseur D'huile / Oil Cooler
Po Mpe D'injection / Injection Pump
Po Rte-Injecteur (Parties Composantes) / Nozzle Holder (Component Parts
Re Gulateur / Governor Lever
Pl Aque De Limiteur De Vitesse / Speed Control Plate
Vo Lant De Moteur, Demarreur / Flywheel, Starter
De Marreur (Parties Composantes) / Starter (Component Parts)
Fi Ltre A Combustible, Parties Composantes / Fuel Filt Er Component Parts
Ac Cessoires / Accessories
Chassis, Couvercle De Moteur / Frame, Engine Cover
Chassis, Couvercle De Moteur (No. De Série -00271) / Frame, Engine Cover (Serial No. -000271)
Chassis, Couvercle De Moteur (No. De Série 00272-) / Frame, Engine Cover (Serial No. 000272-)
Tableau D'autorite, Pare-Choce / Control Panel, Bum Per
Console De Moteur, Silencieux / Engine Base, Muffle R
Poulie / Pulley
Poulie / Pulley
Poulie / Pulley
Hydraulique Pompe, Cylindre / Hydraulic Pump, Cylin Der
Levier / Side Clutch Lever
Levier De Changement / Speed Change Lever
Levier D'embrayage, Levier De Frein / Clutch Lever, Brake Lever
Godet, Levier D'accelerateur / Bucket, Accel Lever
Chenille De Coutchouc / Rubber Crawler
Hydraulique Pompe (Parties Composantes) / Hydraulic Pump (Component Parts)
Transmission (Component Parts 1) (Serial No. -000 103) / Transmission (Component Parts 1) (Serial N O. -000103)
Transmission (Component Parts 1) (Serial No. 0001 04-) / Transmission (Component Parts 1) (Serial N O. 000104-)
Mission (Parties Composantes 2) / Transmission (Com Ponent Parts 2)
Mission (Parties Composantes 3) / Transmission (Com Ponent Parts 3)
Reservoir Carb. / Fuel Tank
Faisceau Electrique, Metre, Interrupteur / Wire Har Ness, Meter, Switch, Battery
Etiquette / Label
Etiquette / Label
Eponge, Equilibrage / Sponge, Trim
Arceau / Rops
