Kubota Carrier KC70-H KC70-SL KC70-HD KC70-4 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Carrier
Model: Kubota KC70-H ; KC70-SL ; KC70-HD ; KC70-4 Carrier
Number of Pages: 62 Pages
Chenilles Caoutchouc Et Composants / Rubber Crawler And Components
Cadre Chenille / Crawler Frame
Chassis Principale / Body Frame
Chassis Operateur / Operator Frame
Accouplement Pompe Hydraulique / Hy Draulic Pump Coupling
Circuit Pompe Hydraulique / Hydraul Ic Oil Line Pump
Chassis Benne / Bucket Frame
Circuit Hydraulique Translation / H Ydraulic Oil Line Translation
Version Hi Tip / Hi Tip Version
Version Auto Charge / Self Loading Version
Système Hydraulique Refoulement Et Retour / Delivery And Return Hydraulic System
Système Hydraulique Traction Extens Ion / Traction And Expansion Hydraulic System
Système Hydraulique Traction Extens Ion Version Sl / Traction And Expansion Hydraulic S Ystem Sl Version
Système Hydraulique / Hydraulic Sys Tem
Distributeur Hydraulique / Hydrauli C Control Valve
Système Hydraulique Version Hi Tip / Hydraulic System Hi Tip Version
Système Hydraulique Version Sl / H Ydraulic System Sl Version
Faisceau Electrique / Wire Harness
Composants Electricite 1 / Electric Al Component 1
Autocolant 1 / Stickers 1
Autocolant 2 / Stickers 2
Visserie / Fitting Parts 1
Raccord Hydraulique / Fitting Parts 2
Carter Moteur / Crankcase
Culasse / Cylinder Head
Filtre A Air / Air Cleaner
Silencieux / Muffler
Culbuteurs / Rocker Arm
Arbre A Cames / Camshaft
Pistons Et Vilebrequin / Piston And Cranks Haft
Pompe A Huile / Oil Pump
Refroidisseur / Oil Cooler
Pompe D'injection(Parties Composantes) / I Njection Pump(Component Parts)
Injecteuss Et Tuyauteries(Parties Composan Tes) / Nozzle Holder(Component Parts)
Regulateur De Regime / Governor
Limiteur De Vitesse / Speed Control
Volant Moteur / Flywheel
Demarreur(Parties Composantes) / Starter(C Omponent Parts)
Accessoires Et Pieces De Service(1) / Acce Ssories And Service Parts(1)
Accessoires Et Pieces De Service(2) / Acce Ssories And Service Parts(2)
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
