Kubota Carrier KC250HR Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Carrier
Model: Kubota KC250HR Carrier
Number of Pages: 134 Pages
Bloque Motor / Crank Case
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Varilla De Nivbl Y Guia / Dipstick And Guide
Aceite Bomba / Oil Pump
Volante / Flywheel
Motor Parar Palanca / Engine Stop Lever
Bomba Inyección / Injection Pump
Placa De Control De Velocidad / Speed Control Plate
Separador / Separator
Alternador Y Polea / Alternator And Pulley
Alternador(Componente Piezas) / Alternator (Component Parts)
Motor De Arranque / Starter
Motor De Arranque(Componente Piezas) / Starter (Component Parts)
Manocontacto De Aceite Y Tapon / Oil Switch And Plug
Agua Bomba / Water Pump
Ventilador / Fan
Del Operador Manual / Operator's Manual
Motor Control / Engine Control
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Electrico Piezas / Electrical Parts
Bastidor / Frame
Secundario Bastidor / Sub Frame
Motor Cubierta / Engine Cover
Lado Cubierta / Side Cover
Guardia / Guard
Accionar Motor / Drive Motor
Tren De Orugas Rodillo / Track Roller
Tren De Orugas Rodillo [Componente Piezas] 1 / Track Roller [Component Parts] 1
Tren De Orugas Rodillo [Componente Piezas] 2 / Track Roller [Component Parts] 2
Superior Tren De Orugas Rodillo / Upper Track Roller
Rueda Loca / Idler
Motor Control / Control Lever And Seat
Control Varilla / Control Rod
Carro / Wagon
Etiqueta / Label
Accesorios / Accessories
Aceite Deposito / Oil Tank
Hidraulico Aceite Linea 1 / Hydraulic Oil Line 1
Hidraulico Aceite Linea 2 / Hydraulic Oil Line 2
Cilindro [Componente Piezas] / Cylinder [Component Parts]
Arco De Seguridad 1[Opcion] / Rops
