Kubota Carrier KC121H Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Carrier
Model: Kubota KC121H Carrier
Number of Pages: 71 Pages
Carter A Huile / Oi L Pan
Culasse / Cylinder Head
(-4z9999)
(5a0001-)
Couvercle De Culass E / Cylinder Head Cover
Paliers De Vilebreq Uin / Main Bearing Case
Arbre A Cames / Cam Shaft
Pistons Vilebrequi N / Piston Crankshaft
Volant Moteur / Fly Wheel
Arbre A Cames / Fue L Camshaft
(-4z 9999)
(-4z 9999)
(5a0 001-)
(5a0 001-)
Pompe D'injection Pompe / Injection Pump Fuel Pump
Regulateur De Regim E / Governor
Porte-Injecteur Bo Ug De Pre-Chauff / Nozzle Holder Glow Plug
Porte-Injecteur ( Parties Composantes ) / Nozzle Holder ( Component P Arts )
Filtre A Combustibl E Parties Composantes / Fuel Filter Component Part S
(-2k9999)
(2l0001-)
Dynamo ( Parties Co Mposantes ) / Dynamo ( Component Parts )
Demarreur Demarreu R ( Parties Composantes ) / Starter Starter ( Comp Onent Parts )
Bride A Eau Pompe A Eau / Water Flange Water Pump
Rese Rve Tank
Clapet Culbuteur / Valve Rocker Arm
Collecteur / Inlet Manifold Exhaust Manifold
Filtre A Air (Part Ies Composantes) / Air Cleaner (Component Parts)
Accessories / Acces Sories
Chassis / Frame
Couvercle De Moteur / Engine Cover
Console De Moteur Silencieux Base De Radiateur / Engine Base Muffle R Radiator Base
Poulie / Pulley
Poulie / Pulley
Levier D'embrayage Lateral Levier D'accelerateur / Side Clutch Lever Accelerator Lever
(-0082)
(0083-)
Levier D'embrayage Levier De Frein / Clutch Lever Brake Lever
Hydraulique Pompe Cylindre Levier De Decharge / Hydraulic Pump Cyli Nder Dump Lever
Hst Reservoir A Hu Le Huike / Hst Oil Tank Oil Cooler
Carrosserie / Body
Support / Holder
Support / Holder
Poulie D'intermedia Ire / Idler Wheel
Chenille De Coutcho Uc Tension Rouleau / Rubber Crawler Tension Rolle R
Hydraulique Pompe (Parties Composantes ) / Hydraulic Pump (Component Parts )
Hst (Parties Compo Santes 1) / Hst (Component Parts 1)
Hst (Parties Compo Santes 2) / Hst (Component Parts 2)
Mission (Parties C Omposantes 1) / Transmission (Component Parts 1)
Mission (Parties C Omposantes 2) / Transmission (Component Parts 2)
Mission (Parties C Omposantes 3) / Transmission (Component Parts 3)
Mission (Parties C Omposantes 4) / Transmission (Component Parts 4)
Mission (Parties C Omposantes 5) / Transmission (Component Parts 5)
Reservoir A Carbura Nt Pompe D'alimentation / Fuel Tank Fuel Pump
Battery
Etiquette / Label
Eponge Equilibrage / Sponge Trim
(-4z9999)
(5a0001-)
(-4z 9999)
(-4z 9999)
(5a0 001-)
(5a0 001-)
(-2k9999)
(2l0001-)
Rese Rve Tank
Chassis / Frame
Poulie / Pulley
Poulie / Pulley
(-0082)
(0083-)
Carrosserie / Body
Support / Holder
Support / Holder
Battery
Etiquette / Label
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
