Kubota Carrier KC121 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Carrier
Model: Kubota KC121 Carrier
Number of Pages: 63 Pages
B Loc Moteur / Crankcase
C Ulasse / Cylinder Head
C Arter De Distribution / Gear Case
P Aliers De Vilebrequin / Main Bearing Case
R Eniflard / Breather
F Iltre A Air / Air Cleaner
S Oupapes Et Culbuteurs / Valve,Rocker Arm
C Ouvercle De Culasse / Cylinder Head Cover
A Rbre A Cames / Camshaft
P Istons Et Vilebrequin / Piston,Crankshaft
V Olant Moteur / Flywheel
D Emarreur Parties Composantes / Starter Component Pa Rts
P Ompe D'injection / Injection Pump
P Ompe D'injection Parties Composantes / Injection Pu Mp Component Parts
P Orte-Injecteur Parties Composantes / Nozzle Holder Component Parts
R Egulateur De Regime / Governor
R Adiateur / Radiator
V Entilateur / Fan
V Entilateur / Fan
F Iltre A Combustible Parties Composantes / Fuel Filt Er Component Parts
A Ccessoires / Accessories
Chassis / Frame
Chassis / Frame
Tableau D'autorite / Control Panel
Couvercle De Moteur / Engine Cover
Poulie / Pulley
Poulie / Pulley
Hydraulique Pompe Et Cylindre / Hydraulic Pump And Cylinder
Levier D'embrayage Lateral / Side Clutch Lever
Levier D'embrayage Et Levier De Frein / Clutch Lev Er And Brake Lever
Pedale D'embrayage / Clutch Pedal
Levier De Changement / Speed Change Lever
Carrosserie / Body
Support / Holder
Poulie D'intermediaire / Idler Wheel
Chenille De Coutchouc / Rubber Crawler
Hydraulique Pompe Parties Composantes 1 / Hydrauli C Pump Component Parts 1
Hydraulique Pompe Parties Composantes 2 / Hydrauli C Pump Component Parts 2
Hydraulique Pompe Parties Composantes 3 / Hydrauli C Pump Component Parts 3
Mission Parties Composantes 1 / Mission Component Parts 1
Mission Parties Composantes 2 / Mission Component Parts 2
Mission Parties Composantes 4 / Mission Component Parts 4
Mission Parties Composantes 5 / Mission Component Parts 5
Batterie / Battery
Faisceau Electrique/Metre/Interrupteur / Wire Harn Ess/Meter/Switch
Silencieux / Muffler
Etiquette / Label
Etiquette / Label
Eponge / Sponge
