Kubota Carrier KC120 00001- Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Carrier
Model: Kubota KC120 Carrier
Serial Number: 00001-
Number of Pages: 75 Pages
Content
Carter Moteur / Crankcase
Carter A Huile / Oil Pan
Culasse / Cylinder Head
Couvercle De Culasse / Cylinder Head Co Ver
Paliers De Vilebrequin / Main Bearing C Ase
Arbre A Cames / Camshaft
Pistons, Vilebrequin / Piston, Cranksha Ft
Volant Moteur / Flywheel
Arbre A Cames / Fuel Camshaft
Plaque De Limiteur De Vitesse / Speed C Ontrol Plate
Butte De Ralenti / Assy Apparatus, Idle
Pompe D'injection, Pompe / Inpection Pu Mp, Fuel Pump
Regulateur De Regime / Governor
Porte-Injecteur, Boug De Pre-Chauff / N Ozzle Holder, Glow Plug
Porte-Injecteur (Parties Composantes) / Nozzle Holder (Component Parts)
Filtre A Combustible, Parties Composant Es / Fuel Filter Component Parts
Dynamo / Dynamo
Dynamo / Dynamo
Dynamo (Parties Composantes) / Dynamo ( Component Parts)
Demarreur, Demarreur (Parties Composant Es) / Starter, Starter (Component Parts)
Bride A Eau, Pompe A Eau / Water Flange , Water Pump
Radiateur / Radiator
Clapet, Culbuteur / Valve, Rocker Arm
Collecteur / Inlet Manifold, Exhaust Ma Nifold
Filtre A Air (Parties Composantes) / A Ir Cleaner (Component Parts)
Hydraulique Pompe (Parties Composantes ) / Hydraulic Pump (Component Parts)
Ens, Coussinet / Kit Metal, Engine
Accessories / Accessories
Chassis / Frame
Tableau D'autorite / Panel, Cont Rol
Couvercle De Moteur / Engine Cov Er
Siege / Seat
Console De Moteur / Engine Base
Reservoir A Carburant / Fuel Tan K
Base De Radiateur / Base, Radiat Or
Dynamo / Dynamo
Filtre A Air , Silencieux / Air Cleaner , Muffler
Poulie, Hst / Pulley, Hst
Hst, Reservoir A Hule / Hst, Oil Tank
Distributeur / Control Valve
Actionnement De La Pédale / Driv E Pedal
Courroir D'entrainement / V-Belt , Drive
Levier D'embrayage Lateral / Sid E Clutch Lever
Lever D’accelerateur / Accelerato R Lever
Bremsenpedal / Brake Pedal
Levier De Decharge, Cylindre / D Ump Lever, Cylinder
Carrosserie / Body
Support / Holder
Chenille De Coutchouc / Rubber C Rawler
Poulie D'intermediaire 1 / Idler Wheel 1
Poulie D'intermediaire 2 / Idler Wheel 2
Hst (Parties Composantes ) / Hs T (Component Parts )
Mission (Parties Composantes 1 ) / Transmission (Component Parts 1)
Mission (Parties Composantes 2 ) / Transmission (Component Parts 2)
Mission (Parties Composantes 3 ) / Transmission (Component Parts 3)
Mission (Parties Composantes 4 ) / Transmission (Component Parts 4)
Cable, Batterie / Cord, Battery
Faisceau Electrique 1 / Wire Har Ness 1
Faisceau Electrique 2 / Wire Har Ness 2
Etiquette / Label
Eponge / Sponge
Eponge / Sponge
Rops / Rops
Rops / Rops
Content
Dynamo / Dynamo
Dynamo / Dynamo
Chassis / Frame
Siege / Seat
Dynamo / Dynamo
Carrosserie / Body
Support / Holder
Etiquette / Label
Eponge / Sponge
Eponge / Sponge
Rops / Rops
Rops / Rops
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
