Kubota Carrier KC110H Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Carrier
Model: Kubota KC110H Carrier
Number of Pages: 88 Pages
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Culasse / Head Cover
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De Pignon De Ralenti / Camsh Aft And Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulateur / Fu El Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Plate
Porte-Injecteur (Parties Composantes) / Nozzle Hold Er (Component Parts)
Couvercle / Cover
Alternateur Und Poulie / Alternator And Pulley
Alternateur (Parties Composantes) / Alternator (Com Ponent Parts)
Lanceur / Starter
Demarreur (Parties Composantes) / Starter (Componen T Parts)
Contact A Huile Et Obturateur / Oil Switch And Plug
Kit D'accouplements Rapides [Option] / Water Flange And Thermostat
Pompe A Eau / Water Pump
Radiateur / Radiator
Tuyau D'eau / Water Pipe
Ventilateur / Fan
Filter A Air / Air Cleaner
Support Avant Droit / Hydraulic Pump
Pompe Hydraulique (Parties Composantes) / Hydraulic Pump (Component Parts)
Manuel De L'utilisateur / Operator's Manual
Jeu De Pistons [Option] / Piston Kit [Option]
Console De Moteur / Engine Bracket
Controle Du Moteur / Engine Control
Reservoir Carb. / Fuel Tank
Silencieux / Muffler
Parties Electriques / Elect Rical Parts
Faisceau Electrique / Elect Rical Wiring
Chassis / Frame
Main Courante / Handrail
Couvercle Avant / Front C Over
Couvercle De Moteur / Eng Ine Cover
Transmission / Transmission
Carter De Transmission / Transmission C Ase
Premier Arbre / First Shaft
Deuxieme Arbre / Second Shaft
Troisieme Arbre / Third Shaft
Essieu / Axle
Frein / Brake
Frein / Brake
Galet De Chenille [Parties Composan Tes] 1 / Track Roller [Component Parts] 1
Galet De Chenille [Parties Composan Tes] 2 / Track Roller [Component Parts] 2
Galet De Chenille [Parties Composan Tes] 3 / Track Roller [Component Parts] 3
Galet De Chenille Superieur / Upper Track Roller
Intermediaire / Idler
Levier D'embrayage / Clutch Leve R
Levier De Commande / Control Lev Er
Frein De Stationnement / Parking Brake
Siege / Seat
Wagon / Wagon
Levier De Serrure / Lock Lever
Etiquette / Label
Accessoires / Access Ories
Reservoir D'huile / Oil Tank
Circuit D'huile Hydraulique 1 / Hydraulic Oil Line 1
Circuit D'huile Hydraulique 2 / Hydraulic Oil Line 2
Cadre Anti-Renversement / Rops
Couvercle / Cover
Lanceur / Starter
Ventilateur / Fan
Chassis / Frame
Essieu / Axle
Frein / Brake
Frein / Brake
Siege / Seat
Wagon / Wagon
Etiquette / Label
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
