Kubota Carrier KC100H Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Carrier
Model: Kubota KC100H Carrier
Number of Pages: 178 Pages
Crankcase ( -4x9999 )
Crankcase ( 4y0001- )
Aceite Cacerola / Oil Pan
Cylinder Head ( -4x9999 )
Cylinder Head ( 4y0001- )
Gear Case ( -4x9999 )
Gear Case ( 4y0001- )
Tapa De Balancines / Cylinder Head Cover
Camshaft ( -4x9999 )
Camshaft ( 4y0001- )
Piston, Crankshaft ( -4x9999 )
Piston, Crankshaft ( 4y0001- )
Volante / Flywheel
Speed Control Plate ( -4x9999 )
Speed Control Plate ( 4y0001- )
Inpection Pump, Fuel Pump ( -4x9999 )
Injection Pump, Fuel Pump ( 4y0001- )
Injection Pump ( Component Parts ) ( -4x9999 )
Governor ( -4x9999 )
Governor ( 4y0001- )
Nozzle Holder, Glow Plug ( -4x9999 )
Nozzle Holder, Glow Plug ( 4y0001- )
Nozzle Holder ( Component Parts )
Fuel Filter Component Parts ( -4x9999 )
Fuel Filter Component Parts ( 4y0001- )
Dynamo ( -4x9999 )
Dynamo ( 4y0001- )
Dynamo ( Component Parts ) ( -4x9999 )
Dynamo ( Component Parts ) ( 4y0001- )
Starter, Starter ( Component Parts ) ( -4x9999 )
Starter, Starter ( Component Parts ) ( 4y0001- )
Water Flange, Water Pump ( -4x9999 )
Water Flange, Water Pump ( 4y0001- )
Radiator ( -4x9999 )
Radiator ( 4y0001- )
Valve, Rocker Arm ( -4x9999 )
Valve, Rocker Arm ( 4y0001- )
Inlet Manifold, Exhaust Manifold
Air Cleaner (Component Parts) ( -4x9999 )
Air Cleaner (Component Parts) ( 4y0001- )
Frame ( -0258 )
Frame ( 0259- )
Engine Cover ( -0258 )
Engine Cover ( 0259- )
Engine Base, Muffler, Radiator ( -0258 )
Engine Base, Muffler, Radiator ( 0259- )
Engine Base, Muffler, Radiator ( 00329- )
Pulley ( -0004 )
Pulley ( 0005- )
Pulley ( 0259- )
Air Cleaner ( -0258 )
Air Cleaner ( 0259- )
Side Clutch Lever
Drive Pedal ( -0258 )
Drive Pedal ( 0259- )
Clutch Lever, Brake Lever ( -0258 )
Clutch Lever, Brake Lever ( 0259- )
Hydraulic Pump, Cylinder
Hst, Oil Tank ( -0258 )
Hst, Oil Tank ( 0259- )
Speed Change Lever ( -0004 )
Speed Change Lever ( 0005- )
Dump Lever ( -0258 )
Dump Lever ( 0259- )
Body ( -0258 )
Body ( 0259- )
Holder ( -0258 )
Holder ( 0259- )
Idler Wheel
Rubber Crawler
Hydraulic Pump (Component Parts )
Hst (Component Parts 1)
Hst (Component Parts 2)
Transmission (Component Parts 1)
Transmission (Component Parts 2)
Transmission (Component Parts 3)
Transmission (Component Parts 4)
Transmission (Component Parts 5)
Fuel Tank ( -0258 )
Fuel Tank ( 0259- )
Wire Harness, Meter, Switch, Battery ( -0258 )
Wire Harness, Meter, Switch, Battery ( 0259- )
Label ( -0258 )
Label ( 0259- )
Sponge, Trim ( -0258 )
Sponge, Trim ( 0259- )
Volante / Flywheel
Dynamo ( -4x9999 )
Dynamo ( 4y0001- )
Frame ( -0258 )
Frame ( 0259- )
Pulley ( -0004 )
Pulley ( 0005- )
Pulley ( 0259- )
Side Clutch Lever
Body ( -0258 )
Body ( 0259- )
Holder ( -0258 )
Holder ( 0259- )
Idler Wheel
Rubber Crawler
Fuel Tank ( -0258 )
Fuel Tank ( 0259- )
Label ( -0258 )
Label ( 0259- )
