7,392
Krupp Crane KMK 5100 Spare Parts List EN DE
Language: German, English
Brand: Krupp
Type of Manual: Spare Parts List
Model: Krupp KMK 5100 Crane
Publication Date: 1998
Number of Pages: 530 Pages
Mobile Crane Kmk 5100
Attaching Parts For Frame
Covering
Axle-Attachment
(Drive Unit 10x8x8)
Tyre 20.5 025 Xhc
1. Steering Type Driving Shaft
2. Steering Type Driving Shaft
3. Rigit Axle
4. Steering Type Driving Shaft
5. Steering Type Driving Shaft
Steering
Hydr. Plant, Steering (Chassis Frame)
Hydr. Pipe Diagram Hydro-
Steering
Hose Assemblies, Hydro-Steering
Control Chassis Frame
Control Turntable
Turntable
Turntable—Attaching—Parts
Jib
.Counterweight
Driver's Cab, Assembly
Steering Pillar Assembly
Door, Left
Door,Right
Windscreen Wiper 5
Windscreen Washer System
Instrument Beard
Crane Cabin, Assembly
Instrument Holding
"Sliding Door
Bearing Stewing Gear, Assembly
Heating System Chassis Frame
Heating System Turntable
Main Hoisting Gear, Grouping
Hoisting Gear
Mikro—Switch
Slewing Gear
Support
Jib Component Parts
Electr. Construction Lmb
Central—Unit
Jib—Unit
Measured Value Transmitter
Cable Drum
Turntable-Engine-Mounting
Diesel Engine
Coolant Circuit
Engine And Gear Assembly
Component-Parts
Diesel Engine
.Distributor Gear
Change—Over Gear
Radiator Mounting 5
Pump Mounting
Compressed Air System Chassis Fr-
Hydr. Plant, Chassis Frame
Pumpes And Oil~Tank—Mounting
Hose Assemblies, Pumps— And
Oil—Tank-Mounting -
Valve Unit
Hydr. Pipe Diagram For Hydro—
Pneumatic-Suspension
Hose Assemblies, Hydro—Pneumatic
Suspension
hydr. Pipe Diagram, Support
Hose Assemblies, Support
Hydr. Pipe Diagram For Fan Drive
Hose Assemblies For Fan Drive
Hydr. Pant, Turntable
Hydr. Pipe Diagram, Turntable
Hose Assemblies, Turntable
Direct Connected Motor-Driven
Pump
Valve Unit, Crane Control
Slewing Gear
Valve Unit, Quick Motion—Long
Distance Anticipatory Control
Hydr. Pipe Diagram, Telescopic
Gear
Hose Assemblies, Telescopic Gear
Electr. Construction Chassis Fr
Electr. Parts Chassis Frame
Electr. parts, Level-Regulation
Electr. Parts Contr. For Support
Electr. Parts Switch Control.
For Support .
Electr. Parts Support-Feeler-
Integral
Electr. Parts. Chassis Frame.
Blink Lamp Left/Right
Headlight
Five-Sector Light
Electr. Parts Blink Lamp Front
Electr. Construction Driver's Cab
Slide-In Unit 1 A Chassis Fr
Slide-In Unit 2 A Chassis Fr
Slide—In Unit. 3.3 A Chassis Fr
Slide-In Unit 4 A Chassis Fr
Slide-In Unit 6 A.Chassis Fr
Slide-In Unit 9 A Chassis Fr
Slide-In Unit 10.2 A Chassis Fr
Electr. Parts Driver's Cab
Slide—In Unit 13 A Chassis Fr
Slide—In Unit, Level Regulation
Warning Light
Electr. Construction Turntable
Electr. Parts Turntable
Electr. Parts Jib Head
Electr. Parts Jib 5 A
Warning Light
Electr. Parts, Feeler-Integral
Part For Counterweight .V
Electr. Construction Crane Cabin
Slide-In Unit 1 A Turntable
Slide-In Unit 3 A Turntable
Slide-In Unit 9.2 A Turntable
Slide-In Unit 10 A Turntable
Slide—In Unit 16.4 A Turntable
Slide—In Unit 18.2 A Turntable
Slide—In Unit 19.3 A Turntable
Slide—In Unit 20.2 A Turntable
Slide-In Unit 21 5 A Turntable
Electr. Parts Crane Cabin
.Rope And Accessories
Accessories Chassis Frame
Attaching Parts For Reserve
Wheel Holding .
Set Of Completion
Set Of Completion Driver's Cab
Turntable/Chassis Frame
Set Of Completion Electric
Set Of Completion Tools
Tool Box Compl.
Set Of Completion
Oils And Filter ' 5
Plates And Symbols Chassis Fr.
Plates And Symbols Turntable
Special Equipment -
Folded Fly Jib
Hinged Jib 12,5-19 M
Hinged Jib 12,5—19 M
Steel construction
Jib Component Parts
Electr. Construction, Hinged Jib
Electr. Parts, Standard-Crane
Hinged Jib
Electr. Parts, Head Piece
Hinged Jib
Special Equipment
Bottom Hook Block
Bottom Hook Block 80 T
Bottom Hook Block 50 T
'Bottom Hook Block 24 T
Special Equipment Additional
Heater .
Auxiliary Heater (Chassis Fr.)
Heating
Auxiliary Heater (Turntable)
Heating
Special Equipment - Liquid Fuel
Heater
Additional Heater Chassis Frame
Liquid Bottled Motor Fuel
Heating
Additional Heater Turntable
Heating
Special Equipment-Oil Cooler
Oil Coller Mounting, Grouping
Pipe Diagram Oil Cooling
Electr. Parts For Oil Radiator
Div. Special Equipment
Wheel, Cpl. (L6.00«25)
Wheel, Cpl. (16.00-25)
Wheel, Cpl. (20.5 —25)
Seat In The Crane Cab
Supporting Disk
Supporting Disk
Trailer Coupling Mounting
Compressed Air System For
Trailer Control
Rebuilding-Parts List, Hand-
Brake Valve
(Connection For Trailer)
Trailer Coupling, Attachment
Trailer Coupling Sk-7
Special Equipment Auxiliary
Hoisting-Gear
Auxiliary Hoisting Gear, Grouping
Hoisting Gear
Micro-Switch
Hydr. Plant, Auxiliary Hoisting Gear
Hydr. Pipe Diagram, Auxiliary
Hoisting Gear
Hose Assemblies, Auxiliary
Hoisting Gear
Valve Unit, Crane Control-
Rebuilding—Set For Auxiliary
Hoisting Gear
Valve Unit, Long Distance Anti-
Cipatory Control Auxiliary
Hoisting Gear
Electr. Parts, Auxiliary Hoist-
Gear
Auxiliary Hoisting Rope
Accessories Turntable
Rebuilding-Parts List, 10 X8 To
10x6-Drive
L. Steering Shaft I
Special Equipment 5
Rear Axle 5
Separate Steering, Rear Axles
Rebuilding—Parts List, Steering
Steering Rod, Telescopically
Hydr. Pipe Diagram, Separate
Compressed Air System, Chassis
Frame (Rollway)
Blocking (3. Axle)
Electr. Construction Separat
Steering
Electr. Parts, Slide-In Unit
(Separate Steering)
Electr. Parts, Separate Steering
Rear Axle
