Krupp Crane KMK 4060 Spare Parts List EN DE
Language: German, English
Brand: Krupp
Type of Manual: Spare Parts List
Model: Krupp KMK 4060 Crane
Serial Number:
208766 and 208767
208769 to 208781
209050 to 209057
Publication Date: 1989
Number of Pages: 484 Pages
Attaching Parts For Frame
Covering, Assembly
Engine Suspension, Assembly
Axle Attachment
Axle Drive
Wheel Drive Left
Wheel Drive Right
Brake
Axle Drive
Wheel Hub Left
Wheel Hub Right
Wheel Drive Left
Wheel Drive Right
Wheel Cpl. (Selection)
Axle Attachment
Steering
Steering Rod, Telescopically
Hydr. Pipe Diagram, Steering
Assembly
Pump, Oil tank, Accessories
Pumps And Oil-Tank-Mounting
Hydraulic Steering, Chassis Fr.
Hose Assemblies, Steering
Chassis (Pump, Oil Tank)
Chassis Frame
Hydr. Pipe Diagram For All—
Wheel steering
Hose Assemblies, All—Wheel«
Steering
Control
Drivers Cab, Assembly
Door, Left
Door, Right
Windscreen Washer System
Windscreen Wiper -
Ball Bearing Slewing Gear
Heating System Chassis Frame
Warm Water Heating Appliance
Supporting Cpl.
Supporting Front
Supporting Behind
Engine— And Gear Assembly
Engine Assembly, Driving Head
Diesel Engine _
Radiator Mounting ,
Distributor Gear For Pump,
Mounting
Gear Mounting 5 We 201
Gear 5 Wg 201 .
Distributor Gear Mounting
Accessories Engine
(Exhaust, Air Filter,-Fuel
Tank)
Fuel—Diagram .
Heat Exchanger And Transducer—
Piping Unit (Mounting)
Compressed Air System, Chassis
(Page 1)
(Axle Area)
Hydr. Pipe Diagram, Chassis
Pumps, Slewing Gear And
Hose Assemblies, Chassis
(Pumps, Slewing Gear And
Accessories)
Pump Mounting
Hydr. Plant Support
Hose Assemblies; Chassis
(Support)
Hydr.—Pneum. Springing
Shock—Absorbing Strut
(Springing) .
Fan Drive
(Fan Drive)
Hydr. Pipe Diagram, Drivers
Cab Tipping Device
Electr. Construction, Chassis
.Headlight
Control Units For Support _
Feeler—Integral Parts For
Support, Left
Drivers Cab Switching
Electr. Parts, Chassis
Level-Regulation
Laced Wiring Harness Terminal
Peeler-Integral Parts For
Support, Right
Electr. Construction Drivers
Cab .
Slide—In Unit 1 A
Slide—In Unit 2.1a
Slide—In Unit 3.4a
Slide—In Unit 6.3a
Slide—In Unit 7.2a
Slide—In Unit 9 A
Slide—In Unit 10.5a
Electr. Parts Drivers Cab
Electr. Parts, Car Radio Recei-
Ver, Two—Man Cabin
Slide—In Unit, Level Regulation
Slideain Unit, Separate Steering
Slide-In Unit Drive
Accessories Chassis
Turntable
Hydraulic Steering Turntable,
Steering
Attaching Parts For Turntable
Counterweight
Crane Cabin
Sliding Door
Heating System, Crane Cabin
Air Heating Appliance
Main Hoisting Gear
Hoisting Gear
Slewing Gear F
Electr. Construct. Lmb (Turnt.)
(Page 1)
Central Unit
Measured Value Transmitter
Compressed Air System, Turnt.
Hydr. Pipe Diagram, Turntable
Dil Tank Mounting
Hose Assemblies .
(Mounting Oil Tank) ,
Valve Unit
Hose Assemblies
(Valve Unit)
Crane Control A "
Main Hoisting Gear
Hose Assemblies
(Main Hoisting Gear)
Luffing Gear
Hose Assemblies
(Luffing Gear)
Slewing Gear And Counterweight
Hoisting Gear
Hose Assemblies
(Slewing Gear And Counterweight
Hoisting Gear)
Long—Distance Anticipat. Contr.
Hose Assemblies D
(Long-Distance Antici. Contr.)
Hose Assemblies Turntable
(Slewing Gear) ,
Electr. Construction, Turntable
Peeler—Integral Counterweight
Electr. Construction, Crane
Cabine .
Slide-In Unit 3 A
Slidewin Unit 5.2a
Slide—In Unit 6 A
Slide~In Unit 7.8a
Slide-In Unit 9.5a _
Slide-In Unit 10 A
Slide—In Unit 18.3a
Slide—In Unit L9.2a
Slide-In Unit 20.La
Electr. Parts Crane Cabin
Wire Rapes And Accessories
Accessories Turntable
Jib
Jib Component Parts
Component Parts luffing Cyl,)
Electr. Construction Lmb Jib (Page 2)
Jib-Unit
Cable Drum 2
Cable Drum 3 V
Hydr. Pipe Diagram, Telescopic
Gear
Electr. Parts Jib
Eguigment
Set Of Completion _
(Tools .
Toolbox, Cpl.
Plates And Symbols (Chassis)
Plates And Symbols (Turntable)
Wheel, Cpl. (Selection)
Hook Blocks
Bottom Hook Block 55 T With
Double Hook
Bottom Hook Block 45 T With
Double Hook
Bottom Hook Block 18 T
Swivel Hook 8 T -
Auxiliary Hoisting Gear
Auxiliary Hoisting Gear Cpl.-
Hoisting Gear
Hydr. Pipe Diagram, Auxiliary
Rebuilding Set For Auxiliary
Wire Ropes And Accessories
Fly Jib Folded
Hinged.Jib
Hinged Jib, Mounting Parts
Bearing Block
Electr. Construction, Hinged
Hinged Jib, 30° Mounting
Auxiliary Heater Driver"S Cab
Heating
(Heating I
Bil Cooler
Oil Cooler Mounting
Hydr. Pipe Diagram, Oil Cooling
Electr. Parts For Oil Radiator
Marking
Plates (Chassis)
Plates (Turntable)
Trailer Coupling
Trailer Coupling, Cpl.
Compressed Air System Chassis
Compressed Air System Axle Area
Compressed Air System Trailer
Control .
Reserve Wheel Holder
Brand: Krupp
Serial Number:
208766 and 208767
208769 to 208781
209050 to 209057
Covering, Assembly
Axle Attachment
Axle Drive
Wheel Drive Left
Wheel Drive Right
Brake
Axle Drive
Wheel Hub Left
Wheel Hub Right
Wheel Drive Left
Wheel Drive Right
Axle Attachment
Steering
Assembly
Chassis Frame
Wheel steering
Steering
Control
Door, Left
Door, Right
Windscreen Wiper -
Supporting Cpl.
Supporting Front
Supporting Behind
Diesel Engine _
Radiator Mounting ,
Mounting
Gear 5 Wg 201 .
Accessories Engine
Tank)
Fuel—Diagram .
(Page 1)
(Axle Area)
Accessories)
Pump Mounting
Hydr. Plant Support
(Support)
(Springing) .
Fan Drive
(Fan Drive)
Cab Tipping Device
.Headlight
Support, Left
Level-Regulation
Support, Right
Cab .
Slide—In Unit 1 A
Slide—In Unit 2.1a
Slide—In Unit 3.4a
Slide—In Unit 6.3a
Slide—In Unit 7.2a
Slide—In Unit 9 A
Slide—In Unit 10.5a
Ver, Two—Man Cabin
Slide-In Unit Drive
Accessories Chassis
Turntable
Steering
Counterweight
Crane Cabin
Sliding Door
Main Hoisting Gear
Hoisting Gear
Slewing Gear F
(Page 1)
Central Unit
Dil Tank Mounting
Hose Assemblies .
Valve Unit
Hose Assemblies
(Valve Unit)
Crane Control A "
Main Hoisting Gear
Hose Assemblies
Luffing Gear
Hose Assemblies
(Luffing Gear)
Hoisting Gear
Hose Assemblies
Hoisting Gear)
Hose Assemblies D
(Slewing Gear) ,
Cabine .
Slide-In Unit 3 A
Slidewin Unit 5.2a
Slide—In Unit 6 A
Slide~In Unit 7.8a
Slide-In Unit 10 A
Slide—In Unit 18.3a
Slide—In Unit L9.2a
Slide-In Unit 20.La
Jib
Jib Component Parts
Jib-Unit
Cable Drum 2
Cable Drum 3 V
Gear
Electr. Parts Jib
Eguigment
Set Of Completion _
(Tools .
Toolbox, Cpl.
Hook Blocks
Double Hook
Double Hook
Swivel Hook 8 T -
Hoisting Gear
Fly Jib Folded
Hinged.Jib
Bearing Block
Heating
(Heating I
Bil Cooler
Oil Cooler Mounting
Marking
Plates (Chassis)
Plates (Turntable)
Trailer Coupling
Control .
