Krupp Crane KMK 3040 Spare Parts List EN DE
Language: German, English
Brand: Krupp
Type of Manual: Spare Parts List
Model: Krupp KMK 3040 Crane
Serial Number: 208698 to 208721
Publication Date: 1990
Number of Pages: 424 Pages
Mobile Crane
Attaching Parts For Frame
Covering Assembly
Engine Suspension, Assembly
Axle Attachment
Axle Drive
Wheel Drive Left
Brake
Wheel Drive Right
Wheel Hub Left
Wheel Hub Right
Wheel Cpl. (Selection)
Steering
Hydr. Pipe Diagram, Steering Assembly
Pump, Oil-Tank, Accessories Hue Assemblies, Steering Chassis (Pump, Oil Tank)
Pumps And Oil-Tank, Mounting
Hydraulic Steering, Chassis
Hose Assemblies, Steering Chassis
Control
Driver's Cab, Assembly
Door, Left
Door, Right
Windscreen Washer System
Windscreen Wiper
Ball Bearing Slewing Gear
Heating System Chassis
Warm Water Heating Appliance
Supporting Cpl.
Engine- And Gear Assembly
Engine Assembly, Driving Head
Diesel Engine
Radiator Mounting
Gear Mounting 6 Wg 200
Gear 6 Wg 200
Accessories Engine (Exhaust, Air Filter, Fuel Tank)
Fuel-Diagram
Transducer Piping Unit (Mounting)
Compressed Air System, Chassis (Page 1)
Compressed Air System, Chassis (Axle Area)
Hydr. Pipe Diagram, Chassis
Pumps, Slewing Gear And Accessories
Hose Assemblies, Chassis (Pumps, Slewing Gear And Accessories)
Pump Mounting
Hydr. Plant Support
Hose Assemblies, Chassis (Support)
Hydr.-Pneum. Springing
Shock-Absorbing Strut
Hose Assemblies, Chassis (Springing)
Fan Drive
Hose Assemblies, Chassis (Fan Drive)
Hydr. Pipe Diagram, Driver's Cab Tipping Device
Electr. Construction, Chassis
Headlight
Control Units For Support
Feeler-Integral Parts For
Support, Left
Driver's Cab Switching
Electr. Parts, Chassis
Level—Regulation
Laced Wiring Harness Terminal
Feeler—Integral Parts For
Support, Right
Electr. Construction Driver's Cab
Slide—In Unit 1 A
Slide-In Unit 2.La
Slide-In Unit 3.4a
Slide—In Unit 6.3a
Slide-In Unit 7.2a
Slide—In Unit 9.4a
Slide—In Unit 18.4a
Electr. Parts Driver's Cab
Electr. Parts, Car Radio Receiver, Twp—Man Cabin .
Slide-In Unit, Level Regulation
Slide-In Unit, Separate Steering 3
Slide-In Unit Drive
Accessories Chassis
Turntable
Hydraulic Steering Turntable
Steering
Attaching Parts For Turntable
Counterweight
Crane Cabin
Sliding Door
Heating System, Crane Cabin
Air Heating Appliance
Main Hoisting Gear .
Hoisting Gear
Slewing Gear
Electr. Construct. Lmb (Turnt.) (Page L)
Central—Unit
Measured Value Transmitter
Compressed Air System, Turnt.
Hydr. Pipe Diagram, Turntable
Oil Tank Mounting
Hose Assemblies (Mounting Oil Tank)
Valve Unit
Hose Assemblies (Valve Unit)
Crane Control
Main Hoisting Gear
Hose Assemblies (Main Hoisting Gear)
Luffing Gear
Hose Assemblies (Luffing Gear)
Slewing Gear And Counterweight Hoisting Gear
Hose Assemblies (Slewing Gear And Counterweight Hoisting Gear)
Long—Distance Anticipat. Contr.
Hose Assemblies Turntable (Slewing Gear)
Electr. Construction, Turntable
Feeler-Integral Counterweight
Electr. Construction, Crane Cabin
Slide—In Unit 3 A
Slide—In Unit 5.2a
Slide—In Unit 6 A
Slide—In Unit 7.7a
Slide—In Unit 9.5a
Slide-In Unit 10 A
Slide-In Unit 18.3a
Slide-In Unit 19.2a
Slide-In Unit 20.1a
Electr. Parts Crane Cabin
Wire Ropes And Accessories
Accessories Turntable
Jib
Jib Component Parts
Component Parts (Luffing Cyl.)
Electr. Construction Lmb Jib (Page 2)
Jib—Unit
Cable Drum 2
Cable Drum 3
Hydro Pipe Diagram, Telescopic Gear
Electr. Parts Jib
Equipment
Set Of Completion
Tools
Toolbox, Cpl.
Plates And Symbols (Chassis)
Plates And Symbols (Turntable)
Wheel, Cpl. (Selection)
Hook Blocks
Bottom Book Block 40 T With
Single Load Hook
Bottom Hook Block 28 T With
Bottom Book Block L2 T With
Swivel Book 5 T
Auxiliary Hoisting Gear
Auxiliary Hoisting Gear Cpl.
Hoisting Gear
Hydr. Pipe Diagram, Auxiliary
Hose Assemblies (Hydr. Pipe Diagram, Auxiliary)
Rebuilding Set For Auxiliary
Fly Jib Folded
Hinged Jib 8—13m
Hinged Jib, Mounting
Hinged Jib, Mounting Parts
Bearing Block
Electra Construction, Hinged
Auxiliary Heater Driver's Cab
Heating
Mil Cooler V
Oil Cooler Mounting
Hydr. Pipe Diagram, Oil Cooling
Electr. Parts For Oil Radiator
Marking
Plates (Chassis)
Plates (Turntable)
Brand: Krupp
Mobile Crane
Covering Assembly
Axle Attachment
Axle Drive
Wheel Drive Left
Brake
Wheel Drive Right
Wheel Hub Left
Wheel Hub Right
Steering
Control
Door, Left
Door, Right
Windscreen Wiper
Supporting Cpl.
Diesel Engine
Radiator Mounting
Gear 6 Wg 200
Fuel-Diagram
Pump Mounting
Hydr. Plant Support
Fan Drive
Headlight
Support, Left
Level—Regulation
Support, Right
Slide—In Unit 1 A
Slide-In Unit 2.La
Slide-In Unit 3.4a
Slide—In Unit 6.3a
Slide-In Unit 7.2a
Slide—In Unit 9.4a
Slide—In Unit 18.4a
Slide-In Unit Drive
Accessories Chassis
Turntable
Steering
Counterweight
Crane Cabin
Sliding Door
Hoisting Gear
Slewing Gear
Central—Unit
Oil Tank Mounting
Valve Unit
Crane Control
Main Hoisting Gear
Luffing Gear
Slide—In Unit 3 A
Slide—In Unit 5.2a
Slide—In Unit 6 A
Slide—In Unit 7.7a
Slide—In Unit 9.5a
Slide-In Unit 10 A
Slide-In Unit 18.3a
Slide-In Unit 19.2a
Slide-In Unit 20.1a
Jib
Jib Component Parts
Jib—Unit
Cable Drum 2
Cable Drum 3
Electr. Parts Jib
Equipment
Set Of Completion
Tools
Toolbox, Cpl.
Hook Blocks
Single Load Hook
Swivel Book 5 T
Hoisting Gear
Fly Jib Folded
Hinged Jib 8—13m
Bearing Block
Heating
Mil Cooler V
Oil Cooler Mounting
Marking
Plates (Chassis)
Plates (Turntable)
