Krupp Crane 180 GMT Spare Parts List EN DE FR
Language: French, German, English
Brand: Krupp
Type of Manual: Spare Parts List
Model: Krupp 180 GMT Crane
Publication Date: 1986
Number of Pages: 478 Pages
Mobile Crane 180 GMT
Attaching Parts For Frame, Ass.
Holding Mounting
Axle—Attachment Ex
Steering Type Driving Shaft Em
Steering Shaft
Driving Axle
Driving Axle
Steering Shaft
Steering
Hydro-Steering
Control Chassis Frame, Mech.
Control-Turntable ""~"
Attaching Parts For Turntable
Turntable Covering
Jib
Counterweight Mounting
Counterweight
Driver's Cab, Assembly
Door Assembly, Right
Door Assembly, Left
Instrument Board, Assembly
Windscreen Washer System
Windscreen Wiper
Crane Cabin Assembly
Door
Roller Bearing Slewing Gear
Heating System-Chassis Frame
Heating System—Turntable
Auxiliary Hoisting Gear
Hoisting Gear
Limit Switch
Main Hoisting Gear
Hoisting Gear
Limit Switch
Slewing Gear
Support
Jib Component Parts
Bottom Hook Block
Turntable-Locking
Electr. Construction Sli
Central Unit
Jib Unit Eks 83
Measured Value Transmitter
Turntable-Engine Mounting
Diesel Engine
Drive Chassis Frame
Diesel Engine
Change-Over Gear
Component Parts
Distributor Gear
Mounting For Emergency Steering
Pump
Radiator Mounting
Pump—Attaching Parts, Mech.
Compressed Air System
Chassis Frame
Compressed Air Parts Mounting
Hydr. Pipe Diagram-Chassis
Frame
Pumps, Control, Chassis Frame
Pump Mounting
Hydro-Pneumatic-Suspension
Support
Pipes And Mounting Material
Hydr. Pipe Diagram, Turntable
Pump, Oil tank, Accessories
Pump Mounting
Long-Distance Anticipatory
Control
Hoisting Gear
Luffing Gear And Extension Gear
Pipe Diagram (Pressure Absorber)
Slewing Gear And Counterweight
Hoisting Gear -
Valve Unit
Pipe And Mounting Material
Hydr. Pipe Diagram, Auxiliary
Hoisting Gear-
Electr. Constr. Chassis Frame
Driver's Cab
Slide—In Unit 1a Turntable/
Chassis Frame
Slide-In Unit 2a Chassis Frame
Slide-In Unit 3a Chassis Frame
Slide-In Unit 4a Chassis Frame
Slide-In Unit 6a Chassis Frame
Slide-In Unit 9a Chassis Frame
Slide-In Unit 10a Chassis Frame
Electr. Construction-Turntable
Jib
Turntable
Electr. Constr. For Crane Cabin
Slide-In Unit 1a Turntable Chassis Frame
Slide-In Unit 2a Turntable
Slide-In Unit 3a Turntable
Slide-In Unit 4a Turntable
Slide-In Unit 9a Turntable
Slide—In Unit 10a Turntable
Wire Ropes And Accessories
Accessories-Chassis Frame
1elevation Adjustment
Accessories-Turntable
Set Of Completion 180 GMT
Plates And Symbols Chassis Frame
Plates And Symbols-Turntable
Tools
Tools And Toolbox
Safety Device
Special Equipment Fly Jib Folded
Hinged Jib 13 M
Hinged Jib, Assembly
Component Parts For Hinged Jib
Electr. Constr.Hinged Jib 13 M
Electr. Constr. Jib
Lifting Apparatus For Fly Jib
Hydr. Pipe Diagram
(Elevation Mechanism For Fly Jib)
Jib Component Parts, Extension 2x6 M
Electr. Parts, Hinged Jib Extension
Special Equipment Fly Jib Luffable
Fly Jib 45 M
Fly Jib
Jib Component Parts For 45m Jib
Bottom Hook Block
Top Block
Anchoring 45 M Fly Jib
Electr. Constr. Fly Jib 45 M
Fly Jib—Unit Eks 83
Electric Parts Jib
Fly Jib Extension
Special Equipment Superlift
Superlift Apparatus
Superlift
Hydr. Pipe Diagram Superlift
Pipe Diagram
Display Unit
Superlift Apparatus
Ropes For Superlift
Special Equipment Block
Hook Fittings 8 T
Block 15 T
Block 30 T
Block 60 T
Block 180 T
Special Equipment Oil Cooler
Oil Cooler Mounting, Grouping
Oil Cooler Mounting
Pipe Diagram, Oil Cooling
Electr. Parts For Oil Radiator
(Slide-In Unit 4, Turntable)
Special Equipment Cold Start Battery's
Rebuilding Parts List, Battery
Special Equipment Trailer Working
Compressed Air System For
Chassis Frame (Trailer Control)
Plug Box (Trailer)
Trailer Coupling, Mounting
Div. Special Equipments
Folding Bed
Function Generator For Hoisting Gear
Rebuilding From 1 Guide Roller
To 2 Guide Rollers
Start pilot-Plant/Vertical Engine
Start pilot-Plant/V-Engine
Working Headlight
Warning Light
Reserve Wheel Holding
Reserve Wheel
Brand: Krupp
Holding Mounting
Axle—Attachment Ex
Steering Shaft
Driving Axle
Driving Axle
Steering Shaft
Steering
Hydro-Steering
Turntable Covering
Jib
Counterweight
Door Assembly, Left
Windscreen Wiper
Door
Hoisting Gear
Limit Switch
Main Hoisting Gear
Hoisting Gear
Limit Switch
Slewing Gear
Support
Jib Component Parts
Bottom Hook Block
Turntable-Locking
Central Unit
Jib Unit Eks 83
Diesel Engine
Drive Chassis Frame
Diesel Engine
Change-Over Gear
Component Parts
Distributor Gear
Pump
Radiator Mounting
Chassis Frame
Frame
Pump Mounting
Support
Pump Mounting
Control
Hoisting Gear
Hoisting Gear -
Valve Unit
Hoisting Gear-
Driver's Cab
Chassis Frame
Jib
Turntable
Tools
Tools And Toolbox
Safety Device
Hinged Jib 13 M
Electr. Constr. Jib
Hydr. Pipe Diagram
Fly Jib 45 M
Fly Jib
Bottom Hook Block
Top Block
Fly Jib—Unit Eks 83
Electric Parts Jib
Fly Jib Extension
Superlift Apparatus
Superlift
Pipe Diagram
Display Unit
Superlift Apparatus
Ropes For Superlift
Hook Fittings 8 T
Block 15 T
Block 30 T
Block 60 T
Block 180 T
Oil Cooler Mounting
Plug Box (Trailer)
Folding Bed
To 2 Guide Rollers
Working Headlight
Warning Light
Reserve Wheel
