7,392
Krupp Crane 140 GMT-AT Spare Parts List 1988 EN DE FR
Language: French, German, English
Brand: Krupp
Type of Manual: Spare Parts List
Model: Krupp 140 GMT-AT Crane
Publication Date: 1988
Number of Pages: 502 Pages
Mobile Crane 140 GMT-AT
Attaching Parts For Frame
Covering
Axle-Attachment
(Drive Unit 12x8x10)
Tyre 20.5 R25 Xhc
1. Steering Type Driving Shaft
2. Steering Type Driving Shaft
3. Steering Shaft
4. Rigit Axle
5. Steering Type Driving Shaft
6. Steering Type Driving Shaft
Steering
Hydr. Pipe Diagram Steering
Hydro-Steering
Valve Unit Ii
Control Chassis Frame
Control Turntable
Turntable-Attaching-Parts
Jib
Counterweight
Driver's Cab, Assembly
Steering Pillar Assembly
Door, Left
Door, Right
'Windscreen Wiper
Windscreen Washer System
Instrument Board 1
Crane Cabin, Assembly
Instrument Holding
Sliding Door
Roller Bearing Slewing Gear
Heating System Chassis Frame
Heating System Turntable
Auxiliary Hoisting Gear
Hoisting Gear
Main Hoisting Gear
Hoisting Gear
Slewing Gear
Support, Double
Jib Component Parts
Attaching Parts For Jib
Bottom Hook Block
Turntable Locking
Electr. Construction Lmb
Hydraulic Pressure Unit
Central-Unit
Jib-Unit
Measured Value Transmitter
Turntable-Engine-Mounting
Diesel Engine
Coolant Circuit
Engine And Gear Assembly
Component Parts
Diesel Engine
Distributor Gear
Change-Over Gear
Radiator Mounting
Pump Mounting
Compressed Air System Chassis Fr.
Compressed Air Parts Mounting
Compressed Air System Turntable
Compressed Air Parts Mounting I
Hydr. Pipe Diagram Chassis Frame
Pipe And Mounting Material
Valve Unit I
Hydr.-Pneum. Springing
Hydr. Plant Support
Pump, Oil-Tank And Accessories
Pump Mounting
Hydr. Pipe Diagram Turntable
Multi-Cycle-Direct Connected
Motor—Driven Pump
Valve Unit Ii
Valve Unit I
Pump, Oil-Tank, Accessories
Long-Distance Anticipatory Con.
Main Hoisting Gear
Luffing Gear And Extension Gear
Slewing Gear And Counterweight
Hoisting Gear
Pipes And Mounting Material
Pumps—Mounting And Oil-Tank-
Mounting
Electr. Construction Chassis Fr.
Electr. Parts Chassis Frame
Electr. Parts, Level-Regulation
Electr. Parts Contr. For Support
Electr. Construction Driver's Cab
Slide-In Unit I A Chassis Fr.
Slide-In Unit 2 A Chassis Fr.
Slide-In Unit 3 A Chassis Fr.
Slide-In Unit 4 A Chassis Fr.
Slide-In Unit 6 A Chassis Fr.
Slide—In Unit 9 A Chassis Fr.
Slide-In Unit 10.2 A Chassis Fr.
Electr. Parts Driver's Cab
Slide-In Unit 13 A Chassis Fr.
Slide-In Unit, Level Regulation
Slide-In Unit Suspension I
Electr. Construction Turntable
Electr. Parts Turntable
Electr. Parts Jib
Electr. Construction Crane Cabin
Slide-In Unit I A Turntable :
Slide-In Unit 2 A Turntable -
Slide-In Unit 3 A Turntable
Slide-In Unit 4.1 A Turntable
Slide-In Unit 9 A Turntable
Slide-In Unit 10 A Turntable
Slide—In Unit 13.2 A Turntable
Slide—In Unit 16.2 A Turntable
Electr. Parts Crane Cabin
Main Hoisting Rope
Auxiliary Hoisting Rope
Accessories Chassis Frame
Set Of Completion
Set Of Completion Driver's Cab
Turntable/Chassis Frame
Set Of Completion Electric
Set Of Completion Tools
Tool Box Compl.
Set Of Completion
Oils And Filter
Plates And Symbols Chassis Fr.
Plates And Symbols Turntable
Special Equipment
Folded Fly Jib
Hinged Jib 20 M
Jib Component Parts
Electr. Construction, Hinged Jib
Electr. Parts, Hinged Jib 13 M
Electr. Parts, Hinged Jib J M
Special Equipment
Mounting Jib
Mounting Jib Cpl.
Mounting Jib (Stud Construction)
Mounting Jib - Component Parts 1
Fly Jib - Component Parts
Mounting Jib - Electr. Con—
Struction
Electr. Parts Grouping, Head
Piece, Fly - And Mounting Jib
Slide-In Unit, Fly Jib-Unit And,
Mounting Jib
Electr. Parts Cable Drum
Main Jib
Electr. Parts Head Piece 2
Main Jib
Fly Jib And Mounting Jib
Electr. Parts Foot Mounting
Mounting Jib
Lmb-Equipment (Fly Jib)
Measured Valve Transmitter
(Jib Head)
Fly Jib-Unit
(Projection Jib)
Special Equipment
Fly Jib
Fly Jib 38,5 M
Fly Jib
Fly Jib-Component Parts Sheet 1
Fly Jib-Component Parts Sheet 2
Fly Jib-Component Parts Sheet 3
Attachment Limit Switch
Anchoring Fly Jib
Electr. Construction—Fly Jib
Slide-In Unit Fly Jib Unit And
Mounting Jib
Electr. Pars, Cable Drum
Main—Jib
Hydr. Plant For Fly Jib
Special Equipment
Bottom Hook Block
Bottom Hook Block 140 T
Bottom Hook Block 80 T
Bottom Hook Block 60 T/
Bottom Hook Block 30 T
Special Equipment Additional
Heater
Additional Heater Chassis Frame
Heating Assembly
Additional Heater Turntable
Heating Assembly
Special Equipment Startpilot
Plant
Startpilot-Plant/Vertical
Startpilot-Plant/V—Engine
Div. Special Equipment
3-Er Seat In The Crane Cab
Flootlight
Warning Light
Gasoline-Tank Meter, Turntable
Car Radio Receiver
Trailer Coupling Mounting
Compressed Air System For
Trailer Control
Outside Mirror-Heated
Electr. Parts Outside Mirror-
Heated -
Tyre L6.00-R25
Additional—Bracket Plate
