Martin Welker
104
230,310
Krone Rear Mounted Mower ActiveMow R 240 Assembly Instructions 150001391-03-EN
Brand: Krone
Type of Machine: Rear Mounted Mower
Type Of Manual: Assembly Instructions
Model: Krone ActiveMow R 240 Rear Mounted Mower
Serial Number: 1081088
Parts Number: 150001391_03_en
Publication Date: 2022
Number Of Page: 94 Pages
Information On This Document
Validity
Significance Of The Document
Re-Ordering
Applicable Documents
Target Group Of This Document
How To Use This Document
Directories And
Information On Direction
Figures
Means Of Representation
Structure Of The Chapter "Scope Of Delivery"
Structure Of The Chapter "Assembly"
Conversion Table
Safety
Personnel Qualification Of The
Basic Safety Instructions
Safety
Shutting Down And Safeguarding The Machine
Securing Raised Machine And Machine Parts Against Lowering
Carrying Out Oil Level Check And Oil And Filter Element Changes Safely
Scope Of Delivery
Assembly
Tightening Torques
Suspended Loads
Contaminated Components
Installation Position Of Roll Pins
General Information On Assembly
Mounting The Drive On The Cutterbar
Mounting The Hinge Links
Mounting The Guard Sheet
Mounting Support Jack
Mounting The Three-Point Hitch
Mounting The Limitation Rod
Mounting The Support Frame
Mounting The Top Guard Sheet
Mounting The
Mounting The Plastic Rope
Mounting The Mower Relief Components
Mounting The Tension Spring With Threaded Spindle
Adjusting The Tension Spring With Threaded Spindle
Mounting Hydraulic Cylinder
Mounting The Tension Spring With Pawl
Mounting The Impact Damage Protection System
Mounting The Protective Cap
Mounting The Blade Box
Mounting The Front Guard Frame ("Guard Frame Mounted" Version)
Mounting The Front Guard Frame ("Guard Frame Mounted With Fixed Side Guard" Version And
"Guard Frame Mounted With Hinged Side Guard" Version)
Pre-Assembling The Hinged Front Guard
Mounting The Hinged Front Guard
Mounting The Lateral Guard ("Guard Frame Mounted With Fixed Side Guard" Version)
Mounting The Lateral Guard ("Guard Frame Mounted With Hinged Side Guard" Version)
Mounting The Guard Carrier
Mount The Side Guard
Mounting The Label Sheet
Fitting The Front Guard Cloth
Mounting The Lateral Guard Cloth ("Guard Frame Mounted With Fixed Side Guard" Version And
Mounting The Hoop Guard
Mounting The Adjusting Lever
Mounting The Lower Link Pin
Initial Operation
Index
