Hyundai
86
176,684
Krone Mower Combination EasyCut B1000CR Original Operating Instructions 150000702_04_us
Brand: Krone
Type of Machine: Mower Combination
Type of Manual: Original Operating Instructions, Hydraulic And Electrical Schematic
Model: Krone EasyCut B1000CR Mower Combination
Machine Number: From 976393
Part Number: 150000702_04_us
Number of Pages: 250 Pages
1 Information on This Document
1.1 Validity​
1.2 Re-ordering​
1.3 Applicable documents​
1.4 Target group of this document​
1.5 How to use this document​
2 Safety
2.1 Intended use​
2.2 Reasonably foreseeable misuse​
2.3 Service life of the machine​
2.4 Basic safety instructions​
2.5 Safety routines​
2.6 Safety labels on the machine​
2.7 Safety equipment​
3 Machine description
3.1 Machine overview​
3.2 Labelling​
3.3 Description of hydraulic system functions​
3.4 Lighting​
3.5 Intermediate universal shaft​
3.6 Pole protection mechanism​
4 Data memory
5 Technical data
5.1 Consumables​
6 Control and Display Elements
6.1 ISOBUS terminal​
6.2 Operation panel​
7 Initial operation
7.1 Checklist for initial operation​
7.2 Setting “Speed” sensor​
7.3 Adapting coupling points​
7.4 Checking/setting the free space from tractor to machine​
7.5 Adapting universal shaft​
7.6 Adapting hydraulic system​
8 Start-up
8.1 Connecting the machine to the tractor​
8.2 Connecting hydraulic hoses​
8.3 Connecting KRONE Beta II terminal​
8.4 Connecting KRONE ISOBUS terminal​
8.5 Connecting foreign ISOBUS terminal​
8.6 Connecting joystick​
8.7 Connecting operation panel​
8.8 Connecting lighting​
8.9 Installing universal shaft​
9 Operation
9.1 Safety device front​
9.2 Side guard​
9.3 Swivelling up support jacks (transport position)​
9.4 Swivelling down support jacks (parking position)​
9.5 Locking/releasing stop cocks​
9.6 Lowering machine from transport position to working position​
9.7 Raising machine from headland position to transport position​
9.8 Lowering the machine from transport position to working position​
9.9 Mowing​
9.10 Emergency manual operation​
10 Driving and transport
10.1 Preparing machine for road travel​
10.2 Switching off the machine​
11 KRONE BETA II terminal
11.1 ISOBUS Shortcut Button not available​
11.2 Switching terminal on/off​
11.3 Design of display​
12 KRONE ISOBUS terminal (CCI 200, DELTA)
12.1 ISOBUS Shortcut Button (ISB)​
12.2 Touchable display​
12.3 Switching terminal on/off​
12.4 Design of display​
13 KRONE ISOBUS terminal (CCI 1200)
13.1 Touchable display​
13.2 Switching terminal on/off​
13.3 Design of display​
13.4 Design of the KRONE machine application​
14 Foreign ISOBUS terminal
14.1 ISOBUS Shortcut Button not available​
14.2 Varying functions to KRONE ISOBUS terminal​
15 Terminal - Machine Functions
15.1 Status line​
15.2 Keys​
15.3 Displays in the work fields​
15.4 Calling up working screen​
15.5 Calling up road travel screen​
15.6 Working screens in manual mode​
15.7 Working screens in automatic mode​
15.8 Operating machine via joystick​
16 Terminal - Menus
16.1 Menu structure​
16.2 Recurring icons​
16.3 Bring up menu level​
16.4 Selecting a menu​
16.5 Changing value​
16.6 Changing mode​
16.7 Menu 1 “Overcut”​
16.8 Menu 2 “Width shift”​
16.9 Menu 3 “Front Mounted Mower”​
16.10 Menu 4 “Accelerator Rollers”​
16.11 Menu 5 “Manual Control/Time Control/Distance Control”​
16.12 Menu 6 “Lowering Speed”​
16.13 Menu 7 “Overlap”​
16.14 Menu 13 “Counters”​
16.15 Menu 14 “ISOBUS”​
16.16 Menu 15 “Settings”​
16.17 Error Messages​
16.18 Task Controller​
17 Settings
17.1 Setting the cutting height​
17.2 Setting high-cut skids​
17.3 Setting the lateral links​
17.4 Setting the lifting/lowering speed on the hydraulic cylinder​
17.5 Setting the side guards​
17.6 Checking/setting locking of side guards​
17.7 Setting roller distance​
17.8 Setting the width shift​
18 Maintenance - General Information
18.1 Maintenance table​
18.2 Tightening torques​
18.3 Deviating tightening torques​
18.4 Venting the friction clutch​
18.5 Checking guard cloths​
19 Maintenance - Hydraulic System
19.1 Oil filter​
20 Maintenance - Gearbox
20.1 Main gearbox​
20.2 Top part of mower gearbox​
20.3 Bottom part of mower gearbox​
20.4 Gearbox for upper roller drive​
20.5 Oil change and oil level check on the cutterbar​
21 Maintenance - Cutterbar
21.1 Rotary hub​
21.2 Replacing shear protection on rotary hub​
21.3 Checking/changing blades​
21.4 Checking/replacing retaining bolts​
21.5 Checking/replacing blade carrier​
21.6 Checking/replacing cutting discs/mower drums​
21.7 Checking/replacing linings on cutterbar​
22 Maintenance - Lubrication
22.1 Lubricating universal shaft​
22.2 Lubrication chart - Machine​
23 Maintenance – Electrics
23.1 Position of sensors​
23.2 Setting the sensors​
24 Storage
25 Waste disposal
26 Appendix
26.1 Hydraulic diagram (for the version with “terminal”)​
26.2 Hydraulic diagram (for the “standard” version)​
26.3 Circuit diagram​
27 Index
