Martin Welker
104
230,310
Kramer Telehandlers 5509 Spare Parts List 1000311561
Language: English, German, French
Brand: Kramer
Type of Machine: Telehandlers
Type of Manual: Spare Parts List
Model: Kramer 5509 Telehandlers
Part Number: 1000311561
Publication Date: 2014
Number of Pages: 467 Pages
Maintenance
Maintenance kit
Hose clamp
Seals
Engine mounting
Engine block
Engine parts
Engine attachments
Cylinder head
Exhaust system
Fuel supply
Air filter
Pre-separator
Gas regulation
Cooling
Cooling + storage
Fan drive
Drive unit
Drive circuit
Drive cooling circuit
Gearbox mounting
Adjustment motor
Hydraulic pump
Quick-change gearbox
Control cover
Axle attachment
Drive shaft
Front axle
Angle drive
Brake
Rear axle
Steering cylinder
Double drive shaft
Wheel hub
Pendulum axle lock
Lock cylinder
Differential lock
Brake system
Brake pedal
Service brake
Trailer brake
Air brake system
Steering
Steering column
Steering-pump-tank circuit
Steering
Work hydraulics
Oil tank
Control unit mounting
Control unit 5-way Ls
Control unit 6-way Ls
Control unit 7-way Ls
Lifting cylinder
Extension cylinder
Tipping cylinder
Compensation cylinder
Tank-pump-control unit circuit
Control unit-tank circuit
Work hydraulics - control unit
Circuit - shut-off valve
Circuit-lifting cylinder
Circuit-extension cylinder
Circuit-tipping cylinder
Circuit-compensation cylinder
3rd control circuit
Load stabilizer circuit
Front control circuit
Additional control circuit rear
Additional control circuit outside
Pressure relief circuit
Level compensation
Tipper+Level compensation
Auto-Hitch+Tipper+Level compensation
Level cylinder
Lubrication line
Central lubrication system
Electrics
Vehicle lighting
Dashboard
Instruments - roof
Display instrument
Board
Potentiometer
Control lever
Cabin wiring harness
Frame wiring harness
Engine wiring harness
Engine oil preheating
Oil preheating wiring harness
Heating/air conditioning wiring harness
Engine control unit wiring harness
Pendulum axle level wiring harness
Quick-change plate wiring harness
Shovel return automation wiring harness
Electrical components
Electrical telescopic arm
Battery-battery cables
Electric exterior mirror
LED lighting
LED boom lighting
Immobilizer
Socket
Radio
Telematics
Rear camera
View camera
Chains/Wheels
Chassis / Frame
Frame
Covering
Bonnet
Wheel cover
Cover
Covering
Protection
Loading system/Arm system
Telescopic boom
Storage
Rocker arm
Quick-change plate
Overload protection
Shovel return automation Sra
Cabin/Driver's seat
Driver's cab
Cabin windows
Rear window
Cabin door
Wiper system
Rearview mirror
Soundproof mats
Storage compartment
Driver's seat mounting
Driver's seat
Heating/Air conditioning
Heating
Air conditioning
Stickers, Tools
Stickers
Tools
Documents
Shovel
Stacking device
Mirror tow hitch
Shunting coupling
Tow hitch"
