Komatsu Wheeled Excavator PW400MH-6 Shop Manual CEBD005600
Type of Machine: Wheeled Excavator
Type of Manual: Shop Manual
Model: Komatsu PW400MH-6 Wheeled Excavator
Serial Number: A84210 and up
Publication Date: 2001
Form Number: CEBD005600
Number of Pages: 662 Pages
Main Menu
Cover
Contents
Safety
Safety Notice
Foreword
General
How To Read The Shop Manual
Hoisting Instructions
Coating Materials
Standard Tightening Torque
Electric Wire Code
Conversion Tables
01 General
Specifications And Drawing
Lifting Performance
Lifting Capacity
Transportation
Fuel Coolant And Lubricants
Engine Oil Specifications
10 Structure And Function
Engine Components
Power Train
Drive System
Swing Circle
Swing Machinery
Hydraulic Piping Drawing
Hydrulic Piping Schematic
Hydraulic Tank And Filter
Hydruucpump
Control Valve
Self Reducing Pressure Valve
Suction Safety Valve
Clss
Swing System
Valve Control
Ppc Valve
Ppc Accumulator
Ppc Shuttle Valve View
Ls-Epc Valve
Solenoid Valve
Air Conditioner
Actual Electrical Wiring Diagram
Actual Electrical Wiring Diagram (2/2)
Engine Control
Electronic Control System
Machine Monitor System
Sensors
20 Testing, Adjusting And Troubleshooting
Standard Value Table For Engine
Standard Value Table For Chassis Related Parts
Standard Value Table For Electrical Parts
Service Tools Table
Engine Components
Governor Motor Lever Stroke
Work And Swing Equipment
Wc Valve Output Pressure
Ls Valve Output And Differential Pressure
Control Circuit Oil Pressure
Solenoid Valve Output Pressure
Ppc Valve Output Pressure And Shuttle Valve
Work Equipment, Swing Ppc Valve
Travel Deviation
Locations Causing Hydraulic Drift Of Work Equipment
Measuring Oil Leakage
Releasing Remaining Pressure In Hydraulic Circuit
Testing Clearance Of Swing Circle Bearing
Bleeding Air
Troubleshooting - General
Troubleshooting Electrical Connectors
Troubleshooting Communication System (N-Mode)
Troubleshoting Governor Pump Controller And System (E-Mode)
Troubleshooting Engine System (S-Mode)
Troubleshooting Governor Pump And Control System (C-Mode)
Troubleshooting Governor Pump Controller Input Signal (F-Mode)
Troubleshooting Machine Mechanical System (H-Mode)
Troubleshooting Machine Monitor System (M-Mode)
30 Disassembly And Assembly
Special Tool Ust
Sketches Of Special Tools
Engine Components
Radiator. Oil Cooler And Ac Condenser
Engine With Main Pump
Damper
Center Swivel Joint
Swing Motor
Swing Machinery
Revolving Frame
Swing Circle
Travel And Carrier System
Work System
Main Pump
Disassembly
Assembly
Main Pump Oil Seal
Control Valve
Pump Merge Divider Valve
Pressure Compensation Valve
Front Pump Servo Valve
Rear Pump Servo Valve
Ls-Epc Solenoid Valve
Solenoid Valve
Work Equipment Ppc Valve
Ppc Shuttle Valve
Operators Cab
Counterweight
Compressor
Installation
Condenser
Receiver Dryer
Air Conditioner Unit
Governor, Pump Controller
Monitor Panel
Control Stand Case
40 Maintenance Standard
Engine Mounts
Radiator And Oil Cooler Mountings (1/2)
Radiator And Oil Cooler Mountings (2/2)
Swing Machinery
Swing Circle
Control Valve
Swing Motor
Work Equipment • Swing Ppc Valve
Ls-Epc Valve
Solenoid Valve
Center Swivel Joint
90 Others
Hydraulic Piping Schematic
Details Of Troubleshooting, And Troubleshooting Procedure
Actions Taken By Controller When Abnormality Occurs On Machine (Part I)
Actions Taken By Controller When Abnormality Occurs On Machine (Part Ii)
Judgement Table For Governor. Pump Controller And Engine Related Parts
Electrical Circuit Diagram For (E) Mode
(A) Idle Speed Is Irregular
(B) Engine Speed Is Hunting
Actions Taken By Controller When Abnormality Occurs On Machine (Part Iii)
Actions Taken By Controller When Abnormality Occurs On Machine ( Part Iv)
Judgement Table For Governor, Pump Controller (Pump Control System) And Hydraulic Related Parts
Electric Circuit Diagram For (C) Mode
Electric Circuit Diagram For (F) Mode
Table Of Failure Modes And Causes (1/2)
Table Of Failure Modes And Causes (2/2)
Actions Taken By Monitor When Abnormality Occurs On Machine
Electrical Circuit Diagram For (M) Mode
Main Menu
Cover
Contents
Safety
Safety Notice
Foreword
General
Coating Materials
Electric Wire Code
Conversion Tables
01 General
Lifting Performance
Lifting Capacity
Transportation
Engine Components
Power Train
Drive System
Swing Circle
Swing Machinery
Hydruucpump
Control Valve
Clss
Swing System
Valve Control
Ppc Valve
Ppc Accumulator
Ls-Epc Valve
Solenoid Valve
Air Conditioner
Engine Control
Sensors
Service Tools Table
Engine Components
Travel Deviation
Bleeding Air
Special Tool Ust
Engine Components
Damper
Center Swivel Joint
Swing Motor
Swing Machinery
Revolving Frame
Swing Circle
Work System
Main Pump
Disassembly
Assembly
Main Pump Oil Seal
Control Valve
Solenoid Valve
Ppc Shuttle Valve
Operators Cab
Counterweight
Compressor
Installation
Condenser
Receiver Dryer
Monitor Panel
Control Stand Case
Engine Mounts
Swing Machinery
Swing Circle
Control Valve
Swing Motor
Ls-Epc Valve
Solenoid Valve
Center Swivel Joint
90 Others
- KOMATSU Fault Codes
