Komatsu Rigid Dump Truck 830E AFE32-AA SN 31807 Spare Parts Catalog
Type of Machine: Rigid Dump Truck
Model: Komatsu 830E AFE32-AA SN 31807 Dump Truck
Serial Number: 31807
Number of Pages: 423 Pages
AFE32-AA HAULPAK TRUCK
FRAME GROUP
GRILLE, HOOD & HANDRAIL
FRAME & UPRIGHTS
RIGHT DECK, HANDRAIL & LADDER
R.H. HAND CONVEX MIRROR INSTL
RIGHT UPRIGHT ELECTRICAL GROUP
RIGHT DECK, HANDRAIL & DECK
LEFT DECK, HANDRAIL & LADDER
MIRROR INSTALLATION
LEFT DECK, HANDRAIL & LADDER - 2
RIGHT UPRIGHT ELECTRICAL GROUP (1)
MIRROR INSTALLATION (1)
R.H. HAND CONVEX MIRROR INSTL (1)
DECK SECTIONS & SAFETY WALK
ACCESS LADDER & STEP INSTALLATION
COOLING SYSTEM
RADIATOR & SURGE TANK INSTL
RADIATOR ASSEMBLY (YA2099)
RADIATOR & SURGE TANK PIPING
FAN & FAN DRIVE
VARIABLE SPEED FAN CLUTCH (VE3712)
FAN GUARD
ENGINE GROUP
AIR CLEANER PIPING
AIR CLEANER ASSEMBLY (PB6850)
AIR CLEANER INDICATOR PIPING
ENGINE & MISCELLANEOUS INSTL
BATTERY CHARGING ALTERNATOR (PB6876)
ENGINE EXHAUST PIPING (EB5825)
HEATED BODY EXHAUST
HEATED BODY EXHAUST - 2
ENGINE OIL PRESSURE PIPING
FRONT WHEEL & BRAKE GROUP
SPINDLE, HUB & BRAKE INSTALLATION
FRONT DISC BRAKE ASSEMBLY (PB7362)
FRONT BRAKE PIPING
FRONT WHEEL & MOUNTING
FRONT SUSPENSION & MOUNTING
FRONT LUBRICATION GROUP
REAR WHEEL & BRAKE GROUP
REAR DISC & PARKING BRAKE INSTL
REAR DISC BRAKE ASSEMBLY (PB7676)
PARKING BRAKE ASSEMBLY (PB7484)
REAR BRAKE PIPING
DRIVE AXLE & MOUNTING
DRIVE WHEEL PIPING
DRIVE AXLE BLOWER HOSE
REAR HATCH COVER INSTALLATION
REAR WHEEL & MOUNTING
REAR SUSPENSION & MOUNTING
REAR SUSPENSION ASSEMBLY (TZ9085)
STEERING SYSTEM
STEERING COLUMN & CONTROL VALVE INSTL
STEERING COLUMN ASSEMBLY (PB6880)
STEERING CONTROL UNIT (PB6905)
STEERING ARMS & LINKAGE
STEERING CYLINDER ASSEMBLY (EB0770)
STEERING ACCUMULATOR INSTALLATION
ACCUMULATOR ASSEMBLY (TY3541)
STEERING CYLINDER PIPING
STEERING CYLINDER ASSEMBLY (EB0770) (1)
FLOW AMPLIFIER (PB6908)
STEERING SYSTEM PIPING
BLEEDDOWN MANIFOLD VALVE ASSM (PB6923)
STEERING PUMP ASSEMBLY (PB6729)
FLOW AMPLIFIER (PB6908) (1)
SHUT-OFF VALVE ASSEMBLY (TY8353)
STEERING PUMP ASSEMBLY - 2 (PB6729)
CAB GROUP
CAB ASSEMBLY
DOOR ASSEMBLY - L.H. (VE6685)
DOOR ASSEMBLY - R.H. (VE6684)
DOOR LINKAGE & SLIDING WINDOW
CAB ASSEMBLY - 2
CAB DOOR LINKAGE
DOOR LINKAGE & SLIDING WINDOW (1)
OPERATOR'S SEAT INSTALLATION
DRIVER'S SEAT ASSEMBLY - 1 (PB7839)
DRIVER'S SEAT ASSEMBLY - 2 (PB7839)
DRIVER'S SEAT ASSEMBLY - 3 (PB7839)
DRIVER'S SEAT ASSEMBLY - 4 (PB7839)
DRIVER'S SEAT ASSEMBLY - 5 (PB7839)
PASSENGER SEAT INSTALLATION
INSTRUMENT PANEL
SHIFT CONSOLE INSTALLATION
HEATER PIPING & INSTALLATION
AIR CONDITIONER PIPING & INSTL
CONDENSER MOUNTING ASSEMBLY
HEATER & AIR CONDITIONER CONTROLS
CONDENSER MOUNTING ASSEMBLY (1)
WINDSHIELD WIPER INSTALLATION
WINDSHIELD WASHER INSTALLATION
BODY GROUP
BODY & BODY PIVOT
BODY-UP LOCK PIN INSTALLATION
BODY POSITION INDICATOR
ROCK EJECTORS INSTALLATION
MUD FLAP INSTALLATION
MUD FLAP INSTALLATION - 2
REAR MUDFLAP INSTALLATION
BODY CABLE SLING INSTALLATION
ELECTRIC POWER COMPONENTS & WIRING GROUP
ELECTRIC POWER COMPONENTS WIRING
BLOWER INLET INSTALLATION
BLOWER INLET WIRING
BLOWN GRID MODULE
BLOWN GRID MODULE - 2
BLOWN GRID MODULE - 3
CONTROL CABINET WIRING
RCP ACC INTERFACE BOX ASSM (EB2636)
CONTROL CABINET WIRING - 2
CONTROL CABINET WIRING - 3
CONTROL CABINET WIRING - 4
CONTROL CABINET WIRING - 5
CONTROL CABINET WIRING - 6
CONTROL CABINET WIRING - REAR
CONTROL CABINET ASSEMBLY
CONTROL CABINET ASSEMBLY - 2
PRESSURE REGULATOR (VY7272)
CONTROL CABINET ASSEMBLY - 3
CONTROL CABINET ASSEMBLY - 4
RCP ACC INTERFACE BOX ASSM (EB2636) (1)
TERMINAL BLOCK PANEL ASSM (TY9891)
CONTROL CABINET ASSEMBLY - 5
CONTROL CABINET ASSEMBLY - 6
PRESSURE REGULATOR (VY7272) (1)
LOAD TEST INSTALLATION
MOTOR SHUNT INSTALLATION
CABINET PRESSURE CONTROL
DECK PIPING GROUP
BRAKE CABINET CAB PIPING
BRAKE CABINET ASSEMBLY (EB6688)
HOIST PILOT VALVE ASSM (PB6922)
SOLENOID VALVE ASSEMBLY (PB7369)
PRESSURE REDUCING MANIFOLD VALVE (PB7054)
BRAKE MANIFOLD - TWO CIRCUIT (PB7565)
BRAKE TREADLE VALVE PIPING
BRAKE TREADLE VALVE ASSM (PB8050)
DUAL CONTROLLER ASSEMBLY
DUAL CONTROLLER ASSEMBLY (1)
STEERING CONTROL VALVE PIPING
BRAKE CABINET ASSEMBLY - 2 (EB6688)
ACCUMULATOR ASSEMBLY (1)
THROTTLE & RETARDER INSTL
ELECTRONIC TREADLE - RETARDER THROTTLE
ELECTRONIC TREADLE - RETARDER THROTTLE (1)
AIR SYSTEM
AIR SYSTEM PIPING & INSTL
AIR GOVERNOR VALVE ASSM (VW5504)
AIR TANK DRAIN VALVE ASSM (PB4774)
SOLENOID, VALVE - 24V (VZ3502)
AIR COMPRESSOR PIPING
AIR COMPRESSOR ASSEMBLY (VE1055)
CRANKCASE & SHAFT (VE1265)
AIR STARTER PIPING
AIR STARTER ASSEMBLY (PB4988)
HORN INSTALLATION
FUEL SYSTEM
FUEL TANK INSTALLATION
ENGINE FUEL PIPING
ELECTRICAL SYSTEM
LEFT UPRIGHT ELECTRICAL GROUP
LEFT UPRIGHT ELECTRICAL GROUP - 2
RIGHT UPRIGHT ELECTRICAL GROUP (2)
RIGHT DECK ELECTRICAL GROUP
BATTERY EQUALIZER BOX ASSM (EB3105)
AXLE HOUSING ELECTRICAL GROUP
AXLE HOUSING PORTABLE LIGHT (TY1408)
BRAKE CABINET CAB WIRING
ELECTRICAL COMPARTMENT - 24 VOLT
ELECTRICAL COMPARTMENT - 24 VOLT - 2
HOIST LIMIT & BODY-UP INTERLOCK SWITCH
POWER MODULE WIRING
BATTERY CHARGING ALTERNATOR (PB6876) (1)
AIR CONDITIONER PIPING & INSTL (1)
CONDENSER MOUNTING ASSEMBLY (2)
CONDENSER MOUNTING ASSEMBLY (3)
HEAD & FOG LIGHTS
HEAD & FOG LIGHTS (1)
REAR LIGHTS & BACKUP HORN
REAR LIGHT ASSEMBLY
REAR LIGHT ASSEMBLY (1)
REAR TURN & CLEARANCE LIGHTS
TWO-SPEED RETARDING INSTALLATION
HYDRAULIC SYSTEM
HYDRAULIC TANK INSTALLATION
HOIST VALVE & CYLINDER PIPING
HOIST VALVE & CYLINDER PIPING (1)
HOIST CONTROL VALVE ASSM (PB6921)
SPOOL INLET SECTION (VE3810)
HOIST CYLINDER & MOUNTING
HOIST CYLINDER ASSEMBLY (TY5936)
HOIST SYSTEM PIPING
HOIST CYLINDER & MOUNTING (1)
HOIST CYLINDER ASSEMBLY (TY5936) (1)
HOIST PUMP ASSEMBLY (PB7943)
HYDRAULIC TANK CABINET PIPING
HOIST PUMP INSTALLATION
HOIST PUMP ASSEMBLY (PB7943) (1)
UNIVERSAL JOINT INSTALLATION
HOIST PUMP ASSEMBLY (PB7943) (2)
OPTIONS & MISCELLANEOUS GROUP
HYDRAIR CHARGING KIT (VD4665)
PRESSURE FUELING - R.H. (TX3576)
WIGGINS QUICK FUEL - L.H.
SERVICE CENTER INSTALLATION (BD0511)
AUTOMATIC LUBRICATION SYSTEM
AUTOMATIC LUBRICATION SYSTEM - 2
AIR INTAKE FILTRATION INSTALLATION
AIR INTAKE FILTRATION INSTALLATION - 2
HYDRAULIC MOTOR ASSEMBLY (PB6585)
TOOL GROUP - INTERNATIONAL (EB6678)
FRAME GROUP
FRAME & UPRIGHTS
MIRROR INSTALLATION
COOLING SYSTEM
FAN & FAN DRIVE
FAN GUARD
ENGINE GROUP
AIR CLEANER PIPING
HEATED BODY EXHAUST
FRONT BRAKE PIPING
REAR BRAKE PIPING
DRIVE WHEEL PIPING
STEERING SYSTEM
CAB GROUP
CAB ASSEMBLY
CAB ASSEMBLY - 2
CAB DOOR LINKAGE
INSTRUMENT PANEL
BODY GROUP
BODY & BODY PIVOT
BLOWER INLET WIRING
BLOWN GRID MODULE
DECK PIPING GROUP
AIR SYSTEM
AIR STARTER PIPING
HORN INSTALLATION
FUEL SYSTEM
ENGINE FUEL PIPING
ELECTRICAL SYSTEM
POWER MODULE WIRING
HEAD & FOG LIGHTS
REAR LIGHT ASSEMBLY
HYDRAULIC SYSTEM
HOIST SYSTEM PIPING
- KOMATSU Fault Codes
