Komatsu PipeLayer K170 Operation & Maintenance Manual 5000-08OP-0001B
Type of Machine: PipeLayer
Type of Manual: Operation & Maintenance Manual
Model: Komatsu K170 PipeLayer
Serial Number: 50000500010021 and up
Publication Date: 2020
Form Number: 5000-08OP-0001B
Number of Pages: 100 Pages
Foreword
Read This Manual
Safety Information
Introduction
Main Use Of Machine
Directions Of Machine
Protectivestructures
Safety
Safety Labels — K170 Pipelayer
(1) Caution For Operation. Inspection And Maintenance
(2) Tipover Hazard
(3) Free Fall Active - Dc Not Operate
(4) Counterweight Lock Pm Thrown Or Flying Objects — Full Body Exposure
(5) Counterweight Crushing Hazard
(6) Counterweight Crushing Hazard. Use Lock Pin
(7) Hydraulic Accumulator
(8) Electrical Power Lines
(9) Boom Stop Operation And Adjustment — Check Daily
(10) Not A Tow Point
General Precautions Common To Operation And Maintenance
Precautions Before Starting Operation
Preparations For Safe Operation
Precautions Related To Protective Structures
Unauthorized Modification
Precautions Related To Attachments And Options
Precautions When Running Engine Inside Building
Precautions For Operation
Precautions For Jobsite
Investigate And Confirm Jobsite Conditions
Precautions When Working On Loose Ground
Do Not Go Close To High-Voltage Cables
Ensure Good Visibility
Check Signs And Signalman’S Signals
Beware Of Asbestos Dust
Start Engine
Use Warning Tags
Lifting Capacities
Precautions When Traveling On Slopes
Precautions When Operating Machine
Precautions When Parking Machine
Towing Information
Operation
General View
Machine Equipment Name
Pipelayer Operation
(1) Lock Lever
(3a) Joystick Hook Control
Accumulator - Relieving Charge
(2) Free Fall Button
(3b) Boom Control
Boomstopswitch
(4) Counter Weight Control
Coun Ter Weightlock Pin
Equipment Lowering With Engine Stopped
Machine Warm-Up ,
Transportation Information
Shipping The Machine
Maintenance
Lubricants- General
Lubricants
Lubricant Capacities (Refill)
Kowaserwces
Maintenance Schedule
Method For Checking Accumulator Pressure
Method For Checking Boom Stop Switch Operation And Adjustment
Method For Checking Counterweight Switch Opera Tion And Adjustment
Method For Lubricating Boom Pivot Pins
Method For Lubricating Counter Weight Hinge Pins 8 Cylinder Pins
Method For Inspecting Wire Cable - Boom And Hook Lines
Method For Installing Boom Line
Method For Installing Hook Load Line
Method For Changing Hook Winch: Gearbox Oil
Method For Changing Boom Winch: Gearbox Oil
Method For Changing Hydraulic System Oil
Method For Changing Case Dra In Oil Filter
Method For Checking Hydraulic System Oil Level
Method For Lubricating Sheave Block Bearing
Method For Lubricating Fairlead Sheave
Base Tractor Maintenance
Specifications
Lifting Capacities
Appendix A - Pullmaster M32 Winch Service Manual
