Komatsu Motor Grader GD655-7 GD675-7E0 Shop Manual SEN06741-12
Type of Machine: Motor Grader
Type of Manual: Shop Manual
Model: Komatsu GD655-7 GD675-7E0 Motor Grader
Serial Number: 65001 and up
Publication Date: 12.2021
Form Number: SEN06741-12
Number of Pages: 4318 Pages
00 Index And Foreword
Index
Foreword, Safety, Basic Information
01 Specification
Contents
Specifications
10 Structure And Function
Contents
Urea Scr System
Boot-Up System
Engine System
Control System
Power Train System
Work Equipment System
Undercarriage And Frame
Work Equipment
Cab Related Parts
20 Standard Value Table
Contents
Standard Value Table For Engine
Standard Value Table For Machine
30 Testing And Adjusting
Contents
Related Information On Testing And Adjusting
Engine And Cooling System
Power Train
Work Equipment
Pm-Clinic
40 Troubleshooting
Contents
Related Information To Troubleshoot
Troubleshooting By Failure Code (Display Of Code)
Troubleshooting Of Electrical System (E-Mode)
Troubleshooting For Hydraulic And Mechanical Systems (H Mode)
Troubleshooting Of Engine (S-Mode)
60 Maintenance Standard
Contents
Explanation Of Terms For Maintenance Standard
Power Train
Work Equipment
80 Others
Contents
Air Conditioner System
Component Parts Of Air Conditioner System
Procedure For Testing And Troubleshooting Air Conditioner
Circuit Diagram And Arrangement Of Connector Pins For Air Conditioner
Air Conditioner System Diagram
Locations Of Air Conditioner Parts And Arrangement Of Connectors
Test Air Conditioner With Self-Diagnosis Function
Test Air Leakage (Duct)
Check Temperature Control Function
Test Fresh/Recirc Air Changeover
Check Evaporator Temperature Sensor
Test Relays
Check Blower Amplifier
Air Conditioner Troubleshooting Chart 1
Air Conditioner Troubleshooting Chart 2
Information Described In Troubleshooting Table
Troubleshooting For Power Supply System (Air Conditioner Does Not Operate)
Troubleshooting For Compressor And Refrigerant System (Air Is Not Cooled)
Troubleshooting For Blower Motor System (No Air Comes Out Or Air Flow Is Abnormal)
Troubleshooting For Temperature Control Function
Troubleshooting For Fresh/Recirc Air Changeover
Troubleshooting For Hot Water Cut Valve
Troubleshooting Using Gauge Pressure
Connect Service Tool
Precautions For Disconnection And Connection Of Air Conditioner Pipings
Compressor Oil
90 Circuit Diagrams
Contents
How To Read The Codes For Electric Cable
Hydraulic Circuit Diagram
Electrical Circuit Diagram
Index
Index
01 Specification
Contents
Specifications
Contents
Urea Scr System
Boot-Up System
Engine System
Control System
Power Train System
Work Equipment
Cab Related Parts
Contents
Contents
Power Train
Work Equipment
Pm-Clinic
40 Troubleshooting
Contents
Contents
Power Train
Work Equipment
80 Others
Contents
Test Relays
Compressor Oil
90 Circuit Diagrams
Contents
Index
- KOMATSU Fault Codes
