Komatsu Motor Grader GD655-6 GD675-6 Shop Manual SEN06523-12
Type of Machine: Motor Grader
Type of Manual: Shop Manual
Model: Komatsu GD655-6 GD675-6 Motor Grader
Serial Number: 60001 and up
Publication Date: 10.2021
Form Number: SEN06523-12
Number of Pages: 3214 Pages
00 Index And Foreword
Index
Abbreviation List
Foreword, Safety, Basic Inform A Tic N
01 Specifications
Contents
Abbreviation Ust
Specifications
10 Structure And Function
Contents
Abbreviation Ust
Urea Scr System
Boot-Up System
Engine System
Control System
Hydrauuc System
Power Train System
Work Equipment System
Undercarriage And Frame
Work Equipment
Cab And Its Attachments
20 Standard Value Table
Contents
Abbreviation Ust
Standard Value Table For Engine
Standard Value Table For Machine
Standard Value Table For Electrical
30 Testing And Adjusting
Contents
Abbreviation Ust
Related Information On Testing And Adjusting
Engine And Cooling System
Power Train
Work Equipment
Pm Clinic
40 Troubleshooting
Contents
Abbreviation Ust
Related Information On Troubleshooting
Troubleshooting By Failure Code (Display Of Code)
Troubleshooting Of Electrical System (E-Mode)
Troubleshooting For Hydrauuc And Mechanical Systems (H Mode)
Troubleshooting Of Engine (S-Mode)
50 Disassembly And Assembly
Contents
Abbreviation Ust
Related Information On Disassembly And Assembly
Power Train
Hydrauuc System
Work Equipment
60 Maintenance Standard
Contents
Abbreviation Ust
Power Train
Hydrauuc System
Work Equipment
80 Appendix
Contents
Abbreviation List
Air Conditioner System
Component Parts Of Air Conditioner System
Explanation Of Procedure For Testing And Troubleshooting Of Air Conditioner
Circuit Diagram And Arrangement Of Connector Pins For Air Conditioner
Air Conditioner System Diagram
Installation Locations Of Air Conditioner Parts And Arrangement Of Connectors
Testing Air Leakage (Duct)
Testing Air Conditioner Using Self-Diagnosis Function
Check Temperature Control Function
Testing Fresh/Recirc Air Changeover
Test Evaporator Temperature Sensor
Test Relays
Check Blower Amp
Air Conditioner Troubleshooting Chart 1
Air Conditioner Troubleshooting Chart 2
Information Described In Troubleshooting Table
Troubleshooting For Power Supply System (Air Conditioner Does Not Operate)
Troubleshooting For Compressor And Refrigerant System (Air Is Not Cooled)
Troubleshooting For Blower Motor System (No Air Comes Out Or Air Flow Is Abnormal)
Troubleshooting For Temperature Control Function
Troubleshooting For Fresh/Recirc Air Changeover
Troubleshooting For Hot Water Cut Valve
Troubleshooting Using Gauge Pressure
Connection Of Service Tool
Precautions For Disconnecting And Connecting Hoses And Tubes In Air Conditioner Pipings
Handle Compressor Oil
90 Circuit Diagrams
Contents
Abbreviation List
Hydrauuc Circuit Diagram
Electrical Circuit Diagram
Index
