Komatsu Motor Grader GD530A(W)-2B(C)Y to GD670A(W)-2B(C)Y Shop Manual CEBD009900
Type of Machine: Motor Grader
Type of Manual: Shop Manual
Model: Komatsu GD530A(W)-2B(C)Y GD650A(W)-2B(C)Y GD670A(W)-2B(C)Y Motor Grader
Serial Number:
GD530A-2BY 203481 and up
GD530A-2CY 203201 and up
GD530AW-2BY 210242 and up
GD530AW-2CY 203290 and up
GD650A-2BY 202556 and up
GD650A-2CY 202642 and up
GD650AW-2BY 203328 and up
GD650AW-2CY 202662 and up
GD670A-2BY 203282 and up
GD6J0A-2CY 202681 and up
GD670AW2BY 203338 and up
GDGJ0AW-2CY 203234 and up
Publication Date: 2002
Form Number: CEBD009900
Number of Pages: 930 Pages
Foreword
Safety
General
How To Read The Shop Manual
Hoisting Instructions
Coating Materials
Standard Tightening Torque
Electric Wire Code
Conversion Tables
01 General
General Assembly Drawing
Fuel Coolant, And Lubricants
10 Structure And Function
Steering (Orbitrol) Control Valve
Transmission Power Shift
All-Wheel-Drive Pump
Circle Reverse Motor
Steering And Brake Pump
Awd Hydraulic Motor
Hydraulic Oil Swivel Block
Control Valve Manifolds
Main System Pump Mount
Main System Pump
Awd Hic Valve
Accumulator
Hydraulic System Overview
Main Hydraulic Circuit
Steering And Brake Circuit
All-Wheel-Drive Circuit
Lock/Unlock Differential Pump
Circle Reverse Sup Clutch
Circle Reverse Gear Case
Tandem Case
Awd Gearbox Assembly
Front Axle Assembly
Final Drive Assembly
Mico Parking Brake
Mico Brake Valve
Tilt Steering Console
20 Testing, Adjusting And Troubleshooting
Standard Value Tables
Awd Pump
Awd Hydraulic Motor
Four-Way Swivel Block
Front Axle And Gearbox
Hydraulic Cyunders
Ball And Socket Shimming Adjustment
Accumulators
Hydraulic Circuits
Lock/Unlock Differential Reuef Valve
Tandem Case
Circle Adjustment
Circle Reverse Slip Clutch
Parking Brake Caliper
Brake Valves
Troubleshooting
Predelivery Procedures
30 Disassembly And Assembly
Method Of Using Manual
Precautions During Operation
Special Tool List
Sketches Of Special Tools
Articulation Joint
Engine Hood, Front & Rear Cowling
Fuel Tank And Hydraulic Tank
Transmission Shifter
Transfer Case
Steering (Orbitol) Valve
Hydraulic Motor
4-Way Sw1val Valve Block
Main System Pump
Hydraulic Integrated Circuit Valve
Hydraulic Cylinders
Accumulators
Tandem Case
Awd - Gearbox Assembly
Awd Motor (Vickers/Eaton)
Front Axle Assembly
Circle Tooth Rebuild
Mico Parking Brake Caliper
Brake Valve
Air Conditioning
40 Maintenance Standard
Final Drive
No Spin Differential Case Assembly
No Spin Differential Assembly
Final Drive And Tandems
Tandem Drive
Brake Valve
Steering Cylinder
Leaning Wheel Cylinder
Moldboard Tilt Cylinder
Moldboard Side Shift
Drawbar Side Shift Cylinder
Drawbar Uft Cylinder
Scarifier Cyunder
Articulation Cylinder
Ripper Cyunder
Lug Nuts
Front Axle
Power Tilt Moldboard Carrier
Frame
Drawbar And Circle
Drawbar Uft
Engine And Transmission
Drive Line
Cab Mount
90 Other
Original Electrical Diagram (Sheet 1 Of 3)
Original Electrical Diagram (Sheet 2 Of 3)
Original Electrical Diagram (Sheet 3 Of 3)
Revised Electrical Diagram (Sheet 1 Part 1 Of 2)
Revised Electrical Diagram (Sheet 1 Part 2 Of 2)
Revised Electrical Diagram (Sheet 2)
800 Transmission With Awd Diagram
Hydraulic Circuit Diagram (Sheet 1 Of 2)
Hydraulic Circuit Diagram (Sheet 2 Of 2)
Serial Number:
Foreword
Safety
General
Coating Materials
Electric Wire Code
Conversion Tables
01 General
Awd Hydraulic Motor
Main System Pump
Awd Hic Valve
Accumulator
Tandem Case
Front Axle Assembly
Mico Parking Brake
Mico Brake Valve
Awd Pump
Awd Hydraulic Motor
Hydraulic Cyunders
Accumulators
Hydraulic Circuits
Tandem Case
Circle Adjustment
Brake Valves
Troubleshooting
Special Tool List
Articulation Joint
Transfer Case
Hydraulic Motor
Main System Pump
Hydraulic Cylinders
Accumulators
Tandem Case
Front Axle Assembly
Brake Valve
Air Conditioning
Final Drive
Tandem Drive
Brake Valve
Steering Cylinder
Scarifier Cyunder
Ripper Cyunder
Lug Nuts
Front Axle
Frame
Drawbar And Circle
Drawbar Uft
Drive Line
Cab Mount
90 Other
- KOMATSU Fault Codes
