Komatsu Motor Grader 830B 850B 870B 830C 850C 870C Shop Manual CEBD011200
Type of Machine: Motor Grader
Type of Manual: Shop Manual
Model: Komatsu 830B 850B 870B 830C 850C 870C Motor Grader
Serial Number:
830B 203163 and up
830C 202753 and up
850B 202575 and up
850C 202727 and up
870B 202509 and up
870C 202775 and up
Publication Date: 2003
Form Number: CEBD011200
Number of Pages: 930 Pages
The Bookmarks of Komatsu 830B 850B 870B 830C 850C 870C Motor Grader Shop Manual:
Foreword
Safety
General
How To Read The Shop Manual
Hoisting Instructions
Coating Materials
Standard Tightening Torque
Electric Wire Code
Conversion Tables
01 General
General Assembly Drawing
Fuel, Coolant, And Lubricants
10 Structure And Function
Steering (Orbitrol) Control Valve
Transmission Power Shift
All-Wheel-Drive Pump
Circle Reverse Motor
Steering And Brake Pump
Awd Hydraulic Motor
Hydraulic Oil Swivel Block
Control Valve Manifolds
Main System Pump Mount
Main System Pump
Awd Hic Valve
Accumulator
Hydraulic System Overview
Main Hydraulic Circuit
Steering And Brake Circuit
All-Wheel-Drive Circuit
Lock/Unlock Differential Pump
Circle Reverse Slip Clutch
Circle Reverse Gear Case
Tandem Case
Awd Gearbox Assembly
Front Axle Assembly
Final Drive Assembly
Mico Parking Brake
Mico Brake Valve
Tilt Steering Console
20 Testing, Adjusting And Troubleshooting
Circle Adjustment
Parking Brake Caliper
Brake Valves
Standard Value Tables
Awd Pump
Awd Hydraulic Motor
Four-Way Swivel Block
Front Axle And Gearbox
Hydraulic Cylinders
Ball And Socket Shimming Adjustment
Accumulators
Hydraulic Circuits
Lock/Unlock Differential Relief Valve
Tandem Case
Troubleshooting
Predelivery Procedures
30 Disassembly And Assembly
Method Of Using Manual
Precautions During Operation
Special Tool List
Sketches Of Special Tools
Articulation Joint
Engine Hood, Front & Rear Cowling
Fuel Tank And Hydraulic Tank
Transmission Shifter
Transfer Case
Steering (Orbitol) Valve
Hydraulic Motor
4-Way Swival Valve Block
Main System Pump
Hydraulic Integrated Circuit Valve
Hydraulic Cylinders
Accumulators
Tandem Case
Awd - Gearbox Assembly
Awd Motor (Vickers/Eaton)
Front Axle Assembly
Circle Tooth Rebuild
Mico Parking Brake Caliper
Brake Valve
Air Conditioning
40 Maintenance Standard
Final Drive
No Spin Differential Case Assembly
No Spin Differential Assembly
Final Drive And Tandems
Tandem Drive
Brake Valve
Steering Cylinder
Leaning Wheel Cylinder
Moldboard Tilt Cylinder
Moldboard Side Shift
Drawbar Side Shift Cylinder
Drawbar Lift Cylinder
Scarifier Cylinder
Articulation Cylinder
Ripper Cylinder
Lug Nuts
Front Axle
Power Tilt Moldboard Carrier
Frame
Drawbar And Circle
Drawbar Lift
Engine And Transmission
Drive Line
Cab Mount
90 Others
Original Electrical Diagram (Sheet 1 Of 3)
Original Electrical Diagram (Sheet 2 Of 3)
Original Electrical Diagram (Sheet 3 Of 3)
Revised Electrical Diagram (Sheet 1 Part 1 Of 2)
Revised Electrical Diagram (Sheet 1 Part 2 Of 2)
Revised Electrical Diagram (Sheet 2)
800 Transmission With Awd Diagram
Hydraulic Circuit Diagram (Sheet 1 Of 2)
Hydraulic Circuit Diagram (Sheet 2 Of 2)
