Komatsu Motor Grader 830 850 870 Shop Manual CEBMG58102
Type of Machine: Motor Grader
Type of Manual: Shop Manual
Model: Komatsu 830 850 870 Motor Grader
Serial Number: 200000 thru 200987, 200997 thru 200416
Publication Date: 1992
Form Number: CEBMG58102
Number of Pages: 861 Pages
Articulation Joint Assembly
Char-Lynn Orbitrol Unit
Tilt Steering Console
Transmission, Power Shift (Funk 2263e1 30b)
All Wheel Drive Pump (Rexroth)
Circle Reverse Motor (Danfoss)
Steering & Brake Pump (Eaton Model 70422 Rdu)
Hydraulic Motor (Vickers) (Drum Drive & All Wheel Drive)
Hydraulic Oil Swivel Block (2-Way & 4-Way)
Control Valve Manifolds (Husco)
Main System Pump (Cessna)
All Wheel Drive (Awd) H.I.C. Valve
Hydraulic Cylinders
Accumulators (Pin 1285 352 H910 1279 537 Hl & 1233 789 H91)
Troubleshooting And Adjustment Manual
Rear Axle Cooling And Lock/Unlock Differential Pump
Circle Reverse Gear Case
Tandem Case (Single And Double Strand Chains)
Gearbox Assembly (Awd)
Front Axle Assembly
Final Drive Assembly With Planetary And Non-Planetary Reduction
Circle Adjustment (Four Shoe)
Parking Brake Caliper (Perrot Pin 40 023 002)
Brake Valve (Rexroth Model Mb 08 Hmd-Ixi7o-19h)
Wiring Diagrams
Suspension Seat
General Torque Values
Metric Conversions
Hydraulic Cylinders
Front Axle Assembly
Wiring Diagrams
Suspension Seat
Metric Conversions
- KOMATSU Fault Codes
