Komatsu Mining Shovel PC5500 Field Assembly Instructions FAMPC5500-04
Type of Machine: Mining Shovel
Type of Manual: Field Assembly Instructions
Model: Komatsu PC5500 Mining Shovel
Form Number: FAMPC5500-04
Publication Date: 2005
Number of Pages: 104 Pages
Main Menu
Cover
Contents
1. Assembly of the Undercarriage (Z 24016a, Z 24018a)
1.1 Assembly
2. Assembly of the Cable Reel Unit (Z21885)
3. Assembly of the Superstructure Platform onto the Undercarriage (Z21886)
4. Assembly of the Prime Drive Unit to the Superstructure Platform (Z 21887)
4. a Mounting of the hydraulic access ladder (Z21136)
5. Assembly of the Boom Cylinders and the Stick Cylinder to the Boom (Z 21888a; Z 21941, Z 21944)
5.a. Assembly of the Boom (Z21889a)
6. Assembly of the Counterweight (Z21891b)
7. Mounting of the Fuel Tank (Z 21892) or Main Switch Cabinet for Electrical Driven Unit
8. Mounting of the Cab Base (Z 21893)
9. Mounting of the Cab with Support Frame (Z 21894)
10. Mounting of the High Pressure Hoses (Z 21896) and the Hydraulic Od Tank (Z 21897)
11. Mounting of the Hydraulic Od Cooler (Z 21895)
12. Mounting of the Hand Rails, Cat Walks, Steps and the Grease Barrel Crane* (Z 21901)
13. Mounting of Cable transfer to the Operators Cab (Z22937)
13a. Installation of Hydraulic Hoses to the Attachment and Rotary Joint
14. Checking of direction motor rotation Z 22844a
15. Connection of Electric Cables
16. Filling the Hydraulic System (Z25026)
17. Pre-checks prior Initial Start-up
17.1 General
17.2 Only with Electric Drive
17.3 Initial Start up
18. Assembly of the Stick to the Boom: Z 21890
19. Mounting of the Stick Cylinders to the Stick (Z 21903)
20. Assembly of the Bullclam Bucket to the Stick: Z 21904
21. Mounting of the Pin Seals (Z 21906)
22. Putting the Lubrication System into operation (Z25022)
23. Checks and Adjustments Prior Commissioning
Metric standard thread
Metric fine thread
Main Menu
Cover
Contents
1.1 Assembly
17.1 General
Metric fine thread
- KOMATSU Fault Codes
