Momed80
151
35,863
Komatsu Mini Excavator PC35MR-5 Parts Book YEPB203700-00 2026
Type of Manual: Parts Book
Model: Komatsu PC35MR-5 Mini Excavator
Engine: 3D88E-7
Serial Number:
PC35MR-5 DBGC0001- And Up
3D88E-7 101 and up
Part Number: YEPB203700-00
Publication Date: 2026
Number of Pages: 422 Pages
ENGINE UNIT
Gear Housing
Flywheel Housing and Oil Pan
Air Intake Manifold
Exhaust Manifold
Camshaft and Drive Gear
Crankshaft and Piston
Lubricating Oil System
Water Pump and Fan
Fuel Injection Pump and Piping (112)
Fuel Injection Pump and Piping (212)
Injector
Fuel Piping
Starting Motor
Controller
Gasket Kit and Tool
ENGINE RELATED PARTS
Engine Related Parts
Mounting
Exhaust Muffler Related Parts
Mounting Bracket
Air Cleaner Related Parts
Air Conditioner Related Parts
Mounting Bracket (With ROPS Cab,Air Conditioner)
Gear Pump
Air Conditioner Piping
Fuel Piping
Piston Pump (1/6)
Piston Pump (2/6)
Piston Pump (316)
Piston Pump (4/6)
Gear Pump (Vlfith ROPS Cab,Air Conditioner)
Piston Pump (516)
Piston Pump (616)
Piston Pump Related Parts
Damper
Fuel Piping (With ROPS Cab,Air Conditioner)
Engine Mounting
Air Cleaner
COOLING SYSTEM
Fan Net
Frame and Oil Cooler
Fan Net (With Air Conditioner)
Frame and Oil Cooler (With Air Conditioner)
Radiator (With Air Conditioner)
FUEL SYSTEM
Hose and Clamp
Tank
ELECTRICAL SYSTEM
Battery
\Mring Harness
Main Wiring Harness
Main Wiring Harness Mounting
Valve Wiring Harness
KOMTRAX Antenna
Machine Controller and KOMTRAX Antenna
Battery Disconnect Switch
KOMTRAX Controller
Headlamp, LED
Travel Alarm
HYDRAULIC SYSTEM
HydraulicTank
Tani:
Mounting Parts
Control Valve, 2WAY
9-Valve (1124)
9-Valve (2124)
9-Valve (3124)
9-Valve (4124)
9-Valve (5124)
9-Valve (6124)
9—Valve (7124)
9—Valve (8124)
9-Valve (9124)
9—Valve (10/24)
9—Valve (11/24)
9-Valve (12124)
9-Valve (13124)
9—Valve (14/24)
9-Valve (15124)
9-Valve (16124)
9.Valve (17/24)
9.Valve (18/24)
9-Valve (19124)
9-Valve (20/24)
9-Valve (21/24)
9-Valve (22/24)
9-Valve (23124)
9-Valve (24/24)
Connecting Parts (1/3)
Connecting Parts (213)
Connecting Parts (313)
Drain Piping
Attachment Piping
Sheet (1/2)
Valve Mounting
Travel and PPC Lock Solenoid Valve
EPC Valve Piping
Valve Piping
Sheet (2/2)
Control Valve, 4WAY
Suction Piping
Delivery Piping
Retum Piping
Drain Piping
Actuator Piping
Travel and Blade (With 1-Additional Actuator Piping)
Piping (112) (With 1-Additional Actuator Piping)
Piping (212) (With 1-Additional Actuator Piping)
FRAME AND ITS RELATED PARTS
Revolving Frame
Boom Swing Bracket
Boom Swing Cylinder
Inner Parts, Swing Cylinder
Mounting
Swing Circle Lubrication
OPERATOR'S COMPARTMENT AND CONTROL SYSTEM
Operator's Seat
Inner Parts (Rigid Type, Reclining)
Mounting (Rigid Type, Reclining,With ROPS Canopy or Plastic Top Canopy)
Inner Parts (78mm Seat Belt, 2-Point Type, Suspension Type)
Mounting (78mm Seat Belt, 2—Point Type, Suspension Type,With ROPS Cab)
Additional Working Lamp
Antenna
Radio
Cab Body and Window
Front Window
Front Lower Window
Door
Door Lock (112)
Door Lock (212)
Wiper
Cab In Parts, Grip and Rear Cover
Headlamp
Floor, Base
Floor, Travel Control Valve Cover
PPC Valve (116) (For Travel)
Floor, PPC Piping for Travel Valve
PPC Valve (216) (For Boom Swing)
Boom Swing Pedal and Piping
Floor, P, T Block
Floor, Console, L.H.
PPC Valve (316) (For Work Equipment L.H.)
Floor, Console, R.H.
Monitor
PPC Valve (416) (For Work Equipment R.H.)
Cab Wiring Hamess
PPC Valve (516)
Blade Control Lever
Cab In Parts, Floor Cover (112)
Floor, Under Sheet
Attachment Pedal
PPC Valve (616) (For Attachment)
Attachment Piping
Wrist Rest
Cap, Console Box
Floor, Travel Control Lever
Travel Pedal
Inner Parts, Air Conditioner Unit (113)
Inner Parts, Air Conditioner Unit (213)
Inner Parts, Air Conditioner Unit (313)
Air Conditioner Controller
Air Conditioner Unit Mounting (112)
Air Conditioner Unit Mounting (212)
Air Conditioner Duct
Controller Mounting Bracket
Controller
Room Lamp
Cab In Parts, Floor Cover (212)
Cup Holder
Rear Cover
Cab Mounting
Rearview Mirror
Hose Clamp
Floor Mat
(With ROPS Cab,1-Additional Actuator Piping)
(With ROPS Canopy or Plastic Top Canopy,1—Additional Actuator Piping)
Window Washer
Canopy
Rearview Mirror
Mounting Bracket
Hose
Ashtray
Floor Frame
Floor, Base
Floor, P, T Block
Monitor
Floor, Wiring Harness
PPC Valve (516) (For Blade)
Blade Control Lever
Floor Cover
Floor, Under Sheet
Attachment Pedal
Attachment Piping
Wrist Rest
Cap, Console Box
Travel Pedal
Mounting
Hose Clamp
Floor Mounting
Gas Springs Related Parts (With ROPS Cab)
Bracket (With ROPS Cab)
Sheet (With ROPS Cab)
Plug (With ROPS Cab)
Gas Springs Related Parts (With ROPS Canopy or Plastic Top Canopy)
Bracket (With ROPS Canopy or Plastic Top Canopy)
Cap (With ROPS Canopy or Plastic Top Canopy)
Sheet (112) (With ROPS Canopy or Plastic Top Canopy)
Sheet (212) (With ROPS Canopy or Plastic Top Canopy)
Mode Selection Connectors
Handrail
GUARDS AND COVERS
Hood
Left Side Cover
(With ROPS Cab)
Right Side Cover
Front (With ROPS Canopy)
Rear (With ROPS Canopy)
Front (With ROPS Cab)
Rear (With ROPS Cab)
Front Cover
Counterweight
Additional Counterweight
Parts For Less Additional Counterweight
Under Cover
SWING CIRCLE AND ITS RELATED PARTS
Swing Machinery and Motor
Swing Machinery
Inner Parts, Swing Motor (112)
Inner Parts, Swing Motor (212)
Related Parts
Mounting and Connecting Parts
UNDERCARRIAGE
Track Shoe Assembly
Idler Cushion
Track Shoe
Track Guard
Track Frame
Swing Circle
Drain Piping, Swivel Joint
Inner Parts, Swivel Joint
Connecting Parts, Swivel Joint
Travel Motor Piping, Lower
Inner Parts, Reduction Gear
Inner Parts, Hydraulic Motor (112)
Inner Parts, Hydraulic Motor (212)
Sprocket
Connecting Parts, Travel Piping
Front Idler
Track Roller
Frame
Carrier Roller
Track Frame Cover (112)
Swing Circle Mounting
Hose Clamp
Track Frame Cover (212)
WORK EQUIPMENT
Boom Unit
Boom and Piping
Attachment Piping
Inner Parts, Arm Cylinder
Pin, Arm Cylinder
Boom Cylinder Piping
Pin, Boom Cylinder
Working Lamp
Boom Cylinder
Inner Parts
Boom Cylinder Cover
Arm and Bushing
Additional Piping
Inner Parts, Bucket Cylinder
Bucket Link
Arm Cylinder Head Pin
Pin, Arm Cylinder
Bucket Link
Bucket Link
Bucket Pin
Blade
Blade Cylinder
Inner Parts, Blade Cylinder
Cover and Pin
MARKS AND PLATES
Warning Plate
AUXILIARY PARTS AND TOOL
General Tool Set
FIELD REPAIR SERVICE PARTS
Service Kit Parts
