Komatsu Hydraulic Mining Excavator PC1600-1 Shop Manual SEBM021TA103
Type of Machine: Hydraulic Mining Excavator
Type of Manual: Shop Manual
Model: Komatsu PC1600-1 Hydraulic Mining Excavator
Serial Number: 10001 and up
Form Number: SEBM021TA103
Number of Pages: 650 Pages
10 Structure And Function
Pto (Power Take-Off)
Pto Lubrication System
Radiator And Oil Cooler
Auto-Deceleration System
Power Train
Travel And Brake System
Swing System
Track Frame
Idler Cushion
Idler
Track Roller
Carrier Roller
Track
Air System
Air Governor
Air Tank
Auto-Drain Valve
Safety Valve
Solenoid Valve (For Lubrication, Horn)
Grease Pump
Greasing System
Hydrauuc Piping Diagram
Hydraulic Circuit Diagram
Work Equipment Control
Automatic Work Equipment Control System
Hydraulic Tank
Main Pump
Hydraulic Oil Filter
Charging And Pto Lubricating Pump
2-Stage And 3-Stage Mode Selector Olss (Open Center Load Sensing System)
Control Valve
Ppc Valve
Ppc Shuttle Valve
Accumulator
Pilot Relief Valve
Safety Lock Valve
Hydraulic Cylinder
Work Equipment
Electrical Circuit Diagram
Electrical Components Of 3-Stage Mode Selector Olss
Electronic Components Of Automatic Work Equipment Control System
Evms (Electronic Vehicle Monitoring System)
20 Testing And Adjusting
Table Of Judgement Standard Value
Table Of Electrical Judgement Standard Value
Testing And Adjusting Tool Ust
Adjusting Valve Clearance
Measuring Compression Pressure
Adjusting Fuel Injection Timing
Adjusting Fuel Control Lever
Adjusting Auto-Deceleration System
Testing And Adjusting Of Main Relief Valve
Testing And Adjusting Control Circuit Pressure
Measuring Oil Leakage From Swing And Travel Motor
Testing Oil Leak From Swivel Joint
Air Bleeding
Charging Accumulator With Gas
Testing Method Using Visual And Functional Check
Adjustment Of Work Equipment Potentiometer
Adjustment Of Work Equipment Control Box (Loading Shovel)
Troubleshooting
30 Disassembly And Assembly
40 Maintenance Standard
Travel Motor
Travel Shuttle Valve
Straight-Travel Valve
Travel Brake Valve
Swing Control Valve
Jet Sensor
Connection Valve
Swing Motor
Swing Circle
Swing Machinery
Final Drive
Track Frame
Track Shoe
Idler
Track Roller
Carrier Roller
Charging And Pto Lubrication Pump
Pilot Relief Valve
V2, V4 Control Valve
V1controlvalve
V3controlvalve
Ppc Valve
Ppc Shuttle Valve
Hydraulic Cylinder
Work Equipment
